E2 FO hiring
E2 FO hiring
dustyroads
Re: E2 FO hiring
As of me writing this reply the E2 First Officer position is on Porter Airlines careers page along with Dash 8.squawk2me wrote: ↑Tue May 20, 2025 7:24 pm Noticed that the E2 FO positions must be filled as they finally took down their ad, anyone happen to know if there is any planned hiring on the jet coming up? Was also wondering if it is just better to try and get in a Dash FO position to start. 2000 hrs and 800 multi turbine pic, wondering what the upgrade time on the Dash would be. Cheers!
Speedbrakes
Re: E2 FO hiring
I'm quite confident there will be a ground school every month for the next two years at least based on the amount of tails still to arrive. This is actually a slow year for deliveries and we're still doing a ground school every month.
Re: E2 FO hiring
Hello
Is Porter looking to hire E2 FOs for the remainder of the year and 2027? How much do FOs fly in a year? Are the newer FOs on reserve or can hold a block?
Thank you!
Thank you!
Speedbrakes
Re: E2 FO hiring
The latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
FOs flying 400-600 hours a year I believe. New hires can expect to be on reserve for a little while. I think 6-9 months now but I am happy to be corrected.
Orion's Fannypack
Re: E2 FO hiring
They still have an ad up for DEC Jet Captains, is that just filling a pool for the future?Speedbrakes wrote: ↑Tue Apr 21, 2026 7:58 amThe latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
Re: E2 FO hiring
They still have an ad for 2 bases that are about to close.Orion's Fannypack wrote: ↑Tue Apr 21, 2026 9:10 amThey still have an ad up for DEC Jet Captains, is that just filling a pool for the future?Speedbrakes wrote: ↑Tue Apr 21, 2026 7:58 amThe latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
Have Pratts - Will Travel
Re: E2 FO hiring
Is there a rough timeline between application submission to ground school start date?
Re: E2 FO hiring
Last year it was under 3 months. Who knows now… supposedly external hiring is set to resume for the E2 shortly but there’s probably quite the candidate pool now.
Re: E2 FO hiring
Finger crossed it happens sooner rather than later, and within a reasonable timeline.
markpilote
Re: E2 FO hiring
Wondering how reserve works at PD:Speedbrakes wrote: ↑Tue Apr 21, 2026 7:58 amThe latest from the company was no outside hiring for 2026 but I suspect that won't be (and probably already isn't) the case. I suspect there will be some outside hiring.
- if everyone regardless of seniority does a few reserve days reserve very month, or is it a full-month for the most junior
- if there is a minimum call-out time they have to give
Speedbrakes
Re: E2 FO hiring
Once you can hold a line you don't do reserve unless you bid for it. The minimum call-out is two hours.
Re: E2 FO hiring
Full-month for the most junior.markpilote wrote: ↑Sat May 23, 2026 1:57 pm Wondering how reserve works at PD:
Minimum call-out 2 hours.
Working rules for reserve aren't great atmo, lots of extensions, nothing is protected, you're essentially the company's slave during your RSV string. Hopefully we see some improvement on our first ever negotiated contract.
Re: E2 FO hiring
For line holders in general, how many days of work are being scheduled per month? Is there the option to drop or trade shifts ? Also is it easy to have a schedule where half of the month is scheduled work and the other half is off?fliter wrote: ↑Sat May 30, 2026 4:47 pmFull-month for the most junior.markpilote wrote: ↑Sat May 23, 2026 1:57 pm Wondering how reserve works at PD:
