That thread about the Toyota Prius vs. Hummer kinda inspired me to write this and ask a couple of questions.
There is a new practice out there called hypermiling (meaning to drive in the most gas saving efficient way possible to squeeze the most out of every drop of gas).
I know most of you have heard about things like keeping your tires inflated right, getting a tune up, planning your trips/avoiding un-necessary trips etc., and basic things like coasting to a stop sign/red-light.
There are those who take it to the extreme however. I decided to experiment with it a bit this last 2 weeks using my 6 cylinder standard transmission 2002 Pontiac Pursuit.
I was just wondering if any of you would have the automotive expertise to comment on the following:
1) Instead of just coasting to a red light (especially when going down a hill) -- turn your ignition off...let inertia glide you there. Theory -- when coasting (with foot off accelerator) -- your engine still "idles" and uses up gas...so turn off the engine and use the built up inertia. If you are idling at a stop light -- you are using gas to get zero miles per gallon! Restart engine when light turns green.
If you have a leased car with an electronic odometer -- turning your ignition and power off allows you to coast significant distances that are not recorded on the odometer and thus saves you on leasing costs. It could build up over time.
If it looks like inertia won't get you to the stop sign -- push down on the clutch pedal so the friction from the engine/drive train etc. won't slow it down.
QUESTION: Isn't this hard on the starter motor and wear and tear?
2) I found a this one on Youtube.com -- Wait until you are nealy empty before refueling because if you have more fuel -- you have more weight. Other than doing price speculation on gas (in other words -- I'd fill up now rather than over a long weekend or when ever I think before gas is going to go up mentality) -- Lets take this one step further! Let's put your car into the "Utility" category.
Carry only enough fuel to get from Point A to Point B Plus an extra 45 minutes or whatever school rules are. This means your car carries less weight. If you do go to a gas station -- fill up only what need to get home in your tank and put the rest (say approx 40 liters) in a jerry can or gas container to take home...refuel using the jerry can or gas container before going on a round trip to and from work/destination.
COMMENT: I've never done this before (afraid my garage with fully loaded gas cans can be a hazard) -- but what effect do you think #2 would have??
3) Tune ups and changing air filter etc...I wonder what your cost of tune-ups are and changing oil filters/tires, ect...
Obviously it increases your gas milage but does that increase in gas milage offset the cost of the tune-up??
