YVR Jepp Plates
drifter
YVR Jepp Plates
Post by drifter »
Does anyone know where I can get the Jepp plates for YVR online? They don't need to be current. Tried the search but it brings up lots of resources for american publications.
Nark
Re: YVR Jepp Plates
Post by Nark »
I have yet to find any Jepp plates online, nor do I imagine they are out there.
The TERP's can be found at Airnav.com
A brief google search brought me here, which are CAP plates.
Semper Fidelis
wallypilot
Re: YVR Jepp Plates
Post by wallypilot »
You won't find Jepps for free online, I'm afraid. Just NOAA's and CAP's.
Tango Romeo
Re: YVR Jepp Plates
Post by Tango Romeo »
YA free Jepps are hard to come by. lf you know any flight planners or dispatchers you may be able to ask them to print them up for you. There's also a few online programs such as Jeppensen E-Link where if you can obtain an access code you will be able to access pretty much all the plates from every international / regional airport from around the globe. Try checking out their website and you may be able to score a free trial or something...always worth a try.
Good luck,
Tango-
Benwa
Re: YVR Jepp Plates
Post by Benwa »
Check PM Drifter...
--In his wrapup remarks, the FAA chief said, "If you think the safety bar is set too high, then your
standards are set too low."
FL_CH
Re: YVR Jepp Plates
Post by FL_CH »
www.google.com
type "CYVR charts"
press "Enter"
click on first link and be directed here:
http://www.freewebs.com/vogelair/CYVR.pdf
Tango Romeo
Re: YVR Jepp Plates
l would not suggest using anything out of google or wikipedia, unless its simply for plate familiorization/study purposes. The reason for this, as you may already know, those plates that are posted online may not be valid anymore.
Tango-
wallypilot
Re: YVR Jepp Plates
FL_CH wrote:http://www.google.com
type "CYVR charts"
press "Enter"
Those are old charts. Do they have more current ones? The Approaches are reasonable accurate, but the Arrivals have all totally changed from from those.
Don't rely on out of date charts, but they are good for study if you know the procedures haven't changed much.
FL_CH
Re: YVR Jepp Plates
Post by FL_CH »
Well, I thought they didn't need to be current.
There's also "JeppView" software that has been floating around the torrent sites. My friend gets the updates for it off the piratebay and he says sometimes they would upload even the current cycle.
