1900 Gear Up
1900 Gear Up
Was watching the news this mornin' - and what would you know it, first thing I see is 1900D doing the electric slide down some runway.
http://www.nzherald.co.nz/section/1/sto ... d=10446360
http://www.thewest.com.au/aapstory.aspx ... ame=392309
Can't find the video yet.
The 1900 is probably the best aircraft to belly-up since the wheels always poke out of the wheel wells, even when the gear is up and locked (designed that way).
"Flaring is for sissies. I've flown both onspeed and flared approaches....and I'd take onspeed anyday."
(Excerpt from a Naval Aviator web Forum)
It may be the Queens english but some versions are a little different. It is a big world out there.ei ei owe wrote:From the report. "A witness said it landed on its belly and was immediately met by fire appliances and sprayed with foam."
WTF.....a fire appliance?![]()
I've got lots of appliances but none of them for fires. Maybe the BBQ?
[/quote]The New Zealand Fire Service has:
348 fire districts (urban)
436 fire stations
800 fire appliances (approx)
- Cat Driver
Words mean different things in different countries, for instance if you were driving down a street in south Africa and saw a red robot ahead of you what would you do?
- VeRmiLLioN
Good job for the pilots getting it down in one piece. now hopefully they can fix her back up again. Too bad they couldn't shut off the engines before they landed like that king air 100 landing in the states.
http://youtube.com/watch?v=VVmHyJMDcus
Had they shut down, the props would be gone to composite heaven and the Pratts would still require a teardown.Too bad they couldn't shut off the engines before they landed
The only benefit I see to shutting down would be to lessen the chance of a blade going through the fuselage (mind you composite blades are fairly light and shatter so there's less energy than say a metal blade fracturing at the hub).
Either way the dammage would be greater than the deductible so it's a bit of a mute point.
Follow SOP's.
I am not sure where you are getting your info. The engine front section may require inspection at most, not tear down or rebuilding. The blades would be inspected and likely flying the next day. If you want to be around for that kind of explosion when blades hit the pavement under power, make it your problem. I have yet to see a company that issues an sop for a gear up landing.Big Pratt wrote:Had they shut down, the props would be gone to composite heaven and the Pratts would still require a teardown.Too bad they couldn't shut off the engines before they landed
Follow SOP's.
You will never live long enough to know it all, so quit being anal about it..
Big Pratt wrote:...so it's a bit of a mute point.
So it's silent then?
I think the expression is moot.
Sorry BP...we have a co-worker that keeps saying it the same way and we always razz him about it (jokingly of course). He has a good sense fo humour and a knack for botching expressions.
Once when wrapping up a meeting he combined "we're juggling all the balls at the same time" with "the wheels are in motion" and blurted out "okay boss my balls are in motion".
I believe that even with the engines shut down the odds of not striking at least one blade on the runway is very slim.
It would be wonderful to be on short final with engines shut down and feathered and discover you are too fast or too slow and must overshoot. It probably makes the decision to feather your engines seem a little silly.
"LIFE IS NOT A JOURNEY TO THE GRAVE WITH THE INTENTION OF ARRIVING
SAFELY IN A PRETTY AND WELL PRESERVED BODY, BUT RATHER TO SKID IN BROADSIDE, THOROUGHLY USED UP, TOTALLY WORN OUT, AND LOUDLY PROCLAIMING"
WOW... WHAT A RIDE
WOW... WHAT A RIDE
If you are short final, and SUDDENLY discover you are "too fast or too slow" I wonder what instruments you were staring at down final.... the oxygen gage?
Me think perhaps you may want to pay more attention to your airspeed indicator in a case like that. It is the one in the top left.
In just two days, tomorrow will be yesterday.
