True Story
mantogasrsrwy
True Story
Post by mantogasrsrwy »
MACH83
Re: True Story
Post by MACH83 »
From the beginning of time, Captains have complained about FOs, and FOs have complained about Captains.
mantogasrsrwy
Re: True Story
Last edited by mantogasrsrwy on Tue Oct 13, 2026 4:00 am, edited 2 times in total.
mantogasrsrwy
Re: True Story
BTD
Re: True Story
Post by BTD »
I still don’t get doing the journey log in the climb. If it is a long leg, do it in cruise, if it is short do it at the gate at the end of the flight.
As to the story; yeah, what is the purpose of VS in that situation anyway. IAS is paramount. Do it in FLCH(Vnav speed window open) or Open Climb or whatever is on the aircraft type and bug the speed you want. Either Mach or IAS. If you are trying to climb over set best rate or even best angle if necessary.
nohojob
Re: True Story
Post by nohojob »
Best Time to put the off time in the logbook is right after the positive rate call. This way you are sure to have the accurate time since sometimes the FMC is not accurate.
AV80R
Re: True Story
Post by AV80R »
I like to do it as we are approaching towering cumulus because it's a fun challenge to try to print straight in turbulence.
Passing you in my Tesla
yycflyguy
Re: True Story
Post by yycflyguy »
Crazy idea, but how about avoiding it laterally instead of trying to top a CB where the turbulence above the top can extend another couple of thousand feet. If there's that much time to mess with the climb, someone should have keyed the mic and requested a deviation.
Tbayer2021
Re: True Story
Post by Tbayer2021 »
What a bunch of amateurs. If you can't fill out the journey log while on a hand flown CATIII just turn in your license. Climb out and cruise are strictly for complaining about the contract, showing off the latest boat, car, cottage and maybe your new gf thats 30 years younger.
‘Bob’
Re: True Story
Post by ‘Bob’ »
BTD wrote: ↑Thu Sep 25, 2025 11:47 am I still don’t get doing the journey log in the climb. If it is a long leg, do it in cruise, if it is short do it at the gate at the end of the flight.
Because FLCH is slow AF to start doing anything. Pro tip.. if ATC asks you to climb and to expedite it for traffic .. don’t use FLCH.
VS is fine to initiate. But don’t keep it there and switch to IAS/Mach as appropriate at the proper attitude (remember what that is?) for a sustainable climb. Switching over right at the anticipated or required IAS/Mach will result in a roller coaster because the attitude will probably be too high.
BTD
Re: True Story
Post by BTD »
‘Bob’ wrote: ↑Thu Sep 25, 2025 3:22 pm
Pro tip, we aren’t talking about ATC requesting expedited climb.
Pro tip, different aircraft types will initiate climbs in flight level change differently. (Boeing are pretty slow, Embraer and the 220 are pretty snappy iirc.)
Pro tip, in the example, they are already climbing, and not initiating from level flight. Even Boeing is quick enough.
Pro tip, switching in and out of Vnav is making a lot of work which is why I said (Vnav speed with window open for Boeing) and would be a point of discussion I would have as a training and check pilot. Not wrong just a discussion.
Re: True Story
A climb is a higher area of vulnerability than cruise, especially with build ups and an inexperienced FO. Maybe time to re-think when you chose to do paperwork or otherwise go heads down?
Eric Janson
Re: True Story
Post by Eric Janson »
mantogasrsrwy wrote: ↑Thu Sep 25, 2025 2:26 am I'm generally laid back. But a 2000 fpm VS climb to the yellow band will elicit a comment from pretty much any captain.
Nothing in the SOP about this?
If nothing in the SOP- then it should be covered in Line Training.
yycflyguy
Re: True Story
Post by yycflyguy »
Eric Janson wrote: ↑Wed Oct 01, 2025 12:22 pm
SOPs can't cover every scenario. I agree that I would be saying something as well watching a colleague pull all the energy out of the aircraft in a V/S climb. If you make the altitude without carrying any energy it also takes forever for the plane to accelerate to your cruise speed. It's a mismanagement of the situation.
