Question About the Glide Ratio
V2-OMG!
Post by V2-OMG! »
I've seen this discussed on a particular thread, but I cannot relocate it.
Could someone please explain the "glide ratio" to me?
Also, would anyone know what the "glide ratio" would be for a Lockheed L-10A (the first a/c used by Air Canada)?
Thanking you in advance!
dangerous
Re: Question About the Glide Ratio
Post by dangerous »
Glide ratio is forward distance travelled divided by altitude lost. When all your engines fail, you want to maximize your glide ratio. Most light aircraft have a published best glide ratio at a specific best glide speed.
"Yeah. There is a problem. You...because you're dangerous. You're dangerous and foolish - and that makes you dangerous! Now, let's cut the...crap. We've got a plane to fly. Let's try to be on time, okay?"
~Val Kilmer, Saturday Night Live
V2-OMG!
Post by V2-OMG! »
Thanks so much "dangerous."
Rudy
Post by Rudy »
It's not all that common to see glide ratio numbers for twin engined aircraft published but someone on here might know. A total guess for an aircraft like the Electra would be around 12:1 with the engines not running and the propellers "feathered" (the position that creates the least drag). For some perspective a Pilatus PC-12 does 16:1 at max. weight, according to google a Northern Flying Squirrel does 1.98:1, and an open class glider like this 'eta' can do around 70:1.
