Wind shear pop quiz.
Doctor Evil
Post by Doctor Evil »
You are on final in your Be200(or other light twin).Gear and flaps are down.Suddenly you encounter windshear and are heading for the ground like a homesick brick.What do YOU do??? :twisted: :twisted:
mellow_pilot
Post by mellow_pilot »
power...power...WAVE OFF!!!!
bandit1
Post by bandit1 »
1- stick your head between your legs
2- kiss your ass good bye
C-GPFG
Post by C-GPFG »
Firewall the power, nose to stall warning, leave gear and flaps down.
Sulako
Post by Sulako »
Yeah what he said. Push all the levers full forward and raise the nose to just below the stall. If/when you start climbing, then deal w. your drag.
Out of Control
Post by Out of Control »
Whip it out start jackin.
Say again, your coming in stupid
C-GPFG
Re: Wind shear pop quiz.
Post by C-GPFG »
Doctor Evil wrote:You are on final in your Be200(or other light twin).Gear and flaps are down.Suddenly you encounter windshear and are heading for the ground like a homesick brick.What do YOU do??? :twisted: :twisted:
Got that question on an exam or something?
Does it matter if it's a twin or single?
Clodhopper
Location: Wishing the only ice I saw was in my drinks...
Post by Clodhopper »
No, typically you just want to avoid adding excess drag, or reducing your amount of total lift. Retracting the gear will first make the doors open up, adding drag. Retracting the flaps reduces drag, but also reduces efficiency of the wing at slow speed.
In much larger airliners, the gear can take upwards of 20 seconds to fully retract, which really puts you behind when trying to overcome windshear. Add in the fact that there are huge doors that open up to accept the gear on those aircraft...
a.k.a. "Big Foot"
C-GPFG
Post by C-GPFG »
I agree and would do the same procedure in the 172. Just wondering why "light twin" was specified in the question.
Dusty 3
Post by Dusty 3 »
Push the nose over and give up.
Doctor Evil
I only specified "light twin" because I wanted to get info for this general type of aircraft.I wasn't too concerned with either a 172 or a 747.That's all.
xsbank
Post by xsbank »
Call "max thrust" rotate to stick shaker and fly it out - NO cleanup 'til VERY positive VSI (don't overspeed the gear).
(Stick shaker gives you 'about' 7 knots warning depending on type - just tickle it).
If you do contact the ground you are at your lowest speed and a very nose high attitude so you might just survive it...
invertedattitude
Post by invertedattitude »
Clodhopper wrote:No, typically you just want to avoid adding excess drag, or reducing your amount of total lift. Retracting the gear will first make the doors open up, adding drag. Retracting the flaps reduces drag, but also reduces efficiency of the wing at slow speed.
what about the 737? No loss in retracting gear on that puppy.
C-GPFG
Post by C-GPFG »
727 is gear down until clear of the shear...is the 737 gear much different?
flyincanuck
Post by flyincanuck »
[Edit]
Disregard.
Blue Side Down
Post by Blue Side Down »
Doctor Evil wrote:...heading for the ground like a homesick brick.What do YOU do???
Flare when the treetops begin to really bother your FO... air can't go down forever- you'll run into 'ground effect' sooner or later. :lol:
oldtimer
Post by oldtimer »
Go to max power and on the stick shaker. Leave the gear and flaps as they were. This is what we were taught and practiced in the G159 Gulfstream sim.
Driving Rain
Post by Driving Rain »
Max power nose up until the AOA tickles the barberpole.
