Missinnippi's caravan
lazyboy
Post by lazyboy »
Anyone know how much damage to the caravan.
groundtoflightdeck
Post by groundtoflightdeck »
Did something happen, or are you talking about last summer?
lazyboy
Post by lazyboy »
Just the other day....heard it was a bad bounce and hit the tail on the ground
2R
Post by 2R »
It would have to be a really bad bounce never heard of anyone smacking the tail on landing before .A new first for a van .Usually the tails get damaged when loading is done by forklifts or no pogo stick.
The most damage is usually done during loading :evil: :evil:
Axial Flow
Post by Axial Flow »
Occurrence Type: Incident Occurrence Date: 2007/08/21
Occurrence Time: 1430 Z Day Or Night: day-time
Fatalities: 0 Injuries:
Canadian Aerodrome ID: Aerodrome Name:
Occurrence Location: Ferguson Lake Province: Manitoba
Country: CANADA World Area: North America
Reported By: TSB Winnipeg AOR Number:
TSB Class Of Investigation: 5 TSB Occurrence No.: A07C0157
Event Information
Flight control systems (ailerons, rudder, rotors, flaps, main, tail)
Hard landing
Aircraft Information
Flight #:
Aircraft Category: Aeroplane Country of Registration: CANADA
Make: CESSNA Model: 208B
Year Built: 2005 Amateur Built: No
Engine Make: PRATT & WHITNEY-CAN Engine Model: PT6A-114A
Engine Type: Turbo prop Gear Type: Land
Phase of Flight: Landing Damage: Minor
Owner: BEAVER AIR SERVICES LIMITED PARTNERSHIP, BY ITS GENERAL PARTNER, MISSINIPPI MANAGEMENT LTD Operator: BEAVER AIR SERVICES LIMITED PARTNERSHIP, BY ITS GENERAL PARTNER, MISSINIPPI MANAGEMENT LTD. (4077)
Operator Type: Commercial
Detail Information
User Name: Ridley, Rod
Date: 2007/08/23
Further Action Required: No
O.P.I.: System Safety
Narrative:The Cessna 208B operated by Beaver Air Services, bounced on landing at Ferguson Lake and sustained minor damage when the tail cone struck the runway. The company recieved a ferry permit to return the aircraft to base for repairs.
just curious
Post by just curious »
The old Ferguson Lake strip was sand and loose rocks on a hill. I wouldn't go there on the otter without intermediates.
The question shouldn't be what damage was there, but rather "How did the pilot avoid damage for so long?"
lazyboy
Post by lazyboy »
I was just told it will be down around 2 weeks getting repairs.
Laluffa
Post by Laluffa »
I heard after further inspection of the aircraft, there was actually extensive damage. Could be down for much longer than two weeks. Ouch!
lazyboy
Post by lazyboy »
You'd think they would learn,one last year on a esker,now this one.I guess you have to take what you can to make them aircraft pay.....
grimey
Post by grimey »
lazyboy wrote:You'd think they would learn,one last year on a esker,now this one.I guess you have to take what you can to make them aircraft pay.....
They are learning. They didn't need a helicopter this time.
Freeride
Post by Freeride »
There's a reason company's charge more for offstrip. It is a lot harder on the aircraft. Things occasionally get bent. Beats the hell out of flying pavement to pavement tho.
Is dat Pan Am on the runway, Isn't that veird?
lazyboy
Post by lazyboy »
Can they charge enough to cover lost revenue,increased insurance,and damage history on the plane....I know they can not.A case of the wrong airplane for the job.
Go Guns
Post by Go Guns »
Caravans have been going in and out of Ferguson for how long now? How does a hard landing make it the wrong airplane for the job?
vstrom
Post by vstrom »
Ok... I promised myself that I would never post here on avcanada..but enough is enough.
The caravan has been going into Ferguson for close to 10 years..the strip there, while rough and soft at times, is more than suitable. The guys there look after that strip very well and do what they can to keep it as smooth as possible.
It wasn't a hard landing that did it..it was turning around... the nosewheel hit a good bump which launched it high enough to hit the tail.
A year and and a half ago a twin otter lost a nosewheel on the ice at ferguson..and you guys didn't jump all over them..or when the DC3 ploughed into the side of the icestrip... guess those airplanes are out of their elements too. Hell..A pilatus goes off the end of a runway and it doesn't even get as much attention. Offstrip/icestrip and etc are going to be more hazardous and maintenace heavy then your typical runway to runway crap.
Lazyboy go stick it where the sun doesn't shine.
Fair enough, so how fast were they taxing to bang the tail on the ground, how far aft was the C of G envelope?
If we are going to give the reasons for these accidents we can only learn from knowing what causes them.
I'm sitting here trying to remember if I ever had a nose wheel leave the ground while taxing on a rough strip, and can't recall ever having that happen.
Is the Caravan subject to banging its tail on the ground while taxing?
tofo
Post by tofo »
are there any fences that they should be aware of when they get it back on line?
2R
Post by 2R »
So it does look a loading issue ,
Aft CG ???
Any pictures ???
