Page 1 of 1
Interview with First Air
Posted: Thu Oct 02, 2008 8:46 am
by synthpro
I was invited to an interview WITH SIM for First Air.
Any heads up would be much appreciated on what to expect.
Synhpro
Re: Interview with First Air
Posted: Thu Oct 02, 2008 12:15 pm
by scopiton
for which position ?
Posted: Fri Oct 03, 2008 7:29 pm
by MKIII
I think there is an opening for a president position...
Posted: Sat Oct 04, 2008 1:36 am
by Hoov
Rampies too...
Posted: Sat Oct 04, 2008 1:13 pm
by ettw
If its like mine was:
Technical exam. cant remember how many questions..maybe 30....IFR, northern ops, i think there was a q about ISA at 35000 feet or something like that, maybe a q about whether to climb or decend as you encounter turb in the vicinity of a jetstream.
The interview was straight forward...tell us about a time....tell us about a time.....describe what crm means to you.
Sim eval was also straight forward. use the pnf, call for the checklists, basic ifr but just faster (of course that depends on what youre flying now). Its a citation sim if they use the TC one here in YOW.
ETTW
Posted: Sat Oct 04, 2008 7:58 pm
by synthpro
Thanks so much ETTW!
That really helps.
Synthpro
Posted: Sat Oct 04, 2008 10:40 pm
by Changes in Latitudes
What ETTW says is on the level.
Have a good idea of the company before you go in. Have an understanding of CRM situations and know that they involve more than just interacting with another pilot (flight attendants, ground crew, dispatch, ops interactions).
Know why you want to work there and the type of environment you'll be working in. Come armed with a few questions too.
Posted: Sun Oct 05, 2008 1:31 pm
by B757FO
ettw wrote:If its like mine was:
ETTW
ETTW is bang on. I used to do some interviews there in my time there and if they are the same exams as before I created them and they are not that hard. If you have the books written by a guy in western Canada go through the ATPL ones and the questions are similar. 1 exam was for jet entries and 1 exam for turbo prop entry level. The exam is based on experience and is only a guidline in the hiring process. It was 30 questions for the turbo prop and 65 for the jet rated pilots. Again mostly as stated above ATPL exam and some basic questions like the ISA at 35000'. I believe the question was what is ISA -10'C at 35000ft. Or it was written the other way like if its -45'C at 35000 what is ISA. I think it's the 2nd way if I can remember. What happens to mach in a climb at a constant IAS. At -20'C the Altimiter over or under reads. Lightning is prominent around a thunderstorm between what temperature ranges? -5 to +5'C etc questions like that. The interview part is based on the old Air Ontario interview now this may have changed but I am sure its the same one. Simple situations they put you in and you have to talk your way out of it essentially. As ETTW mentioned always mention the F/A. Drunk Captain etc. Tell us why we should hire you. Why First Air and not AC/WJ etc. Know a bit about the company will always help.
The sim profile was based in YOW on the King air 90 sim. (This is all by memory so may not be corrent but the items to be covered will be the same.)
T/O from rwy 25 left turn direct the YOW VOR (may be clearance) Prior to reaching the VOR you will get a hold clearance at the VOR. Use the pilot not flying to fly basic skills straight and level on the heading etc and speed. Once you brief the hold and don't forget to talk about wxx and fuel etc for the hold advise company then advise the backend etc. You will be vectored for an ILS on either 32 or 07 to a go around engine failure. Vector around for a visual on one of the runways. Now this may have changed but sim evals are all similar. There are looking for a good scan. The sim has no Z axis so it does not yaw only pitch and roll so engine failures are pretty easy to feel them. Falls to one side.
Its a good company as BBB will agree but I had done my 11 years and needed a change. Miss it though some days. Good luck. Let us know how you did.
EDITED: ADDED
Another thing we used to do is give a guy a small emergency checklist on the 727 and give you a minute to remember it then they take it away and ask you to recite it by memory as best you can.
Cheers.
B757FO
Posted: Sun Oct 05, 2008 7:42 pm
by synthpro
Hey B757FO...
I want to truly thank you for these points. I will make sure to put them to good use. Thank you so much, and I appreciate the time you took to write this.
Synthpro
Posted: Mon Oct 06, 2008 7:07 am
by B757FO
No problem. Good luck. Just be yourself. The more info you know about the company is a plus also as ETTW said. They will ask you what do you know about 7F. Routes planes bases etc.
Good luck.
