Travel benefits
Travel benefits
Hello,
How does travel benefits work for TS?
Is it only for spouse (marriage) , parents, kids ?
Or you can have travel partner? Or common law spouse ?
Re: Travel benefits
avcan123 wrote: ↑Mon Jun 26, 2023 8:02 pm Hello,
Starts upon hiring, some confirmed passes based on YOS, standby and discounts
All of the above
If you do not have a spouse or common law partner you can have a registered companion
Re: Travel benefits
does TS have any standby travel agreements with any airlines through myidtravel etc?
Re: Travel benefits
Essentially every major airline worldwide and many smaller ones.
Re: Travel benefits
that's pretty neat. which means it is pretty much covering every corner of the world ,thank you for your reply,cheers
Re: Travel benefits
And most importantly at Air Transat you will get enough days OFF to use your travel benefit, it looks like that we work less than at any other airlines in CanadaKingair200 wrote: ↑Fri Jun 30, 2023 12:24 amthat's pretty neat. which means it is pretty much covering every corner of the world ,thank you for your reply,cheers![]()
