Is it fine to do more than minimums for Night Rating?
nishranth
Post by nishranth »
Apart from the minimum Night Rating reuqirements of 5 hours solo and 5 hours dual. Is it okay if I do more solo hours before I submit my night rating application?
I plan to submit my night rating application with 10hours of solo and6 hours of dual night flight time.
Would that be a problem?
Re: Is it fine to do more than minimums for Night Rating?
No problem at all.
Bede
Post by Bede »
No it's not a problem but why would you do that? You need to be under the supervision of an instructor the whole time.
What I would encourage you to do is do as much of your 100 PIC that you need for your CPL as night XC. This will help you out a lot when you go for your ATPL.
broken_slinky
Post by broken_slinky »
Bede wrote: Tue Mar 14, 2023 12:37 pm No it's not a problem but why would you do that? You need to be under the supervision of an instructor the whole time.
+1
nishranth
Post by nishranth »
I just delayed my application for Night Rating and ended up doing about 5 additional hours of Solo Night XC. So i was worried if it would be a problem while applying for the Rating
