Instrument rating training in actual IMC
Posted: Mon May 11, 2026 5:48 am
Are there any schools that conduct training towards the instrument rating in actual IMC?
I think this is pretty much it. Heck even our military flying around the prairies, winter IFR is out for icing and summer IFR can be sketchy with convective activity. Even we have no icing equipment or weather radar. The "IFR equipped machines" at most flight schools have some very nice / new Garmin boxes that can fly an LPV, but are still coupled to old DGs that precess 10 degrees every 10 minutes, ADIs that don't hold level very well, and forget about de-ice or weather radar.digits_ wrote: ↑Mon May 11, 2026 5:33 pm I don't know of anyone actively avoiding it. It's just that more items need to line up to make it consistently happen. The prairies are generally out: in winter you have the constant freezing conditions in cloud. In summer weather is usually good, except for thunderstorms.
Coastal areas might have IMC conditions where you don't want to fly a single piston in. Many years ago a school wanted at least 500ft agl for IFR training, to at least give you a fighting chance if your engine decided to quit. Then there's the issue of currency for the instructors (not just legally but also practically). And maintenance for the aircraft. An old instrument that 'sort of' works is borderline ok to play around with in VMC but not IMC.
I always did actual IFR when I did IFR's. Apparently, it common practice, including at a large volume IFR school in Ontario for the minimum clouds to be 500' above the PT altitude so that they don't run the risk of going in cloud.DanWEC wrote: ↑Mon May 11, 2026 3:37 pm Are there those that don't, as a practice?
Back when I was our school's MIFR guy I did all the time, and that was just business as usual. It was great never being constrained by VFR, so we were able to fly virtually every day as long as our finicky airplane wasn't grounded.
Are the Prairie's bad for icing in the winter? It's freezing cold in the winter. Very little moisture and no super cooled water. In my area (NWO), winter IFR has very little ice. Fall on the other hand...careerpilot? wrote: ↑Tue May 12, 2026 6:47 am I think this is pretty much it. Heck even our military flying around the prairies, winter IFR is out for icing and summer IFR can be sketchy with convective activity. Even we have no icing equipment or weather radar.
This seems bizarre. Is this perhaps a typo? (did you mean 500ft above PT?) But even then it's definitely a sad policy....
Not really, but if the GFA is forecasting their standard potential for icing, it's hard to justify as an FTU to go into clouds.
Pretty much what digits said, we often debate what “forecast” icing is, but the most conservative interpretation generally is any visible moisture above the freezing level.Bede wrote: ↑Wed May 13, 2026 6:45 amdigits_ wrote: ↑Mon May 11, 2026 5:33 pm I don't know of anyone actively avoiding it. It's just that more items need to line up to make it consistently happen. The prairies are generally out: in winter you have the constant freezing conditions in cloud. In summer weather is usually good, except for thunderstorms.Are the Prairie's bad for icing in the winter? It's freezing cold in the winter. Very little moisture and no super cooled water. In my area (NWO), winter IFR has very little ice. Fall on the other hand...careerpilot? wrote: ↑Tue May 12, 2026 6:47 am I think this is pretty much it. Heck even our military flying around the prairies, winter IFR is out for icing and summer IFR can be sketchy with convective activity. Even we have no icing equipment or weather radar.
I think it depends on circumstances. If there is no convective activity, and the ASEP shows no risk of icing, and you can safely duck beneath the clouds if you do end up with any icing, I think it is safe to go above the freezing level in IMC. Obviously if you don't do your due diligence it can go badly wrong.careerpilot? wrote: ↑Wed May 13, 2026 4:42 pm Pretty much what digits said, we often debate what “forecast” icing is, but the most conservative interpretation generally is any visible moisture above the freezing level.
