I was hoping someone would have an idea.
I'm building an Excel program to produde OFP's. I'm having a hard time finding a database with airport distances or waypoints in Canada.
I know that these exist in the format of Databases with Lat and Long and I'm sure I could figure out how to extract what I need from one of those (if I could find one). I would also be interested in a simple distance chart. I built one of my own for the comon destinations of my company but I still find that it is lacking.
DC
Airport Database
captain_dc
captain_dc
Re: Airport Database
In answer to my own question.
http://www.plews.ca/AirportsinCanada.htm
Now, I'll have to figure out how to complete the rest of the excell formula's to produce distance and heading as well as ete with wind.
DC
DC
Look for the old American DAFIF. It's a few years old unfortunately, because some twits in the US government decided to stop publishing it for "national security" reasons. But it contains coordinates for pretty much every navaid and intersection out there. Even approach waypoints.
This should get you started...
Code: Select all
'Collection of Excel functions to implement (some) of my Aviation Formulary
'Insufficient attention has been paid to error conditions- in particular invalid inputs
'Released under the GNU GPL 12/30/00 EAW
Public Const PI As Double = 3.14159265358979
Function radtodeg(rad)
'Convert radians to degrees
radtodeg = (rad / PI) * 180
End Function
Function degtorad(deg)
degtorad = (deg / 180) * PI
End Function
Function degtodegmin(deg)
'Convert deg to deg and min. Associate sign only with degrees
'Output is array of length 2 [deg,min]
sign = Sgn(deg)
adeg = Abs(deg)
degtodegmin = Array(sign * Int(adeg), (adeg - Int(adeg)) * 60#)
End Function
Function degmintodeg(degmin As Variant) As Double
'Convert [deg,min] to deg.
'Input is array of length 2 [deg,min]
'Sign comes from degree argument
sign = Sgn(degmin(1))
adeg = Abs(degmin(1))
mins = degmin(2)
degmintodeg = sign * (adeg + mins / 60#)
End Function
Function degtodegminsec(deg As Double)
'Convert deg to deg, min and sec. Associate sign only with degrees
'Output is array [deg,min,sec]
sign = Sgn(deg)
deg = Abs(deg)
mins = (deg - Int(deg)) * 60#
degtodegminsec = Array(sign * Int(deg), Int(mins), (mins - Int(mins)) * 60#)
End Function
Function degminsectodeg(degminsec As Variant) As Double
'Convert [deg,min,sec] to degrees
sign = Sgn(degminsec(1))
adeg = Abs(degminsec(1))
mins = degminsec(2)
secs = degminsec(3)
degminsectodeg = sign * (adeg + mins / 60# + secs / 3600#)
End Function
Function disrad(i As Integer) As Double
'Multiplier to turn distance to radians
If (i = 1) Then
disrad = PI / (180 * 60) 'nm
ElseIf (i = 2) Then
disrad = PI / (180 * 60 * 1.852) 'km
ElseIf (i = 3) Then
disrad = PI / (180 * 60 * 1.150779) 'statute miles
End If
End Function
Function Asn(x)
' Equivalent of spreadsheet Asin(x)
Asn = 2 * Atn(x / (1 + Sqr(1 - x * x)))
End Function
Function Acs(x)
' Equivalent of spreadsheet Acos(x)
If (x >= 0) Then
Acs = 2 * Atn(Sqr((1 - x) / (1 + x)))
Else
Acs = PI - 2 * Atn(Sqr((1 + x) / (1 - x)))
End If
End Function
Function Atn2(y, x)
' Equivalent of spreadsheet Atan2(x,y)
' Note argument order!
