And does that mean that the 12 months timer doesn't apply to me once I get my ATPL license saying “Skill test does not meet ICAO requirements.”? I have a license after all, it's just restricted? So essentially the the written exams don't expire if you meet all the other requirements (1500h TT, 100h night etc)421.34(6) Restricted Licence
(a) Where the applicant has not completed the skill test in an aeroplane required to be operated with
a co-pilot as specified in subsection (9), the licence shall be issued with the remark, “Skill test does
(b) Where the applicant completes the skill test in an aeroplane required to be operated with a copilot as specified in subsection (9), upon request to the Minister the remark shall be removed from
the licence.
New Text 421.34(5) Skill
(a) Within the 12 months preceding the date of application for the licence, an applicant
shall demonstrate in flight or in a level C or D full flight simulator, and on the
ground, familiarity with and the ability to successfully perform, as pilot-incommand of a multi-engine aeroplane (with no central thrust configuration)
required to be operated with a co-pilot as defined in subsection (9), and fitted with
7
instruments and equipment suitable for two crew IFR flight in controlled
airspace:
(i) both normal and emergency flight procedures and manoeuvres
appropriate to the aeroplane in which the flight test is conducted and
to successfully execute all manoeuvres and procedures set forth in
Division XIV for issue of a Group 1 instrument rating.
(ii) a Pilot Proficiency Check (PPC) for operations under IFR in
accordance with Part VII; or
(iii) a Pilot Proficiency Check (PPC) or Pilot Competency Check (PCC)
for operations under IFR in accordance with Subpart 604 conducted
by a person designated by the Minister to conduct the flight test
Link to Notice of Standard Ammendment:
https://wwwapps.tc.gc.ca/Saf-Sec-Sur/2/ ... x?id=12950