I don't disagree. However, with the GFA note of "trace/light icing in cloud above freezing level", it's probably correct to interpret any visible moisture above the freezing level to constitute forecast icing... I'm simply outlining some of the more conservative interpretations that are often used at the flight school level, and even by some operationally. I didn't necessarily say I agree with itCpnCrunch wrote: ↑Thu May 14, 2026 10:08 amI think it depends on circumstances. If there is no convective activity, and the ASEP shows no risk of icing, and you can safely duck beneath the clouds if you do end up with any icing, I think it is safe to go above the freezing level in IMC. Obviously if you don't do your due diligence it can go badly wrong.careerpilot? wrote: ↑Wed May 13, 2026 4:42 pm Pretty much what digits said, we often debate what “forecast” icing is, but the most conservative interpretation generally is any visible moisture above the freezing level.
https://www.tsb.gc.ca/eng/rapports-repo ... w0027.html
The correct limitation is "known icing", not forecast icing.careerpilot? wrote: ↑Thu May 14, 2026 10:57 am I don't disagree. However, with the GFA note of "trace/light icing in cloud above freezing level", it's probably correct to interpret any visible moisture above the freezing level to constitute forecast icing... I'm simply outlining some of the more conservative interpretations that are often used at the flight school level, and even by some operationally. I didn't necessarily say I agree with itWhether it's safe or legal to fly in forecast icing is another debate.
Because there's a competing forum with that in it's name.careerpilot? wrote: ↑Thu May 14, 2026 10:57 am Side note - why does the avcanada language filter remove scu(d) but not the F word (which I've seen in other recent posts)?
Is it? CAR 605.30 specifically mentions forecast icing:Bede wrote: ↑Mon May 25, 2026 8:09 amThe correct limitation is "known icing", not forecast icing.careerpilot? wrote: ↑Thu May 14, 2026 10:57 am I don't disagree. However, with the GFA note of "trace/light icing in cloud above freezing level", it's probably correct to interpret any visible moisture above the freezing level to constitute forecast icing... I'm simply outlining some of the more conservative interpretations that are often used at the flight school level, and even by some operationally. I didn't necessarily say I agree with itWhether it's safe or legal to fly in forecast icing is another debate.
One could argue the "unless the PIC determines the aircraft is adequately equipped... statement provides the PIC some lattitude, but I'm not sure how much scrutiny it would actually hold up to...De-icing or Anti-icing Equipment
605.30 No person shall conduct a take-off or continue a flight in an aircraft where icing conditions are reported to exist or are forecast to be encountered along the route of flight unless
(a) the pilot-in-command determines that the aircraft is adequately equipped to operate in icing conditions in accordance with the standards of airworthiness under which the type certificate for that aircraft was issued; or
(b) current weather reports or pilot reports indicate that icing conditions no longer exist.
That's hilarious.Because there's a competing forum with that in it's name.careerpilot? wrote: ↑Thu May 14, 2026 10:57 am Side note - why does the avcanada language filter remove scu(d) but not the F word (which I've seen in other recent posts)?
I think the latitude is in the forecast itself. The "NIL-LGT RIME ICGIC ABV FZLVL UNLS NOTED" is just a catchall, but if you look at the ASEP forecast it will give a more detailed icing forecast along the planned route.careerpilot? wrote: ↑Mon May 25, 2026 11:01 am
I stand corrected. I would still argue that the nil-light in a GFA does not constitute a forecast of icing.careerpilot? wrote: ↑Mon May 25, 2026 11:01 amIs it? CAR 605.30 specifically mentions forecast icing:Bede wrote: ↑Mon May 25, 2026 8:09 amThe correct limitation is "known icing", not forecast icing.careerpilot? wrote: ↑Thu May 14, 2026 10:57 am I don't disagree. However, with the GFA note of "trace/light icing in cloud above freezing level", it's probably correct to interpret any visible moisture above the freezing level to constitute forecast icing... I'm simply outlining some of the more conservative interpretations that are often used at the flight school level, and even by some operationally. I didn't necessarily say I agree with itWhether it's safe or legal to fly in forecast icing is another debate.
I tend to agree. This is where much of the debate lies! Some take the more conservative approach, some don’t. I believe flight schools tend to err on the conservative side when it comes to training in actual.Bede wrote: ↑Mon May 25, 2026 6:15 pmI stand corrected. I would still argue that the nil-light in a GFA does not constitute a forecast of icing.careerpilot? wrote: ↑Mon May 25, 2026 11:01 amIs it? CAR 605.30 specifically mentions forecast icing:
Are you punching through a layer, or going to be in it for the duration of the flight? If the duration will be relatively short, can the PIC decide IAW the CAR that the aircraft is adequately equipped given this definition? I think when it comes to forecast light icing, there is some leeway to be had.The rate of accumulation may create a problem if flight is prolonged in this environment (over 1 hr)
