King Air 90
King Air 90
Hey, I notice that the service ceiling is well above 13 000 feet, my question is, how come this plane isn't pressurized? is it required for 10% of the pax to actually wear oxygen in this plane after 30min above 10 000 feet and look like ww2 pilots?
Also, if you want to buy a Single Pilot Multi Turboprop airplane like the B90 but want to throw two pilot's in there, I am right to say that you need an SOP correct?
And the captain does not have to hold an ATPL because he/she isn't commanding a multi crew airplane, but would writing an SOP make this a multi crew airplane and thereby require the captain to have an ATPL?
Also, if I am paying my pilots for their PPC on the plane, would I have to designate a Chief Pilot to carry out their recurrency rides every 6 months? or would I just have to send them back to where they got their initial PPC training?
Last but not least, if I wanted to throw two commercial pilot's into this plane where one of them acts as F/O on one of the legs and acts as Captain on the second leg, would there have to be a special legal requirement for that or is it just mentioned in the SOP that pilots will switch legs accordingly and log PIC time on one of the 2 legs?
jetflightinstructor
Re: King Air 90
It is pressurized. Get it fixed if not. Thats criminal to burn fuel at 10000 feet on a turbine airplane.Hey, I notice that the service ceiling is well above 13 000 feet, my question is, how come this plane isn't pressurized?
and the 90% remaining die?is it required for 10% of the pax to actually wear oxygen in this plane after 30min above 10 000 feet and look like ww2 pilots?
The PIC doesnt need an ATPL. (on a medevac flight, the government could ask one though).And the captain does not have to hold an ATPL because he/she isn't commanding a multi crew airplane, but would writing an SOP make this a multi crew airplane and thereby require the captain to have an ATPL?
No the chief pilot is not automatically entitled to conduct the renewal. And thats each year.Also, if I am paying my pilots for their PPC on the plane, would I have to designate a Chief Pilot to carry out their recurrency rides every 6 months? or would I just have to send them back to where they got their initial PPC training?
yes approved by TC.Also, if you want to buy a Single Pilot Multi Turboprop airplane like the B90 but want to throw two pilot's in there, I am right to say that you need an SOP correct?
Then they have to be checked on both seat.
Re: King Air 90
With under 10 passengers, you operate under 703 regs and so I don't think you need SOPs, those are a legal requirement for 704 and up only. If you want the cojoe to be able to log time though, it has to be in your COM. And swapping captains is fairly common, they're called co-captains. Jetflightinstructor, E-Flyer is correct that you only need oxygen for 10% of the passengers above 10,000 feet for > 30 minutes, it's when you go above 13,000 unpressurized that they all need oxygen. There's enough oxygen below 13,000 for pax to listen to their ipods and sleep in the back.
You better incarcerate those hoodlum Caravan/BE99/etc drivers then!Thats criminal to burn fuel at 10000 feet on a turbine airplane.
- Cat Driver
Re: King Air 90
What is the big deal about being able to fly from either seat?
What happens when you get in a tandem seat airplane, do you get a split personality tugging you both left and right?
jetflightinstructor
Re: King Air 90
well... those driver are not given the choice....You better incarcerate those hoodlum Caravan/BE99/etc drivers then!
Re: King Air 90
I thought it wasn't pressurized cause I read it on the dynamic aviation website, wasn't able to find the info on the beech website. Anyway thanks !jetflightinstructor wrote:It is pressurized. Get it fixed if not. Thats criminal to burn fuel at 10000 feet on a turbine airplane.Hey, I notice that the service ceiling is well above 13 000 feet, my question is, how come this plane isn't pressurized?
Another question, since I don't need an SOP under 703, would I just need a COM that is approved by TC if I want to have two pilots in there?
Who would designate that the pilots are okay to fly from both right and left seat if there's no CP?
Can't I just buy the airplane as private and not make it a commercial op? or would it be mandatory to make it a Commercial Operation if I am paying pilots? Cause couldn't a person get himself a plane and pay two pilots to fly it for him?
Thanks !
tired of the ground
Re: King Air 90
ANY operation that runs 2 crew needs "appproved" SOP's. If you aren't taking credit for the co-jo being there and they are in fact just along for the ride then it's not required.
I believe the dynamic aviation 90's are a65 models which where queen airs fitted with pt6's, square windows and all. They may not be pressurized at all.
Re: King Air 90
okay ... so who has the legal right to write up the SOP and COM? or could our COM be the SOP that we write with the only difference being TC's approval on it? How does that work? I heard elsewhere where the COM is a TC Approved SOP, so when you go against the SOP to put flaps down 10 miles away from final, you're going against TC as well.
Re: King Air 90
Unless the airplane is a weirdo one of built for the US Army or an oldie that has exceeded it's service life, a B90 King Air is pressurized to 4.6 PSID by a supercharger on the right engine. Oxygen requirements are basically a "bailout bottle" so you can get down to a breathable altitude in case of a pressurization failure. You are obviously a private operator because if you have a commercial OC, you would know the answers to the questions. Either way, you cannot just buy the airplane and start operating. A commercial operator will have to have the airplane added to the OC, you will have to be in a higher weight category, you will require an Ops Spec to operate the airplane, and man, you have a bunch of homework to do. If you are a private operator, contact the CBAA and they will lay out the requirements.
But what I think is happening here is you are a rampie with dreams just fishing, otherwise you would know most of the answers.
Re: King Air 90
Actually, I am not dreaming of anything. My friends boss is planning on adding a plane to his company for business trips and I am asking all these questions on his behalf. I should have mentioned that earlier. And nope, I am not a rampie... you probably were just assuming that I was.
You aren't by any chance the janitor i had a disagreement with at the airport a few days ago are you? Seriously, don't just jump to conclusions, I know it's easy behind a computer.
SAR, I know it's 26 000 feet, I was refrencing 13000 to the pressurization requirements that's all. Thanks otherwise !
Re: King Air 90
Actually I think I saw a 90 in Baker Lake last year run by a survey company with big square windows that wasn't pressurized.
Re: King Air 90
Nope not a 99.
it was a king air, looked exactly like the 200 i was flying but smaller and without a T-tail.
I thought it was weird too, first time I've seen the square windows on a beech other than the 99. I guess this one was never built to be pressurized.
Howitzer
Re: King Air 90
As mentioned in a few posts above, the US Military had ordered several King Air 90's that are not pressurized, and have a cargo door on them. That probably what you seen up there, as many of them have been sold off as surplus.
Re: King Air 90
Mode C said.................
"Actually I think I saw a 90 in Baker Lake last year run by a survey company with big square windows that wasn't pressurized."
Could that have been a Beech Queen Air?
Esse quam videre.
