Flight schools in Northwestern Ontario
Can you guys tell me some of the schools here in NW Ontario? The one that was here in Thunder Bay has apparantly closed up shop, and now there is no where I can go to see if piloting peaks my interest.
I would prefer in and around Kenora, seeing as I have family there aswell.
Maybe they have some float places around there who knows...
Thanks,
-Dave
Thanks,
-Dave
- Buschpielot
If your set on Northwestern Ontario then there aren't that many options this time of year. In South Eastern Manitoba there is Harv's Air that can take you all the way from PPL to Multi IFR. If your full-time it will take about a year and a little bit with hard work to complete your training
Having trouble reaching ATC? Squak 7500
Just make sure you're getting quality training. It may be tempting to stick in Kenora but if the guy's a hack (not saying he is, I'm unaware of him), it'll be detrimental to you in the long run. Quality training should be your number 1 priority, not so much location, just ask Cat Driver.
- mikegtzg
There is a little brown building on the right hand side as you drive in. And just in front of the new Navcanada bldg. in Kenora that says they do some flight training. I don't know the person...but apparently someone is available.
After reading the last comment. I think this thought should also be considered. No matter who you get for your initial pilots licence training. As long as you both communicate well. The basic training syllabus for flight schools is mandated by TC rules. Most flight instructors are going to be fairly competent to provide the sense of security and awareness required to maintain student confidence. But initial training is just the beginning. Ask any pilot that has been flying for years. And they will likely tell you that they learned more about flying in the subsequent 100, 200, 300, etc hours of PIC. Then they knew when they just got there licence.
At some point in the flight training. The influence of an exceptional flight instructor surely is a benefit. But not likely during the early stages of ab-initio.
Northwestern Ontario - What exactly is Northwestern Ontario anyway? Being from Manitoba, I would consider it anything west of T-Bay. However I know some people from Toronto who consider it anything north of Barrie and west of the 400. Only in Toronto, I guess.
If you are willing to go as far west as Kenora, then you should look at Harv's. They are in Steinbach, only about 1 1/2 hr west of Kenora.
Toronto is probably the most expensive place for flight training around here. And not only is everything more expensive, you've almost certainly got a long flight to the practice area and back.
In the winter, I'd suggest Florida for flight training, esp with the new complete licence reciprocity between the DOT and the FAA. In the late spring and early fall, I'd look at Harv Air in MB. And in the furnace heat of the summer, find someplace near a large body of water to moderate the temp, but beware of the fog!
