Jazz Sim
- PeteThePilot
As long as you knew where you were, followed as best you could the profiles they gave you, and did try to correct your mistakes, you should be ok. There is of course the exception to every rule.
The biggest thing there looking for the ability to have a beer with you after 12 hours of sitting beside eachother.
Chase lifestyle not metal.
- PeteThePilot
- Flying Low
Word of advice for those doing the Dash 8 sim eval.
Listen to the briefing before hand and fly power/attitude. When I did mine the instructor/evaluator told me what to expect in terms of pitch attitude and power settings for cruise and steep turns. It worked remarkably well.
Qwert, The sim is just like a typical ride, but less intense. You'll take off, do a couple steep turns, get cleared to the beacon and get a hold clnc. After that you'll get vectors for the straight in NDB approach, you'll overshoot, get an engine fire, shut it down and get vectored for the ILS. Pretty simple.
Before you get in the sim you'll have about 45 minutes to look over the plates and speed/power settings they want you to use. The guy that sits in the other seat is helpful calling deviations, doing checklists and shutting down engines for you.
Hope this helps, good luck.
GearBay Overheat
