Engine heaters.
Engine heaters.
Anybody have any experience with engine preheaters? Wonder if it is worth the cost and how effective they are with the cold weather right around the corner?
Re: Engine heaters.
What aircraft type. For a 172 etc, we used to just stuff a ceramic heater under the cowl.jpilot77 wrote:Anybody have any experience with engine preheaters? Wonder if it is worth the cost and how effective they are with the cold weather right around the corner?
Re: Engine heaters.
The best are the Tanis heaters. They heat the oil pan and each cylinder. Runs between $500-$800 depending on the system but there is no better way to preheat. Sticking a space heater up into the cowling isn't enough if you are operating in -10/-20 or lower.
Not cheap, but I am willing to bet it will knock at least that amount off your overhaul bill or unscheduled engine repairs...
http://www.tanisaircraft.com/index.php
Re: Engine heaters.
I have a Seneca 1, so portable heaters are gonna be a problem. If I decide not to fly bellow -10 is it still worth it to install a heater?
Re: Engine heaters.
For those Lycomings with the camshaft way up high, with no oil and none coming anytime soon because of the cold, you bet.
Either that or pickle your engine because you sure don't want to have the engine full of moisture with exposed surfaces over winter.
However; the best maintenance for any aircraft IMHO is to fly it as much as you can...
Re: Engine heaters.
Little Buddy car heaters. They have to run under a good engine blanket for hours, or overnight to be effective. In the field we use one under the dash one in the transmission deck and one in the engine. Take the battery to bed with you and snuggle with it..... when you land always put the blankets on, If you have no power, Below -20 start the aircraft ever couple hours. Always keep the battery warm. I you follow this regime you will have no problems. If you have a frozen aircraft ie cold soaked. Herman nelson is your friend.. don't know who herman is, go back to OZ
i couldn't find any stc info for those heating pads. They look the same as the automotive ones, just custom fit.
Re: Engine heaters.
I have a Reiff Pre-Heat System with a HotStrip element on the oil sump. Takes a few hours but have a programmable timer for that.
Also have an insulated engine cover.
http://www.reiffpreheat.com/product.htm
PAJ
PAJ
Flight takes MORE than Airspeed and Money ...
Re: Engine heaters.
If you're not going to fly below -10, and it's your money, I'd consider a good multi-grade oil. Do you have a hangar you can pull it into for a couple of hours, or a night before you fly?
Engine covers are a waste of time if you have no heat source. I've seen guys blanket up their Navajos for the night with no plug ins. Total waste of time. Another point. Wind chill has nothing to do with engine heat. If it's -5 and the wind is blowing 30 knots, your engine will never get colder than -5.
As iflyforpie (wonder if he'll fly for cake?) points out....fly it. Running it up to temp isn't the same thing.
Re: Engine heaters.
Stick a car warmer in the cowling and wrap the engine completely with an insulated cover, designed for the plane, and your engine will be as warm in the morning as it is on a summer morning.
I have done this at -50
If no electricity I use to use a propane heater something like a Herman Nelson only smaller, with a 12 volt blower motor so you can run it off you truck battery. Still need the insulated cover, of course, then it only takes about 30 minutes to warm up. Even though I haven't used it for years it is till in my storage shed.
http://www.aerocovers.com/
http://www.kinnearupholstery.com/
Any to answer the first question - Yes it is worth the cost.
Bob
Bob
- PICT0003X.JPG (72.08 KiB) Viewed 3705 times
Re: Engine heaters.
Thanks for the info folks, I want to fly it as much as possible and I would idealy like to have it in a hanger but some of the other fixes might also be good.
Re: Engine heaters.
T.C. issued some sort of a very unorothodox 'blanket approval' for the permanent installation of a ceramic heater under the cowl of piston engine airplanes.
"So long as it does not interfere with engine controls, fire detection or supression systems, the benefit of such a heater installation is considered to outweigh the risk.." Or something like that.
It was a suprising deviation towards common sense by T.C.