' No value for x=y=0
' Returns result in -pi< Atn2 <= pi
pi2 = PI / 2
If (Abs(y) >= Abs(x)) Then
Atn2 = Sgn(y) * pi2 - Atn(x / y)
Else
If (x > 0) Then
Atn2 = Atn(y / x)
Else
If (y >= 0) Then
Atn2 = PI + Atn(y / x)
Else
Atn2 = -PI + Atn(y / x)
End If
End If
End If
End Function
Function Md(y As Double, x As Double) As Double
' Equivalent of spreadsheet Mod(y,x)
' Returns the remainder on dividing y by x in the range
' 0<=Md <x
Md = y - x * Int(y / x)
End Function
Function Modcrs(crs)
' Return crs in range 0<crs<=2*pi
twopi = 2 * PI
Modcrs = twopi - Md(twopi - crs, (twopi))
End Function
Function Modlon(lon)
' Return lon in range -pi<=lon<pi
Modlon = Md(lon + PI, 2 * PI) - PI
End Function
Function Norm3(v)
vn = Sqr(v(1) ^ 2 + v(2) ^ 2 + v(3) ^ 2)
Norm3 = Array(v(1) / vn, v(2) / vn, v(3) / vn)
End Function
Function Cross(v1, v2)
Cross = Array(v1(2) * v2(3) - v1(3) * v2(2), _
v1(3) * v2(1) - v1(1) * v2(3), _
v1(1) * v2(2) - v1(2) * v2(1))
End Function
Function vtolat(v)
vtolat = Atn2(v(3), Sqr(v(1) ^ 2 + v(2) ^ 2))
End Function
Function vtolon(v)
vtolon = Atn2(-v(2), v(1))
End Function
Function vf(v)
vf = Atn2(-v(2), v(1))
End Function
'great circle functions
'All arguments and results are in radians
Function gcdist(lat1, lon1, lat2, lon2)
'Compute distance from [lat1,lon1] to [lat2,lon2]
gcdist = 2 * Asn(Sqr((Sin((lat1 - lat2) / 2)) ^ 2 + Cos(lat1) * Cos(lat2) * (Sin((lon1 - lon2) / 2)) ^ 2))
End Function
Function gcbearing(lat1, lon1, lat2, lon2)
'Compute bearing from [lat1,lon1] to [lat2,lon2]
If (gcdist(lat1, lon1, lat2, lon2) < 1E-16) Then
gcbearing = 0 'same point
ElseIf (Abs(Cos(lat1)) < 1E-16) Then
gcbearing = (3 - Sin(lat1)) * PI / 2 'starting point at pole
Else
gcbearing = Modcrs(Atn2(Sin(lon1 - lon2) * Cos(lat2), Cos(lat1) * Sin(lat2) - Sin(lat1) * Cos(lat2) * Cos(lon1 - lon2)))
End If
End Function
Function gcdirectlat(lat1, lon1, d, tc)
'Compute latitude of point d from [lat1,lon1] on the tc bearing.
gcdirectlat = Asn(Sin(lat1) * Cos(d) + Cos(lat1) * Sin(d) * Cos(tc))
End Function
Function gcdirectlon(lat1, lon1, d, tc)
'Compute longitude of point d from [lat1,lon1] on the tc bearing.
lat = gcdirectlat(lat1, lon1, d, tc)
dlon = Atn2(Sin(tc) * Sin(d) * Cos(lat1), Cos(d) - Sin(lat1) * Sin(lat))
gcdirectlon = Modlon(lon1 - dlon)
End Function
Function gcintlat(lat1, lon1, lat2, lon2, lon)
'Compute latitude of the point where the GC through [lat1,lon1] and [lat2,lon2]
'crosses the lon meridian
'returns error if lon1=lon2 or lon1=lon2+pi ie GC is a meridian
If (Sin(lon1 - lon2) = 0) Then
gcintlat = "no result"
Else
gcintlat = Atn((Sin(lat1) * Cos(lat2) * Sin(lon - lon2) - Sin(lat2) * Cos(lat1) * Sin(lon - lon1)) / (Cos(lat1) * Cos(lat2) * Sin(lon1 - lon2)))
End If
End Function
Function gcintlat1(lat1, lon1, tc, lon)
'Compute latitude of the point where the GC through [lat1,lon1] bearing tc
dl = lon1 - lon
cosA = -Cos(dl) * Cos(tc) + Sin(dl) * Sin(tc) * Sin(lat1)
sinA = Sqr(1 - cosA * cosA)
If (sinA = 0) Then
gcintlat1 = "no result"
Else
gcintlat1 = Asn((Cos(tc) + cosA * Cos(dl)) / (sinA * Sin(dl)))
End If
End Function
Function gclatmax(lat, tc)
'Find the latitude at the apex of the GC bearing tc at lat by Clairaut.
gclatmax = Acs(Abs(Sin(tc) * Cos(lat)))
End Function
Function gclonatmaxlat(lat, lon, tc)
'Find the longitude at the apex of the GC bearing tc at [lat,lon]
'Error condition if the GC is the equator.
latmax = gclatmax(lat, tc)
If (latmax > 0) Then
If (tc < PI) Then
gclonatmaxlat = Modlon(lon - Atn2(Cos(tc), Sin(tc) * Sin(lat)))
Else
gclonatmaxlat = Modlon(lon + PI - Atn2(Cos(tc), Sin(tc) * Sin(lat)))
End If
Else
gclonatmaxlat = "Undefined"
End If
End Function
Function gcintlon(lat1, lon1, lat2, lon2, lat3)
'Find the longitudes where the great circle through [lat1,lon1] and [lat2,lon2]
'crosses the lat3 parallel.