BrianLarson
Re: True Story
Post by BrianLarson »
When you're in a thrust-limited climb, managing your vertical speed is a smart way to control your speed, especially as you approach or exceed Mach. For jets, just set your climb thrust, maintain your speed or Mach (whether it's managed or selected), and let the rate of climb do its thing. If you need to get above the weather, consider asking for a speed boost, a quick deviation, or a step climb—just don’t get too fixated on the vertical speed indicator. A clear communication helps: “Speed mode for the climb.” If you do use vertical speed, make sure to set a conservative cap with a solid speed floor (like “no lower than .74/280”). This way, you can keep climbing without stalling out at 0 feet per minute.
PostmasterGeneral
Re: True Story
Post by PostmasterGeneral »
I try and get the logbook done well below 10,000’ that way I can monitor things like this much better.
lostaviator
Re: True Story
Post by lostaviator »
I usually do the logbook prior to departure. It makes it much easier for me to watch over FO's and tell them things like "the company doesn't like it when..." and "we aren't supposed to use that mode".
With acars uplinking times right to the maintenance control software, the paper version is just there to make me feel important. However, I have learned to leave the destination field blank on the last leg of the last day until I actually set the brake at home. Bad luck.
Joking aside. We all had to learn at some point. May I suggest banging your head and going back to paperwork, then running to your hotel and logging onto avcan to vent isn't the best way to mentor a colleague.
PostmasterGeneral
Re: True Story
lostaviator wrote: ↑Wed Oct 22, 2025 5:09 am I usually do the logbook prior to departure. It makes it much easier for me to watch over FO's and tell them things like "the company doesn't like it when..." and "we aren't supposed to use that mode".
You can't mentor these guys (and gals) anymore. They all have it figured out already, and need no help or advice from anyone.
mantogasrsrwy
Re: True Story
mantogasrsrwy wrote: ↑Wed Sep 24, 2025 7:29 pm .
Re: True Story
Don't even see the first post with details.
FLCH works just fine in Boeings, from my experience(although I can't speak for all types). If it is climbing slowly, there is probably a good reason.
If ATC says expedite for traffic and you can't climb quickly, say Unable(or make sure they know it will not be a fast climb). If you climb very quickly to start above optimum altitude, you will probably finish the climb extremely slowly.
northernpilot2
Re: True Story
Post by northernpilot2 »
PostmasterGeneral wrote: ↑Tue Oct 21, 2025 9:42 pm I try and get the logbook done well below 10,000’
The logbook can be done after you arrive at the gate and shut down. What's the hurry? From time to time I see too many idiots (not you) trying to rush the logbook with other busy things going on while in the air. Just relax, prioritize essential duties FIRST.
Re: True Story
I don't see the original story, vut can imagine... climbs at altitude shouldn't be managed with vertical speed (except to maybe finesse the last 500 or 1000' with traffic proximate, but even then). VNAV with window open as needed or FLCH. If you find FLCH slow, push the levers to climb N1 yourself, don't wait for the autothrottle to figure it out.
You want reference N1 and airspeed, not vertical speed which will not necessarily give you the thrust you need and will dangerously deplete your airspeed to give you vertical rate. Don't get behind that drag curve.
mantogasrsrwy
Re: True Story
altiplano wrote: ↑Wed Nov 11, 2026 12:10 pm I don't see the original story, vut can imagine... climbs at altitude shouldn't be managed with vertical speed (except to maybe finesse the last 500 or 1000' with traffic proximate, but even then). VNAV with window open as needed or FLCH. If you find FLCH slow, push the levers to climb N1 yourself, don't wait for the autothrottle to figure it out.
That was the point of the original post. But everyone around here thought it was more dangerous having the logbook out through fl300 than climbing at 2500 fpm in vertical speed through fl300 with the speed rapidly bleeding off, so I deleted it.
Re: True Story
2500 fpm at altitude is pretty ambitious, maybe unless you're light and in something with some serious jam behind it.
I shudder every time someone hits VS, even on descent, FLCH protects your speed and the set your thrust to get the rate you want.
Me262
Re: True Story
Post by Me262 »
altiplano wrote: ↑Wed Nov 11, 2026 1:22 pm 2500 fpm at altitude is pretty ambitious, maybe unless you're light and in something with some serious jam behind it.
We don't all have autothrottle
