required instrument acronyms
Apollo
Post by Apollo »
does anybody remember the acronyms for the required instruments and what they stand for?
I seem to remember one: Moofactar
M
O (OAT?)
O
F (Fuel indicators)
A (Altimeter)
C (Compass)
T (Timer?)
A (Attitude indicator)
R (Radio?)
but I definatly can't remember the night one. :(
Apollo
Post by Apollo »
Yay, foud it:
Manifold pressure guage
Oil temperature guage
Oil pressure guage
Fuel qantity indicators
Aairspeed indicator
Compass
Tachometer
Altimeter
Radiocommunication
and
Fuses
Attitude indicator
Tturn coordinator
Directional Gyro
Altimeter (sensitive)
Pitot Heat
Postion/anticollision lights
Instrument lights
Landing light (if carrying pax)
OAT guage
Vertical speed indicator
EchoNovemberAlpha
Post by EchoNovemberAlpha »
Sorry a bit new to these... :( When do you use these... :?:
Can understand the latter is for Night ops...but MOOFACTAR..??
Any acronyms for Inst checks on taxiing...
Lommer
Post by Lommer »
You use these on your flight test when the examiner asks you to list the required instruments from memory.
Hedley
Post by Hedley »
Ok, I found this:
http://www.tc.gc.ca/civilaviation/gener ... 9/menu.htm
But where does it say that you must have memorized all the CARs? Isn't that why we carry around the CAP GEN?
Apollo
Post by Apollo »
EchoNovemberAlpha wrote:Sorry a bit new to these... :( When do you use these... :?:
Like bar left, ball right heading indicator decreasing, compass free and swinging?
Then VOR/ADF/GPS?
EchoNovemberAlpha
Then VOR/ADF/GPS
Yep...that's what i was referring to...any acronyms for it..?
I know it's more or less the 'left to right/ top to bottom' thing on the standard instrument panel...but any acronyms or easy to remember tips..??
Cheers...
PS.."Bar left" :?:
Apollo
Post by Apollo »
or wings left - it depends on the turn and bank or turn and slip :P
Unfortunatly I don't have any acronyms for it though, sorry :(
Hedley
Post by Hedley »
You wanna do both a left turn and a right turn before takeoff.
I just go left to right across the panel, just like I do a pre-takeoff or pre-landing check.
My callout would be:
Left turn: "turn left, ball right, attitude indicator steady, heading decreasing, compass swinging, ADF increasing"
Right turn: "turn right, ball left, attitude indicator steady, heading increasing, compass swinging, ADF decreasing"
Note the turn right/left call is the same with both a turn co-ordinator (wings) and needle (turn and slip) because they both indicate the direction of yaw.
This really isn't as hard as you're making it out to be.
Right Seat Captain
Post by Right Seat Captain »
I was wondering why it's so important to say all that...rather than "Instruments showing correctly"
bob sacamano
Post by bob sacamano »
Hedley wrote:My callout would be:
But that is.
:smt109
Redneck_pilot86
Post by Redneck_pilot86 »
But that is.
Thats easy, its exactly the way I was taught.
And for MOOFACTAR, I think one O is OAT and one is Oil temp/pressure
ST
Nappy
Post by Nappy »
if you strip it the bare minimums, it is AACC = Airspeed ind., Altimeter, Compas, Clock. If you have an engine, you have to add tach, oil press and temp... appart from that, you don't need a manifold pressure gage nor radios if you're flying from an atf.
Aeros
Post by Aeros »
Nappy wrote:if you strip it the bare minimums, it is AACC = Airspeed ind., Altimeter, Compas, Clock. If you have an engine, you have to add tach, oil press and temp... appart from that, you don't need a manifold pressure gage nor radios if you're flying from an atf.
The clock is only required for power-driven aircraft too.
Nappy
Post by Nappy »
"The clock is only required for power-driven aircraft too"
I just looked through the cars... now section 605.14 for VFR powered flight says nothing for a time piece.. and actually neither does the others sections... so is it still required??
Aeros
Post by Aeros »
Nappy wrote:"The clock is only required for power-driven aircraft too"
Check CAR 602.60:
602.60 (1) No person shall conduct a take-off in a power-driven aircraft, other than an ultra-light aeroplane, unless the following operational and emergency equipment is carried on board:
(f) a timepiece that is readily available to each flight crew member;
Wasn't Me
Post by Wasn't Me »
This one always gets my passengers exited
O
H
S
H
I
T
I wish I could spell
trey kule
Post by trey kule »
Hedley wrote:
[quote]ADF increasing"[quote] or 'decreasing' as the case may be.
I must be having a brain fart, because for the life of me, I can not remember ever seeing that as a checklist item. Are you talking about an RMI or an HSI?
Seems to me it might be hard to get an ADF signal on the ground at some airports and that an increase or decrease would be dependent on the relative position of the plane to the station.
Explain this to an old guy will you.
Perhaps I misunderstood your original question also. Are these memory items, that is do you have to know all these nowadays for an exam or flight test? If it is so, does anyone have the reference for the standard requiring this bit of knowledge?
