"Blacklisted" Several Times
Re: "Blacklisted" Several Times
Well, at least the good news is that while you are away from home you should be able to post again without getting blacklisted because you will be using a different provider and IP address. Of course, if it is you that they object to the same will happen. Even more interesting would be if you brought the computer/laptop you use at home to your new home away from home and see what happens.
Flight takes MORE than Airspeed and Money ...
Hi Fog, Are you using Telus internet by any chance?
I am and i was using the Telus security and had to uninstall it as it was blocking way too much.
I am using AVG and same spybot as you were with no problems whatever.
Bob
Bob
- The Old Fogducker
Bob:
Nope, not Telus.
Steps have/are being taken which should have already (hopefully) cured the problem. We're in a test period now.
The Old Fogducker
Nope, not Telus.
The Old Fogducker
Did you get the problem resolved? The idea of changing your IP address sounds bang on. Also I would change the password on all the accounts such as Avcanada, all your email accounts etc.
I had a problem with sexually explicit messages sent to people in my hotmail account when I was offline. It turns out someone hacked my hotmail account and used it for this purpose when I was offline. I tried a half a dozen different programs as well. In the end all I had to do was to change my password.
"Nearly all safety regulations are based upon lessons which have been paid for in blood by those who attempted what you are contemplating" Tony Kern
Am having a similar problem, what turned out to be the solution?
Hi Conan Can you just refresh us on when the maintenance times will be for the ANZ server now? Cheers