'Error condition if there are no points (when |lat3| > latitude of apex)
'Error condition if GC is equator
l12 = lon1 - lon2
a = Sin(lat1) * Cos(lat2) * Cos(lat3) * Sin(l12)
b = Sin(lat1) * Cos(lat2) * Cos(lat3) * Cos(l12) - Cos(lat1) * Sin(lat2) * Cos(lat3)
c = Cos(lat1) * Cos(lat2) * Sin(lat3) * Sin(l12)
lon = Atn2((b), (a)) 'atan2(y,x) convention
If (c > Sqr(a ^ 2 + b ^ 2)) Then
gcintlon = "no crossing"
ElseIf (Sqr(a ^ 2 + b ^ 2) = 0) Then
gcintlon = "equator"
Else
dlon = Acs(c / Sqr(a ^ 2 + b ^ 2))
lon3_1 = Modlon(lon1 + dlon + lon)
lon3_2 = Modlon(lon1 - dlon + lon)
gcintlon = Array(lon3_1, lon3_2)
End If
End Function
Function gcintlon1(lat1, lon1, tc, lat)
'Find the longitudes where the great circle through [lat1,lon1] bearing tc
'crosses the lat parallel.
'Error condition if there are no points (when |lat| > latitude of apex)
If ((Cos(tc) = 0) And (lat1 = 0)) Then
gcintlon1 = "equator"
End If
latmx = gclatmax(lat1, tc)
lonmx = Modlon(lon1 - Atn2(Cos(tc), Sin(tc) * Sin(lat1)))
x = Cos(latmx) / Cos(lat)
If (x > 1) Then
gcintlon1 = "no crossing"
Else
dlon = Atn2(Sqr(1 - x * x), x * Sin(lat))
gcintlon1 = Array(Modlon(lonmx + dlon), Modlon(lonmx - dlon))
End If
End Function
Function gcxtrackdist(lat1, lon1, tc, lat, lon)
'Find the cross-track distance of the point [lat,lon] from the GC
'defined by the tc bearing from [lat1,lon1]
'[lat1,lon1] cannot be a pole
'positive distance = right of track
tcp = gcbearing(lat1, lon1, lat, lon)
dp = gcdist(lat1, lon1, lat, lon)
gcxtrackdist = Asn(Sin(tcp - tc) * Sin(dp))
End Function
Function gcaltrackdist(lat1, lon1, tc, lat, lon)
'Find the along-track distance of the point [lat,lon] from the GC
'positive distance = along track from point 1
xtr = Asn(Sin(tcp - tc) * Sin(dp))
direction = Sgn(Cos(tc - tcp)) '+1/-1 for ahead/behind [lat1,lon1]
gcaltrackdist = direction * Acs(Cos(dp) / Cos(xtr))
End Function
Function gcv(lat1, lon1, lat2, lon2)
gcv = Array(Sin(lat1 - lat2) * Sin((lon1 + lon2) / 2) * Cos((lon1 - lon2) / 2) - _
Sin(lat1 + lat2) * Cos((lon1 + lon2) / 2) * Sin((lon1 - lon2) / 2), _
Sin(lat1 - lat2) * Cos((lon1 + lon2) / 2) * Cos((lon1 - lon2) / 2) + _
Sin(lat1 + lat2) * Sin((lon1 + lon2) / 2) * Sin((lon1 - lon2) / 2), _
End Function
Function gcsphabc(a, b, c, ByRef AngA, ByRef AngB, ByRef AngC)
'Given three sides of a spherical triangle (a,b,c)
'compute the three angles (AngA,AngB,AngC)
'return 1 on success, 0 if the triangle is impossible
s = (a + b + c) / 2
xa = Sin(s - b) * Sin(s - c) / (Sin(b) * Sin(c))
xb = Sin(s - c) * Sin(s - a) / (Sin(c) * Sin(a))
xc = Sin(s - a) * Sin(s - b) / (Sin(a) * Sin(b))
If (xa >= 0 And xb >= 0 And xc >= 0) Then
AngA = 2 * Asn(Sqr(xa))
AngB = 2 * Asn(Sqr(xb))
AngC = 2 * Asn(Sqr(xc))
gcsphabc = 1
Else
gcsphabc = 0
End If
End Function
'Wind functions
Function wndunk(crs, hdg, tas, gs)
'return unknown wind [wd,ws]
'use rad arguments and result
