The quickest way to go from a float to another on a Beaver
glideric
Post by glideric »
Look at this video I made of myself going from a float to another on the DHC-2 Beaver...I learned it from a old bush pilot...
If you wanna try, make sure the prop hub is clear of oil and water...
Have fun ! ;)
http://www.youtube.com/watch?v=NwO2HLBnnkg
Je me souviens
MUSICMAAN
Re: The quickest way to go from a float to another on a Beaver
Post by MUSICMAAN »
uh..... that's not the governor.
duCapo
Post by duCapo »
Personally I would make sure the prop hub was free and clear of oil and water:-)
Rule #62 "Don't take yourself so damn seriously"
glideric
Post by glideric »
Sorry MUSICMAAN, I change it...for hub...thanks
Je me souviens
cubonfloats
Post by cubonfloats »
did you ever fall in the water practising?
pointyendforward
Post by pointyendforward »
Nice Moves!!!! Do you actually use this other than when you are at the dock? i can't imagine attempting a tough offside docking while full of passengers... pull the mixture, mags off, steer it as best you can, out the door to the front of the float and........ SPLASH!!!!! Pilot in the drink and Beaver shooting past the dock and into the trees... So, is this something you actually use or just a way to show off your moves on you tube?
Post by niss »
I do that during my walk around to get to the other side of the cowl.
Will that work on these ones :wink:
http://www.airliners.net/photo/Harbour- ... &sok=WHERE__(aircraft_generic_%3D_%27De_Havilland_Canada_DHC-2_Beaver_(L-20ESCSLASHU-6)%27)_&sort=_order_by_photo_id_DESC_&prev_id=1387216&next_id=1385003
cubonfloats
iflyforpie wrote:Will that work on these ones :wink:
i wish.. itd save a lot of time...might be hard to hold onto the window cleaner while doing it, though.
Rudder Bug
Post by Rudder Bug »
Nice stunt but I prefer my good old cable in the front! :D
glideric
Post by glideric »
I never use it on a move, but in the morning when you want to oull out water of floats,,,you gain time. The pilot how teach me that says that it use it almost all time...you got to be tall for working good on this...
Je me souviens
glideric
Post by glideric »
No chance,..no grip, some hubs are bigger than this one, but they are harder to do to...the smaller the better...(not always it life)...
Je me souviens
glideric
Post by glideric »
No chance,..no grip, some hubs are bigger than this one, but they are harder to do to...the smaller the better...(not always in life)...
Je me souviens
Chuck Ellsworth
Post by Chuck Ellsworth »
That is a prop dome not a hub...
D-Iced
Post by D-Iced »
There is an even more secure way to do it, though not quite as quick (can be with practice), and it works with a 3 blade. The bottom of the cowling is secured directly to the cylinder heads, very secure. You start with yer left hand on bottom of cowling (if this was rock climbing it would be a "bomber mega pocket", solid), left foot out as far as possible on forward horizontal float strut, layback position. Right hand over left in a crossover move, a quicktime shuffle of the feet, and an easy pull up on the fwd diagonal strut on the offside with your left hand. Voila! The prop should be straight down on a 3, same for a 2.
Not saying I have used this for offside docks, but you could for shore. :wink:
Don't have a lot of experience with Beavers but isn't the bottom cowl just resting in a couple of grooves on the bottom cylinders just like the top cowl? And the two halves secured with four 1/4" T-bolts in quick releases held in some light gauge tin?
glideric
Post by glideric »
D-Iced wrote:There is an even more secure way to do it, though not quite as quick (can be with practice), and it works with a 3 blade. The bottom of the cowling is secured directly to the cylinder heads, very secure. You start with yer left hand on bottom of cowling (if this was rock climbing it would be a "bomber mega pocket", solid), left foot out as far as possible on forward horizontal float strut, layback position. Right hand over left in a crossover move, a quicktime shuffle of the feet, and an easy pull up on the fwd diagonal strut on the offside with your left hand. Voila! The prop should be straight down on a 3, same for a 2.
Can you make a movie doing it ??? Please...
Je me souviens
Post by North Shore »
Methinks a good start-of-season practical joke (you know, just after the ice has gone, and the water's nice and cold!) would be to put a thin coating of lightweight oil on the prop dome of glideric's machine! Just make sure the camera's running! :smt040
Happiness is V1 at Thompson!
Rudder Bug
And a banana peel on the other float so we can't miss! :mrgreen:
Matthew
Post by Matthew »
why not just go through the doors :roll:
...and learn to dock downwind when you can't :wink:
The hub is certainly strong enough for that kind of manouver, but the cowl as iflyforpie already mentioned is only attached to the other cowl........and for the price of them I don't think it's a good idea to hang off them (at least when the owner is looking).
Matt.
D-Iced
Post by D-Iced »
Matthew wrote:why not just go through the doors :roll:
Matt.
I beg to differ. The bottom of the cowl is tied right into the jugs. Check it out (unless older Beavs are diffferent)
xsbank
Post by xsbank »
If you go swinging on the cowl of my beav I think I would just shoot you.
Xsbank, isn't it natural for a monkey to want to swing on things? :mrgreen:
ThatGuyYouKnow
Post by ThatGuyYouKnow »
So that's how dents get on the inside of floats...lol. Not exactly what I would do, the front cable makes more sense to me. Too many things to go wrong.
WTF
sammy
Post by sammy »
why didn"t someone tell us that the motor should be stopped before doing this ? Anybody who found an arm and an ear ....reward is offered at Dumb Dumb Airlines.