Does anybody have a link to that? I think it was a 'Service Letter.'
Re: Engine heaters.
One plane I fly has a TANIS heater, the thing works very well. Minus 30 and it fires right up and the oil temp is up to temp in minutes, quicker then in the summer. If it snows I always find ice at the edge of the engine cover from where the snow melted.
Lurch
Lurch
Take my love
Take my land
Take me where I cannot stand
I don't care
I'm still free
Take my land
I don't care
I'm still free
Re: Engine heaters.
Flying during the winter?
I always thought that God invented winters to give pilots time to pay for their fuel from the previous flying season.
midwingcrisis
Re: Engine heaters.
Tanis...or hangar
How do you go 205 kts TAS on 32 gal/hr without turbos!
Re: Engine heaters.
BeaverBob,
Did you build that thing yourself? Looks like a pretty good rig.
What did you use for a nozzle? BBQ ignitor, I'm guessing?
Re: Engine heaters.
If you are using any type of heater make sure there is no fire hazard & don't leave the heater plugged in if you're not going flying as the moisture generated will turn your engine into a rusted piece of junk very quickly.The longest I leave my safeheat electric oil pan pad plugged in is overnight for an early am departure.I also use a good cowl cover to keep the heat in.I've got a continental io520 D & it only takes a couple of hours to go from -30c to +10c for oil temp.I never preheat if I'm not going flying anywhere.
Daryl
Daryl
Re: Engine heaters.
I often wondered about that ... here is what Reiff says ... believable or marketing spin?BGH wrote: ...... don't leave the heater plugged in if you're not going flying as the moisture generated will turn your engine into a rusted piece of junk very quickly.The longest I leave my safeheat electric oil pan pad plugged in is overnight for an early am departure.
http://www.reiffpreheat.com/FAQ.htm#QA3
PAJ
Re: Engine heaters.
The "frost-fighter" brand will produce a tremendous amount of moisture, the "herman nelson" is relatively dry.
The "tanis" heater though, is by far the best, imho.
For the real cold, tanis + proper engine blankets + batt blanket + buddy heaters in the engine inlets + buddy heaters near anything electronic + heat in the cockpit for the gyros.
As you run out of options power-wise, you must decide what is important, for me it was always engines (incl batt), then apu, then electronics.
black hole
Re: Engine heaters.
For the pilots that fly every day, and just need to keep the engine warn at a remote location occasionally; plugging in a tanis set up on a warm engine overnight is a good deal. The Tanis is not a good deal to heat a cold soaked engine to fly in a few hours at -30. I Found that the old car heater to be better.
The big problem is when there is no power available. I have seen many jury rigged outfits and even a Honda generator to provide power. I made a rig that fit in a tool box from a VW van heater. It would warm one engine on my PA-23; I then started the engine and it then provided power to warm the other.
There is no substitute for a tight fitting engine cover.
Does anyone remember the old blow pot?
BH
BH
paydaymayday
Re: Engine heaters.
Used to use a gigantic 3 foot by two foot combustion 'dragon heater' with two pipes that would fit up to the cowl intakes. Leave the thing running with the vents open on a small to medium piston aircraft and the cabin would be +15 while it was -30 outside. Now, I just use engine blankets and internal engine plug in heaters for the PT6s.
Re: Engine heaters.
Okay, a lot of answers to a simple question. With an even simpler answer!!
wait for it
wait for it
wait for it
The Bahamas!!!!!!!
wait for it
wait for it
wait for it
The Bahamas!!!!!!!
black hole
Re: Engine heaters.
HS-748 2A wrote:BeaverBob,
I bought it at an industrial supply company in Dawson Creek in about 1973. Something like a Napa or Northern Metallic store.
It has a temperature limit switch on it as well.The regulator is adjustable if you want more heat.
Bob
RobinsBright2
Re: Engine heaters.
Space heaters also come in handy if you have a room in your home or office that lacks heating ductwork, is poorly insulated or is otherwise difficult to heat.
Hockaloogie
