Dash FO to captain upgrade time
Bryce55
Post by Bryce55 »
I have heard Porter does have a picus program, I’m just wondering what the average upgrade time has been to accomplish that?
Do you need to fulfill the captain requirements or are they different for position upgrades?
Timetoflyagain
Re: Dash FO to captain upgrade time
Post by Timetoflyagain »
Bryce55 wrote: Fri Oct 27, 2023 1:58 am I have heard Porter does have a picus program, I’m just wondering what the average upgrade time has been to accomplish that?
Porter is hiring direct entry Captains on the Q…meaning if you’re a FO and have the requirements…go for it! With current and expected fleet growth on both the E and Q fleets it’ll be a logbook numbers game vs a seniority numbers game for a good long time.
Bryce55
Post by Bryce55 »
yeah thanks I'm looking into getting FO at 1000 ish hours and working my way up.
Bryce55 wrote: Fri Oct 27, 2023 1:07 pm yeah thanks I'm looking into getting FO at 1000 ish hours and working my way up.
I'd bank on 3 years, and hope to be pleasantly surprised if you get on with 1000 TT. You may find you want to fly the right seat of the jet for a stint before then working up the left side of the pay scale, you never know. That said, the DEC hiring matrix for Porter is higher for the Q, than it is for the Jet so who knows?
kenaanna
Post by kenaanna »
Hey Bryce55! The average upgrade time for the PICUS program at Porter can vary, but many pilots report around 2-3 years. You typically need to meet the captain requirements for position upgrades, but it’s best to check with HR for specifics. Hope this helps!
rice purity test
IcePharaoh
Post by IcePharaoh »
Hi, what are the captain requirements for the Q400 at Porter?
braaap Braap
Post by braaap Braap »
Management starts applying the pressure ~2000 total and 500 on type
IcePharaoh
braaap Braap wrote: Fri Nov 22, 2024 7:26 am Management starts applying the pressure ~2000 total and 500 on type
Thank you. What if it's an E2 FO upgrading to the left seat of the Q without the time on type?
braaap Braap
IcePharaoh wrote: Fri Nov 22, 2024 12:08 pm
The idea is just starting to be played with. Havent heard of anyone doing it. Id imagine they’d want to see 500-1000 MPIC of a transport level turboprop.
cdnavater
Post by cdnavater »
braaap Braap wrote: Fri Nov 22, 2024 12:41 pm
Isn’t E2 FO pay slightly higher or basically the same as Q captain?
braaap Braap
cdnavater wrote: Fri Nov 22, 2024 1:43 pm
No they adjusted it last february so that Q CA is a bit ahead of E2 FO after people decided to forgo the upgrade
BaldChewbacca
Post by BaldChewbacca »
Dash captains make $1/hr more than an E2 fo. So it's essentially the same and personally I wouldn't take on the added work of a dash captain if I could make the same as an E2 fo. Keep in mind that there is no yos at Porter, so you could go for example yr3 fo making $115/hr to a yr1 captain making $112/hr. It just doesn't make sense
cdnavater
Post by cdnavater »
BaldChewbacca wrote: Fri Nov 22, 2024 5:23 pm Dash captains make $1/hr more than an E2 fo. So it's essentially the same and personally I wouldn't take on the added work of a dash captain if I could make the same as an E2 fo. Keep in mind that there is no yos at Porter, so you could go for example yr3 fo making $115/hr to a yr1 captain making $112/hr. It just doesn't make sense
That’s basically what I thought, why would you bother for that!
dontcallmeshirley
Post by dontcallmeshirley »
cdnavater wrote: Fri Nov 22, 2024 9:39 pm
Your comment is disingenuous. Let's ignore the years in the Q captain seat counting toward your starting pay and look at the actual pay rates whether you go DEC Q or FO E2. The difference only goes up with the years in seat match.
Code: Select all
Year | Q400 DEC | E2 FO | Difference
  1  |   $112   |  $85  |    $27
  2  |   $116   |  $100 |    $16
  3  |   $126   |  $115 |    $11
  4  |   $136   |  $125 |    $11
  5  |   $141   |  $135 |    $6
It only becomes $1 different after 5 years (step 6) with the company. At that point, you'll have an ALPA contract and the WaWCons are going to be different.
cdnavater
Post by cdnavater »
dontcallmeshirley wrote: Fri Nov 22, 2024 10:40 pm
Code: Select all
I believe the question was going from E2 FO at Porter to Q captain? Porter does not give YOS when you go from right to left seat, you go back to step 1 in your new seat. So let’s say you’re year 3 E2 FO and go left seat Q, it appears you would go from 115 to 112. Someone
Who works there can feel free to correct me on YOS but that’s how I understand it.
