Posting a search within an individual forum
Having difficulties with AvCanada Forums, the internet etc.. ask your questions here.
AOW
Post by AOW »
I was trying to post a link to the search function to help somebody in the Maintenance forum. Maintenance is forum ID # 27, so the url should be
Code: Select all
http://www.avcanada.ca/forums2/search.php?keywords=Voyageur+VAL&terms=any&author=&fid[]=27&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=-1&t=0&submit=Search
however, trying to use the "" tags throws an error because of the b ... mit=Search
I thought maybe it would help if I put the url in quotations, but
Doesn't work either
now if I try to use the automatic URL parsing function, it only parses up until the square brackets, so I get this:
search.php?keywords=Voyageur+VAL&terms= ... mit=Search
Surely, there must be some way to post a link to a search on this board!! I took out the offending brackets and it works, except the search is for every forum, not just maintenance.
Any phpBB gurus out there?
AuxBatOn
Re: Posting a search within an individual forum
Post by AuxBatOn »
I'm not sure why the [] is in the search URL...
Going for the deck at corner
AOW
Post by AOW »
the [] is there as part of fid[]=27 or forum id = 27 (maint). The search you posted is site wide, I just want to get results from the maintenance forum. But thanks for trying.
AuxBatOn
Post by AuxBatOn »
Does that work?
You need to make the [ and the ] as HTML code ( %5B for [ and %5D for ] )
AOW
Post by AOW »
perfect! I should have thought of that!
Widow
Post by Widow »
Place the link inside the "url" tags, where "" = [].
To get
"url"search.php"/url"
a link to a completed search for "voyageur + VAL" in all forums
"url"search.php?keywords=Voyageur+VAL&terms= ... mit=Search"/url"
a link to a completed search for "voyageur" in the "maintenance (27) forum
"url"search.php?keywords=voyageur&terms=all& ... mit=Search"/url"
To display different text
"url=link"DISPLAY"/url"
Note the system will not search for words of three letters and under (like VAL).
AOW
Post by AOW »
Thanks to both of you. I was trying way too hard, and it was in fact a very simple answer...
A
Return to “Internet and Computer Help”
