"......and centre this is ABC123 level one seven thousand".
....I'm not sure using the word "AND" to start any communiqué, whether in person, writing OR radio is proper, AND not to mention it is driving me nuts to hear on the radio
So the question now is as I have heard it more and more over the radio from AC to WJ from C150 egg beaters to B777 left seaters...
Lets start with the Dictionary definition of this word.
http://dictionary.reference.com/browse/and
I think # 11 is the only scenario where using the word AND to begin a communiqué applies in aviation.and /ænd; unstressed ənd, ən, or, especially after a homorganic consonant, n/ Show Spelled Pronunciation [and; unstressed uhnd, uhn, or, especially after a homorganic consonant, n]
1. (used to connect grammatically coordinate words, phrases, or clauses) along or together with; as well as; in addition to; besides; also; moreover: pens and pencils.
2. added to; plus: 2 and 2 are 4.
3. then: He read for an hour and went to bed.
4. also, at the same time: to sleep and dream.
5. then again; repeatedly: He coughed and coughed.
6. (used to imply different qualities in things having the same name): There are bargains and bargains, so watch out.
7. (used to introduce a sentence, implying continuation) also; then: And then it happened.
8. Informal. to (used between two finite verbs): Try and do it. Call and see if she's home yet.
9. (used to introduce a consequence or conditional result): He felt sick and decided to lie down for a while. Say one more word about it and I'll scream.
10. but; on the contrary: He tried to run five miles and couldn't. They said they were about to leave and then stayed for two more hours.
11. (used to connect alternatives): He felt that he was being forced to choose between his career and his family.
12. (used to introduce a comment on the preceding clause): They don't like each other—and with good reason.
13. Archaic. if: and you please. Compare an 2 .
–noun
14. an added condition, stipulation, detail, or particular: He accepted the job, no ands or buts about it.
15. conjunction (def. 5b).
—Idioms16. and so forth, and the like; and others; et cetera: We discussed traveling, sightseeing, and so forth.
17. and so on, and more things or others of a similar kind; and the like: It was a summer filled with parties, picnics, and so on.
Example:
"aaaaand Toronto centre, this is ABC123...I left my wife....level @ oneseven thousand."
Other than that, we as pilots should NOT being using the word and at the start of any radio communiqué.
And....The End
