The amount of flying time and landings is likely irrelevant for such a situation. I'm more wondering about the age of the rubber. Basically when will a tubeless tire start leaking, or when will a tube start to rot such that the valve stem starts leaking. (those seems to be the most common failure modes on old tires, but I just added them as an example).
Is there a rule of thumb when you should change them?
And on the same note, does anybody have the details of the air michelin/condor tire codes?
Internet tells me:
Source https://iflyamerica.org/how_old_is_this_new_tire.aspMichelin (Air, Aviator and Condor)
Michelin aircraft tires are marked with a ten-digit serial number that also represents the year and Julian date that the tire was produced. Character one represents the last number of the manufacturing year; the next three numbers indicate the Julian day and the remaining six characters are related to decade of production, manufacturing facility and production number. For example: 9211P0025 (9) is for 1999, (211) is the Julian day - 29 July, (P) pertains to the facility and decade, 0025 is a unique production number. For more information see https://aircraft.michelin.com.
But I'm trying to figure out what all the possible facility/decade codes mean. P is explained here, wondering about 'S' in particular. Google came up empty.
