nice vis in yeg
nice vis in yeg
METAR CYEG 201300Z 23002KT 0SM FZFG VV001 M14/M15 A2988 RMK FG8 RVR
RWY 12 1100FT VIS 0150FT FROIN SLP167=
first ive seen this one!
Re: nice vis in yeg
even better....
METAR CYQF 201300Z 00000KT 0SM FZFG VV000 M09/M12 A2986 RMK FG8
SLP164=
SLP164=
Re: nice vis in yeg
Back in the old SA (Surface Analysis were replaced by METARs and had a slightly different language) days they used to write W0X0F.
That's before that vv stuff, you could see 1X for 100ft obscured now you see VV1. Weather 0ft Obscure 0sm in Fog was "W0X0F"
F
F
Re: nice vis in yeg
I was working the midnight this morning, and I feel real bad about a certain Flightcraft. Started taxiing at about 5:35 with descent vis, then it crapped out. Taxi'd him all over the airport trying to find a runway with legal departure. Don't know how long he waited, my shift ended at about 6:15. On a side note, the VV 100 was interesting, I saw the caravan overfly this morning and the moon real nice. Reminded me of my flying days in CYRB. Woxof only in the last 50' of approach
Rob Benusic, CYEG Tower
Re: nice vis in yeg
The obs are still done using the SA code, more or less. METAR abbreviations have replaced the old SA ones (so fog is FG now, not just F), but the weather gets written out the old way on paper, before a computer translates it into a METAR. But if the weather were bad enough, the observer would still be recording W0X0FG.fougapilot wrote:Back in the old SA (Surface Analysis were replaced by METARs and had a slightly different language) days they used to write W0X0F.
F
Re: nice vis in yeg
We overheard that jazz was planning to land in YXD to wait out the junk wx. Did they end up going to city centre?
Re: nice vis in yeg
So... how much would centre-line lighting cost??? Maybe YEGAA could turn down the gas on the big fireplace outside of Second Cup and scrape a few pennies for the next time lower than standard departure minima are needed.
Re: nice vis in yeg
$1,000,000+WJ700 wrote:So... how much would centre-line lighting cost??? Maybe YEGAA could turn down the gas on the big fireplace outside of Second Cup and scrape a few pennies for the next time lower than standard departure minima are needed.
- invertedattitude
Re: nice vis in yeg
CYXS 221200Z 00000KT 0SM R15/0500FT/N FZFG VV000 M10/M11
CYXS 221635Z 221601 00000KT 0SM FZFG VV000
Re: nice vis in yeg
ya that was quite the day i worked midnight to 10am that day and watched the fog roll in around 5 am just after fedex 727 arrived and then it finally moved out around 930 i believe,
TO KNOW THE ROAD AHEAD, ASK THOSE COMING BACK
- invertedattitude
Re: nice vis in yeg
Morningstardisengage wrote:ya that was quite the day i worked midnight to 10am that day and watched the fog roll in around 5 am just after fedex 727 arrived and then it finally moved out around 930 i believe,
