Metric or Imperial
NEBOJSA
Metric or Imperial
Post by NEBOJSA »
Do Canadian airlines use Metric or Imperial calculations for fuel loading in Canada.What about other airlines that fly to/from Canada.
NotDirty!
Re: Metric or Imperial
Post by NotDirty! »
Yes.
NotDirty!
Post by NotDirty! »
I suppose I can explain further…
Fuel in Canada is sold in litres, so the fuel ticket will always show the net delivery in litres.
However, most FBOs see enough Americans that if they receive an order in US Gallons, they know to multiply by 3.785 L/USG to make the conversion.
Most airliners have fuel systems calibrated in pounds or kilograms. Most of those take single point fuelling, where the airplane systems automatically direct the fuel to the appropriate tanks, and then shut off the flow once the preset quantity is reached. In these cases, the request will be to fill to 10,000 kg or whatever, and the fueller sets that value on the fuel panel, hooks up their hose, and waits for the magic to make the fuel stop.
So in short, yes, metric or imperial.
NEBOJSA
Post by NEBOJSA »
Thank you
Eric Janson
Post by Eric Janson »
NEBOJSA wrote: Sun Oct 22, 2023 3:46 am What about other airlines that fly to/from Canada.
All our weights are in Kg.
After refuelling Engineers convert from Li to Kg using the specific gravity - this calculation goes in the Tech Log.
Flair is Litres for fuel uplift, KG or metric Tonnes for fuel on board, and metric Tonnes for aircraft weights, but Knots for IAS, and inches of mercury for QNH.
Mach1
Post by Mach1 »
Fuel: Pounds
W & B: Pounds
Speed: Knots
Distance: Nautical Miles
Temperature: Celsius
Altitude: Feet
Altimeter: Inches of Mercury
Fuel volume: Litres
Cargo Volume: Cubits
Weight of Cargo: Grains
Currency Conversion: Shekels
CaptDukeNukem
Post by CaptDukeNukem »
Mach1 wrote: Sun Oct 29, 2023 6:02 pm Fuel: Pounds
W & B: Pounds
Speed: Knots
Altitude: Feet
Fuel volume: Litres
Nice. :) We measure our cargo weight in “stone” and cargo volume by : “cubic micrometers”
