aerial application
Place a topic in this forum to introduce yourself and find a little advice.
Moderators: sky's the limit, sepia, Sulako
gavrailoff
aerial application
Post by gavrailoff »
Im currently working on my CPL and Im interested in getting into the air spraying industry. Any info about what the companies out there require would be great.
Adam Oke
Re: aerial application
Post by Adam Oke »
Most of the work is out west in Manitoba and Sask. One good thing to have is a strong background in agriculture. It's a very steep learning curve if you didn't grow up in the industry. Extensive tail wheel time is a must. No way around it as all Canadian spray planes are tail draggers. Most companies insure their aircraft through CAIR (Canadian Applicators Insurance Recirocal). In order to get insured you need some booms on time. In order to get some booms on time, you can either work for a a company that does not insure the hull (liability only) until you gain enough experience. Or take an Aerial Application course. Runs around $16k and can only be done in two places in Canada. Battlefords Airspray in North Battleford, SK or Leading Edge Aviation in Yorkton, SK. It is not a "time builder" or an "entry level job". Try to get some low level experience.
A good place to start reading is the Canadian Aerial Applicators Association website. http://www.canadianaerialapplicators.com
culver10
Post by culver10 »
Does anyone know the minimum spraying hours one needs to qualify for drift and liability insurance?
bkn4thr
Post by bkn4thr »
best way to get to know all or most of the Canadian operators and also learn alot about the industry is to apply for this job.
http://www.canadianaerialapplicators.co ... 009-01.pdf
CAAA Job Opportunity
The CAAA is seeking for a CAP Clinic Assistant to assist with the 2009 CAP Clinics. The candidate must be available for part time work from the end of April through mid June. The assistant would receive training with Dennis Gardisser to become a certified SAFE Analyst. Competitive salary provided. Please send your interest in the position to jill@managewise.ca or fax to 780-413-0076 by February 15, 2009
bkn
Return to “AvCanada's Mentor Program”