B757FO
Posted: Mon Oct 06, 2008 8:34 am
by Brantford Beech Boy
B757FO wrote:Its a good company .... Miss it though some days.
some days.
BBB
Posted: Tue Oct 07, 2008 9:13 pm
by Pratt
Word has it that they are not doing very well at the moment, losing alot of market share to Canadian North and others. Having let go a couple of the big guys........................
Just a few more things you might want to figure into your decision.
Posted: Tue Oct 07, 2008 10:22 pm
by northernu
ya, ive also heard they're not doing too well at the moment. looks like the few guys who got out and headed to asia left at the right moment. from what ive heard though, the shaky area lies with the atr staff...i doubt 5T could take over for the herc though.
Posted: Thu Oct 09, 2008 7:28 pm
by young grasshopper
I suppose you've scoured over the 7F accounting books to figure out that one? I guess a friend of a friend would be a reputable source though...
No one has left for Asia...but yeah - when EVERY company was losing guys, 7f lost some guys to Emirates/AC/etc.
Sometimes change is a good thing...wait for a couple months and you'll see...
Pretty brazzen for a guy with ONE post...Stand by your Company/Identity if you're choosing to slag another company and their staff...
Jeff
Posted: Thu Oct 09, 2008 9:12 pm
by Pratt
Jeff[/quote]
I am not arguing with you, just stating facts.
I didn't say it wouldn't be better or worse,, but it is the typical knee jerk reaction when things aren't going well. Two very experienced guys gone, who is directing the show now, the bean counters, that can't be good.
Posted: Fri Oct 10, 2008 6:16 am
northernu wrote:ya, ive also heard they're not doing too well at the moment. looks like the few guys who got out and headed to asia left at the right moment. from what ive heard though, the shaky area lies with the atr staff...i doubt 5T could take over for the herc though.
Definitely, with consistently full loads and 60 years of doing this I am sure 7f is feeling this shaky ground and hitting the panic button. I'm betting that they've never had a change in management in 60 years either, its all very new to the organization as you must know. Hope those Dash 8's can handle sarcasm because I am loading it on real thick at the moment.
Anyway, there's enough food at the buffet for everyone, just keep your face on the right side of sneeze guard, ace.
Getting back on track, First Air offers an outstanding benefits package, above average pay, great maintenance, good schedule, and great people to work with in a challenging environment. It's a stable organization worth exploring; go to the interview!
Posted: Fri Oct 10, 2008 6:15 pm
by flynfiddle
I've heard those ATR guys are a shifty bunch! :smt040
Posted: Fri Oct 10, 2008 8:15 pm
by Four1oh
7f is a solid company, with solid flying; the kind of flying that teaches you more than just hand-flying an ILS. You'll learn lots, and the place probably smells far better now that a certain CEO is gone. It can only get better.
My sim eval was on the 727 many moons ago. Remember, if you find yourself on a 5 mile final, in the dark, and no glideslope; power=altitude and pitch=speed.
Posted: Sat Oct 11, 2008 11:45 am
by Rowdy
ETTW - You're a king. Every post I've seen from you has been clear, concise to the point with no bullshit and no bias. Pretty impressive for a Hawker pilot. haha :wink:
I have no info to add as I don't work there, but we see a lot of their crews and they seem like a good bunch.
Best of luck to you.
Posted: Sat Oct 18, 2008 5:48 am
by synthpro
Hey everyone.
I GOT THE JOB!!!! ha ha ha. I'm so happy.
I just wanted to thank all of you for your responses. The kind of information I received from you was extremely useful.
So I truly thank you for all your help. This was a big break for me.
Synthpro
Posted: Sat Oct 18, 2008 5:53 am
synthpro wrote:Hey everyone.
I just wanted to thank all of you for your responses. The kind of information I received from you was detrimental to my interview last week. Information is most certainly POWER.
Synthpro
Geeze, that's the last time I give out any employment info, I didn't mean for it to be detrimental to your inteview, Synth! :lol:
detrimental (comparative more detrimental, superlative most detrimental)
Causing damage or harm.
Smoking tobacco can be detrimental to your health.
Congrats!!! I think :)
Posted: Sat Oct 18, 2008 8:34 am
by synthpro
Still hangn' from the celebrations last night.
Synthpro...
Posted: Sun Oct 19, 2008 1:46 pm
Welcome to the team - are you YOW/YFB based or YZF? In any event - congrats again and see you around...
Posted: Sun Oct 19, 2008 1:52 pm
by ettw
Synthpro
CONGRATS!! I'm sure you'll enjoy it very much!
ETTW
