AC Rouge 1693
AC Rouge 1693
Hi All…was witness to a very hard bounce and landing on RWY 32 today in CYOW (30Mar24). The aircraft hit and bounced at least 15’ back into the air and it looked they initiated a G/A and then levelled out and then came back down. Hope there were no injuries and the aircraft was OK. As I’m no Airbus pilot what is the protocol for a bounced landing, same as other transport aircraft? Thanks
Eric Janson
Re: AC Rouge 1693
Yes it is:-
- Re-establish the landing attitude if the bounce is not too bad.
- Go - around in case of a significant bounce.
I wasn’t there so can’t comment on the specifics of this flight.
Re: AC Rouge 1693
Thanks Eric…I’ve seen a lot of firm landings in my day, but never a bounce and up again of that magnitude. cheers
Re: AC Rouge 1693
First and second by the sound of it.
Accident speculation:
Re: AC Rouge 1693
An undercarriage absorbs unbelievable amount of weight during a bounce like that which reaches peak as a negative vertical velocity hits zero on an impact such as is described.
The lift to weight ratio then skyrockets (it’s all lift no weight for that second) at contact & even more lift is added to that if pitch likely increased pre-emptively pre impact in a negative vertical velocity. After impact all that new/free lift combines with upward force (same absorbed weight) coming off the suspension.
Re: AC Rouge 1693
Could you dumb that down a little for those of us who do not hold a PHD in Physics?
Re: AC Rouge 1693
haha, based on my super sophisticated CYPM knowledge he is saying planes are designed to bounce by way of design.
Re: AC Rouge 1693
If this touchdown also coincided with some extra thrust kicking in (like if some power was added to reduce a sink rate around flare) just as it bounces (still at flare AOA) … helps to “bounce” higher, but also ok position to flare again …lots of rwy left.a bounce and up again of that magnitude
Was fairly breeze day (20-30 mph) til later aft except the metar/anemometer record 2-3pm at both Ottawa airports show component reduced in that hour of approach .
Captain Kirkk
Re: AC Rouge 1693
Gear is toast. Plane is potentially written off as it is old.
Even my landings aren't that bad..
Video will be up Monday about it.
Kirk
Kirk
Re: AC Rouge 1693
Haven’t seen the video or heard about the plane being written off. Any more info?Captain Kirkk wrote: ↑Thu Apr 04, 2024 3:11 pm Gear is toast. Plane is potentially written off as it is old.
Kirk
