Cheep Multi Engine rating
Hi all
I am looking for cheep ME rating around canada
any suggested school , and how long does it take normaly if i do it full time
thanks
thanks
Multi Engine Rating does not have minimum time requirements. It doesn't have a lot of exercises to do and it's more about procedures. So the cost of the rating varied depending on your effort to study and how well you are flying.
I've seen people get the rating with about 2 hours on the multi and some in the sim. while some others needed 20 hours.
- Cat Driver
- Cat Driver
What do you find is the biggest problem they have learning to fly a basic twin engine airplane?
Most of the proceedures can be learned sitting on the ramp or in the hangar.
- Elessar_44
Problem is, the multi can be the first time a student has seen:
1) constant speed prop
2) retractable gear
3) fuel injection, cowl flaps
4) HSI, RMI, DME, IFR GPS, etc
then you go on to the whole engine-out drill, fuel system, janitrol heater, etc.
If the student has seen #1 through #4 on a single before, a "multi" endorsement shouldn't take very long - just type famil & engine-out drill.
2) retractable gear
Multi
If you already have the knowledge the rating should take between 5-10 hrs. Review constant speed prop theory, mechanical workings and operation and you should be ok.
Just think of it as a type check. The airplane will still fly the same way... you just have to manage one more engine and know what to do if one or both engines are not working.
good_idea
good_idea
- Cat Driver
- Cat Driver
Excellent advice.Get an experienced instructor. Knowing how to do something and knowing how to teach it are two different things.
Just don't get confused by thinking the term " instructor " means that the person training you must hold a " Flight Instructors Rating "
There are many pilots avaliable who are excellent teachers who no longer have or never did have an instructors rating.
It is no different than any other service you pay for, all you need do is check the background and reputation of the person whom you hire to teach you......
So bottom line is look for the best you can find with or without the " Flight Instructor Rating "
Doc wrote:
It was superb advice on several of your parts, to recommend getting someone with experience.
As to the instructing part, many of us, myself included, held instructors ratings years ago, and in the interim have become CP's or line check pilots, or training pilots, or had training in the military with regard to instructing.
to make the claim, as one poster did, that you should get only an instructor is ridiculous.
It is obvious to me, by some of the posts here, and from some of the things I have seen around FTU's that it actually may be difficult for some of those instructors. It is also obvious to me, from what I have seen coming out of the FTU's that instructors are either milking the students, or really dont know exactly what it is they are trying to achieve and so waste alot of time. One case I heard about from a new pilot two years ago....the first lesson they just taxied around the airport to learn about asymetic thrust in the turn....I am not making this up. 0.7 hrs of "flight time" and they never left the ground. The only reason they stopped was that the student finally got mad and complained.Lets try and make it look difficult.
Good point. But the student would be wise to find someone with some sort of educator training, current or not. Teaching is like flying; when its done well it looks easy enough that anyone can jump right in and do it, when in fact it's an art whose finer points require some mentoring to pick up.Just don't get confused by thinking the term " instructor " means that the person training you must hold a " Flight Instructors Rating "
- Cat Driver
Exactly,once again I agree with some of what you say.Good point. But the student would be wise to find someone with some sort of educator training, current or not. Teaching is like flying; when its done well it looks easy enough that anyone can jump right in and do it, when in fact it's an art whose finer points require some mentoring to pick up.
Just bear in mind holding a Canadian flight instructors rating is not proof that you are a top notch teacher, I wouldn't have a hope in hell of passing even the class 4 written or flying tests with TC. But I do consider myself to be an excellent teacher of flying.
When searching for a top notch instructor one of the best methods of determining the quality of their instruction is the pay per hour they receive and will they give you contact information with their former students so you can get their recommendation.
The top instructors command top money.
I do quite well in that department.
- fingersmac
- fingersmac
It was $322 for the airplane and instructor after tax ($253 + $50 + GST).
http://www.pro-flight.on.ca/main.html
Ok, I'll bite...
"Instructor Ratings" don't make the instructor. But they do save cash on the CPL requirment.
I had a student come in yesterday who had 30 hours of dual float time. He has no asperations for an ifr and wants his commercial license signed off. Unfortunatly he needs about 15 hours 'dual' from a licensed instructor to have the 35 needed on the cpl. He needs about 14 hours of instrument also. This means we are doing all of his instrument time in the aircraft instead of the sim. So he cost himself about 1600$ because of the 'non instructor rated float instructor'.
(although his float instructor was an awesome teacher, so I'm sure he learned a lot. But because the guy doesn't have a rating, it's costing the students)
Just have a conversation with the instructor. Ask how long they have been doing it. Subtly ask what class of instructor they are (I know this doesn't matter, but I wouldn't want someone as new as a class 4 in a plane costing me +300/hour).
Someone with industry experience is great, but it may just mean 500 hours of multi cruise flying.
ptp
ptp
- Cat Driver
And conversely with a certified flight instructor you may get someone who has never been inside a cloud.Someone with industry experience is great, but it may just mean 500 hours of multi cruise flying.
Yes, that is true, and it just shows how abysmally stupid the rules are.(although his float instructor was an awesome teacher, so I'm sure he learned a lot. But because the guy doesn't have a rating, it's costing the students)
Anyhow this instructor thing is a no win for some of us who are unable to get one because we don't fit the TC mold of getting on our knees and submitting to TC's flight training inspectors.