goingnowherefast
Post by goingnowherefast »
Wow that's dumb. Why would anyone go e2 FO to q400 capt with those rules? Even a 2yr e2 FO upgrading, and going yr1 ca q400. The first year or two maybe, but compare e2 fo yr4 to q400 ca yr3. Why would anyone do that? More work, more responsibilities, less money. The q400 to e2 movement is heavily throttled, so you'll never go back either. Just stay in the right seat of the e2, make more money and patiently await the upgrade on type.
dontcallmeshirley
cdnavater wrote: Sat Nov 23, 2024 1:53 am I believe the question was going from E2 FO at Porter to Q captain? Porter does not give YOS when you go from right to left seat, you go back to step 1 in your new seat. So let’s say you’re year 3 E2 FO and go left seat Q, it appears you would go from 115 to 112. Someone
I must have misread it. In that scenario, it makes no sense unless you want the PIC time and the thrill of landing on the island.
Grey_Wolf
Post by Grey_Wolf »
goingnowherefast wrote: Sat Nov 23, 2024 4:17 am Wow that's dumb. Why would anyone go e2 FO to q400 capt with those rules? Even a 2yr e2 FO upgrading, and going yr1 ca q400. The first year or two maybe, but compare e2 fo yr4 to q400 ca yr3. Why would anyone do that? More work, more responsibilities, less money. The q400 to e2 movement is heavily throttled, so you'll never go back either. Just stay in the right seat of the e2, make more money and patiently await the upgrade on type.
The issue that most of these newer FO's will run into is not having any considerable PIC time. Their career progression (for low time folks), as laid out would be Q-FO, E2-FO, Q-Capt, E2-Capt. For those that have significant prior multi-pic time, they would be able to skip the Q-Captain portion.
With the matrix, below:
Entry Level Captain E195-E2:
- Minimum 4000 hours total time AND 500 hours PIC on type variant (E170/175/190/195, E1/E2)
- AND, 500 hours PIC on either EFIS Transport Category Aircraft Heavy Turboprop OR jet over 44000 lbs MTOW (as per CAR 705 or equivalent)
OR
- Minimum 4500 hours total time and one of the following:
- 500 hours PIC on type variant (E170/175/190/195, E1/E2)
- 1000 hours PIC on either EFIS Transport Category Aircraft Heavy Turboprop OR jet over 44000 lbs MTOW (as per CAR 705 or equivalent)
- 1000 hours total time transport category jet
- 500 hours PIC on either EFIS Transport Category Aircraft Heavy Turboprop OR jet over 44000 lbs MTOW (as per CAR 705 or equivalent), AND, 500
hours total time transport category jet.
IMHO, the E2 shouldn't be the FO's first ever Captain job.
goingnowherefast
Jazz has no problem doing it in CRJs and the 175. Air Canada does it too. Why is the 195-e2 any different?
If that's the expected career progression, then they have significant work to do to ensure pay and lifestyle also encourages that progression.
Why would a 3 yr e2 FO go DH8 capt to take a pay cut and work harder and have lower career earnings when they could go to AC?
MD11
Post by MD11 »
Grey_Wolf wrote: Mon Nov 25, 2024 3:42 pm IMHO, the E2 shouldn't be the FO's first ever Captain job.
If the pilot is skilled, hard working and responsible then why not? There are countless pilots at AC who's first upgrade is on an A220 or other narrowbody. The rest of the world start F/O's off on narrowbodies at 250 hrs and as they progress to senior F/O's an eventual upgrade on type occurs. On the other hand, I've flown with Captains who had more "experience" but questionable decision making and personalities which make you really involved in the flight deck for everyone's safety. It's a great time to be a young pilot and good training/attitude will provide a quality Captain candidate IMO.
Post by 8895 »
OR
This is just fear mongering fanfic porn for Q management….. right?
lowoleo22
Post by lowoleo22 »
8895 wrote: Tue Nov 26, 2024 12:48 pm
OR
1000hrs PIC on a Porter Dash is all you need for left seat E2.
Post by 8895 »
lowoleo22 wrote: Tue Nov 26, 2024 1:25 pm
OR
Sounds great when you leave the current flow rate out, doesn’t it :rolleyes:
braaap Braap
OR
More like 1000 Pic on the dash, 3500 total …and then the other 150 people in front of you to trickle over at 3/class until they move to a vacancy bid system at the end of 2025. Hope there are still seats left!
canadianfly
Post by canadianfly »
Any words of YHU base for Porter ??
Return to “Porter Airlines”
