CPL Flight Test Study Sheet
SpitfireMustang
Post by SpitfireMustang »
Hi folks. Brand new on here and currently in MIFR. But I took so much good information from AvCanada that I thought I would give back. I've attached my CPL study guide (based on Cessna 172).
It includes everything from V Speeds (model m, n, r), Va information, weight and balance, systems, airworthiness and documents, recency, emergencies, privileges, airspace, and some CFS stuff. Its definitely not perfect, but basically includes most things that I got tested on in the CPL ground of the Flight Test
Hopefully it's helpful to some people.
Look forward to seeing you in the skies. Now to find a job next month haha
CPL Oral Exam.pdf
(274 KiB) Downloaded 111 times
careerpilot?
Re: CPL Flight Test Study Sheet
Post by careerpilot? »
Nice work!
Here's one to help you out on your MIFR. The aircraft specific stuff is for a DA62.
Standard disclaimer: Confirm all info with applicable references before using!
DA62 IFR.xlsx
(40.58 KiB) Downloaded 31 times
