Flight attendants are only paid when the plane is in motion.
TCAS II
Post by TCAS II »
https://www.cbc.ca/news/politics/flight ... -1.7220150
I wonder if this is something being looked at for the pilots.
fish4life
Re: Flight attendants are only paid when the plane is in motion.
Post by fish4life »
TCAS II wrote: Sat Jun 01, 2024 9:26 pm https://www.cbc.ca/news/politics/flight ... -1.7220150
If I’m Air Canada tomorrow I’m going to the union and taking the annual salary of the FA’s dividing it by 2080 hours and giving them that as an hourly rate and paying them for every hour on duty.
yvrgoods
Post by yvrgoods »
Bingo.
I don’t think they realize the Pandora’s box they’re opening here.
RippleRock
Post by RippleRock »
yvrgoods wrote: Sat Jun 01, 2024 10:33 pm Bingo.
Exactly. They open it, they can deal with what comes out.
They need to look at their "total compensation package". We in aviation that work from "brake off to brake on" aren't really "hourly workers".
RippleRock
goingnowherefast
Post by goingnowherefast »
Brake off to brake on + 75 minutes (or whatever time they decide). Probably should vary with type, a CS300 boards and deplanes faster than a 777.
Would that be more reasonable?
Donald
Post by Donald »
When you are hired, you are shown the payscale (annual salary), and duties required.
You accepted employment on that basis.
Has the airline broken either of those commitments?
If you need more money, then by all means negotiate a raise. I think we all need more money these days. However, this tactic of "unpaid work won't fly" might result in the FA group being paid a lower hourly salary over more hours. And that lower hourly rate could impact things like their OT rate.
CaptDukeNukem
Post by CaptDukeNukem »
goingnowherefast wrote: Sun Jun 02, 2024 8:51 am Brake off to brake on + 75 minutes (or whatever time they decide). Probably should vary with type, a CS300 boards and deplanes faster than a 777.
Too complicated for cookie pushers
itsgrosswhatinet
Post by itsgrosswhatinet »
Are we sure their hourly wage for total time away from base wouldn't be below minimum wage? I saw 40 hour weeks assumed above. It's probably more like 75-80 hours per week they are away from home.
Safety starts with two
yvrgoods
Post by yvrgoods »
itsgrosswhatinet wrote: Sun Jun 02, 2024 10:17 am Are we sure their hourly wage for total time away from base wouldn't be below minimum wage? I saw 40 hour weeks assumed above. It's probably more like 75-80 hours per week they are away from home.
That’s not how it works
CaptDukeNukem
Yea. I don’t think TAFB counts as on duty.
yvrgoods
Post by yvrgoods »
FAs already have way better top ups than pilots. They need to stop complaining, and just try to negotiate a higher rate (they aren't up for contract until next year).
For example if they don't get min contract rest on layover (fall below 10 hours I think) then they get total duty from check in on day one to check out on day two minus 4 hours. Which can be insane pay top ups vs what they were originally blocked for, it's why so many FAs always ask for us to taxi slow and stuff. Even one minute delayed into their layover can trigger this massive pay claim. They know how to play the system.
Fanblade
Post by Fanblade »
In aviation our wages are pretty much double a normal hourly worker to make up for the time we work with no pay at all. A normal work month is 160 hours. We work full time at 80 flight hours. So our hourly wage is double.
If you cut your hourly pay in half that is pretty much a direct comparison to a normal hourly worker.
If you make $200/hour it’s really a $100/hour. If you make $50/hour it’s really comparable at $25.
A new FA makes $22-$23/hour. You cut that in half and it’s $11-$12/hour. Below minimum wage. Yet it’s not below minimum wage because the official hourly rate is $22-$23.
The company is taking advantage of them. The pay system is failing them.
How the FA’s deal with it is up to them. I would be inclined to stick with the current system and fix it. They appear instead to have decided to go after unpaid work as a strategy.
