angle of incidence
angle of incidence
I cant remember if the angle on incidence is the same as angle of attack or what the difference is. help
Angle of incidence is a permanent angle built into the plane; the chord line of the wing to the horizontal datum line of the aircraft. Angle of attak is the angle at which the wing meets the air (relative airflow).
"Young man, was that your landing or were we just shot down?"
Another thing to add is that the answer to your question, while reading French language documents depends on where the text was written/translated.
And now, the long drawn out answer:
French texts from Europe tend to use "angle d'incidence" as the angle between chord and airflow, while French texts from Quebec use "angle d'attaque" for the same. (You might also see the Greek letter alpha)
Depending on which term is used for the angle between chord and flow, I've seen "angle d'incidence" to refer to the angle between horizontal plane and chord, or, "angle de calage", also used while explaining prop pitch.
Goodbye,
Louis
Goodbye,
Louis
- tripleseven
- tripleseven
