Icelandair flight FI603, a Boeing 737-9 (registration, TF-ICA) aircraft, was on approach to Toronto,
ON (CYYZ) Runway 33R when a glide slope fluctuation caused the autopilot to disconnect. The
flight crew continued flying the approach manually. The aircraft deviated above the glide slope
(GS) in the later part of the approach, as a result the pilot flying (PF) increased the rate of decent.
Just prior to the point of flare, the flight crew increased the nose up pitch to slow the aircraft, but
the aircraft touched down hard and bounced. The PIC called for a go around after the bounce and
the aircraft was brought around for a second approach. The aircraft landed without further incident.
The next flight crew noticed that the tail skid was damaged on their walkaround. Maintenance
confirmed the tail skid crush cartridge needed to be replaced, there was no other damage to
aircraft.
Icelandair 737 Tailstrike YYZ
FlyingMonkey
Re: Icelandair 737 Tailstrike YYZ
The tail strike crush cartridge worked. Non event.
Re: Icelandair 737 Tailstrike YYZ March 4, 2023
Iceland B39M at Toronto on Mar 4th 2023, tail strike on balked landing
http://avherald.com/h?article=5063b57f&opt=0
An Icelandair Boeing 737-9 MAX, registration TF-ICA performing flight FI-603 from Keflavik (Iceland) to Toronto,ON (Canada) with 177 passengers and 6 crew, was landing on Toronto's runway 33R, the next departure already received clearance to line up for departure, when the crew initiated a go around advising tower they had balked their landing to be safe. The aircraft climbed to 4000 feet and positioned for another approach to runway 33R. The aircraft landed without further incident about 13 minutes after the balked landing.