But I doubt anyone who understands the pay system would argue that below minimum wage is acceptable. Part of the problem is I don’t think they understand their own system.
itsgrosswhatinet
Fanblade wrote: Sun Jun 02, 2024 1:43 pm A new FA makes $22-$23/hour. You cut that in half and it’s $11-$12/hour. Below minimum wage. Yet it’s not below minimum wage because the official hourly rate is $22-$23.
I thought so. Good on them for trying for a raise. I'm concerned how many comments were negative against other workers. This doesn't bode well for outside support of our own negotiations.
Fanblade
Post by Fanblade »
itsgrosswhatinet wrote: Sun Jun 02, 2024 2:46 pm
No it's not helping them but ignore it and don't follow suit.
Most of the AC unions have forgotten how to be a union.
We can lead by example
newlygrounded
Post by newlygrounded »
Donald wrote: Sun Jun 02, 2024 9:24 am When you are hired, you are shown the payscale (annual salary), and duties required.
By that logic minimum wage shouldn't exist
newlygrounded
CaptDukeNukem wrote: Sun Jun 02, 2024 9:45 am
Why is it so hard to act like a professional?
TalkingPie
Post by TalkingPie »
There's quite a bit to unpack here, not the least of which being the terrible attitude of a minority of pilots towards their coworkers.
I'm of the opinion that the safest way to increase pay would be to leave the longstanding hour credit system in place and just raise the hourly rates. Developing a whole new pay structure would be incredibly complicated and would leave the door open for management to stack the deck in its favour. That said, the current "pay for boarding" campaign is making headlines and getting attention in political circles. Putting pressure on management in this way prior to negotiations is probably no bad thing!
It should also be pointed out that management dug this hole by whittling pay credit hours down so low that this is no longer a financially viable job for new hires. It's normal that people will clamour for change at this point. As others have said, management is abusing the system to effectively pay less than minimum wage. Most people look at their pay at the end of the month, and if the figure is acceptable to them, they won't stress much about the whys and wherefores of how that number was calculated. But if they feel screwed over, you'll get what is currently happening.
There's also an element of dishonesty in how the company advertises the pay. Pilots, having gone through training, made their way through the ranks of the first, second, and maybe third flying jobs before making it to a 705. By that time, they've most likely been informed about how how the flight credit hour system works. 18 year old flight attendants who see "$29/hour, training is paid at a lower rate" on the Air Canada job site might not have the context required to realize how bad a deal that is. By the time they're made aware, they're often already committed into training. Employees' fault for not researching and knowing better? Maybe, but as a company, having many of your new employees feeling duped isn't a great look.
Donald
Post by Donald »
newlygrounded wrote: Mon Jun 03, 2024 6:57 pm
Are FA's paid an hourly wage, or a monthly salary?
Me262
Post by Me262 »
Donald wrote: Mon Jun 03, 2024 8:17 pm
And are they also paid from brakes off / brakes on like us or a different start/end?
Donald
Post by Donald »
Me262 wrote: Mon Jun 03, 2024 9:03 pm
Not sure about you, but I'm paid a MMG.
Me262
Post by Me262 »
Donald wrote: Mon Jun 03, 2024 9:41 pm
You have a MMG but you get paid x amount of credits a day when you work, with a minimum for each of those days most likely. If you work more than the minimum, that's extra money in your pocket.
itsgrosswhatinet
The minimum wage is very important. Even in modern times slavery would be morally justifiable by MBA sociopaths.
newlygrounded
itsgrosswhatinet wrote: Tue Jun 04, 2024 3:13 am The minimum wage is very important. Even in modern times slavery would be morally justifiable by MBA sociopaths.
This is why I think the argument of "they know what they signed" doesn't entirely hold water. There is a reason you can't waive away your workers rights, because the employers have so much more leverage
NEBOJSA
Post by NEBOJSA »
Is this a Air Canada thing or is this industry wide.
Return to “Air Canada”