hdmcrs = hdg - crs
ws = Sqr((tas - gs) ^ 2 + 4 * tas * gs * (Sin(hdmcrs / 2)) ^ 2)
wd = Modcrs(crs + Atn2(tas * Sin(hdmcrs), tas * Cos(hdmcrs) - gs))
wndunk = Array(wd, ws)
End Function
Function wndhdggs(crs, tas, wd, ws)
'return hdg and gs [hdg,gs]
'degree arguments and result
'return ["not","possible"] if course cannot be flown
swc = (ws / tas) * Sin(wd - crs)
If (Abs(swc) > 1) Then
wndhdggs = Array("not", "possible")
Else
hdg = Modcrs(crs + Asn(swc))
gs = tas * Sqr(1 - swc ^ 2) - ws * Cos(wd - crs)
wndhdggs = Array(hdg, gs)
End If
End Function
Function wnd3gs(gs1, gs2, gs3)
'given three groundspeeds on headings differing by 120 degrees
'find the TAS and wind.
'TAS is assumed to be the larger root!
vms = (gs1 ^ 2 + gs2 ^ 2 + gs3 ^ 2) / 3
a1 = gs1 ^ 2 / vms - 1
a2 = gs2 ^ 2 / vms - 1
a3 = gs3 ^ 2 / vms - 1
mu = (a1 ^ 2 + a2 ^ 2 + a3 ^ 2) / 6
bp = 0.5 + Sqr(0.25 - mu)
bm = mu / bp
wnd3gs = Array(Sqr(vms * bp), Sqr(vms * bm))
End Function
Function wnddir3gs(hdg1, gs1, gs2, gs3)
'given three groundspeeds on headings of hdg1, hdg1+120 and hdg1+240
'find wind direction- ASSUMED to be less than the TAS
bm = mu / bp
theta = Atn2((a3 - a2) * vms / Sqr(3), a1 * vms)
wnddir3gs = radtodeg(Modcrs(degtorad(hdg1) + PI - theta))
End Function
'standard atmosphere functions (up to 20km)
Function stdattemp(h1, unith, unitt)
'return temperature as a function of height h
' unith=0 h1 in ft, else h in m
' unitt=0 result in C, else result in F
h = h1
If (unith = 0) Then
h = h * 0.3048 ' ft->m
End If
If (h < 11000) Then
tc = 15 - 0.0065 * h
ElseIf (h <= 20000) Then
tc = -56.5
End If
If (unitt = 0) Then
stdattemp = tc
Else
stdattemp = tc * 9 / 5# + 32#
End If
End Function
Function stdatpress(h1, unith)
'return pressure/sea-level pressure as a function of height
h = h1
If (unith <> 0) Then
h = h / 0.3048 ' m->ft
End If
If (h < 11000 / 0.3048) Then
stdatpress = (1 - 0.0000068755856 * h) ^ 5.2558797
ElseIf (h <= 20000 / 0.3048) Then
stdatpress = (1 - 0.0000068755856 * 11000 / 0.3048) ^ 5.2558797 * Exp(-0.00004806346 * (h - 11000 / 0.3048))
End If
End Function
Function stdatdens(h1, unith)
'return density/sea-level density as a function of height
h = h1
End If
stdatdens = (1 - 0.0000068755856 * h) ^ 4.2558797
stdatdens = (1 - 0.0000068755856 * 11000 / 0.3048) ^ 4.2558797 * Exp(-0.00004806346 * (h - 11000 / 0.3048))
End If
End Function
Function stdatcs(tc)
'return sound speed in air at temp Tc (C) in knots
stdatcs = 38.967854 * Sqr(tc + 273.15)
End Function
'Altimetry functions
Function altdiff(altsetting)
'return (pressure-indicated) altitude (feet) given altimeter setting (in Hg)
altdiff = 145442.2 * (1 - (altsetting / 29.92126) ^ 0.190261)
End Function
Function altdenalt(pressalt As Double, tempC)
'return the density altitude given pressure altitude, pressalt (feet) and
'outside air temperature, tempC (degrees C)
ts = stdattemp(pressalt, 0, 0) + 273.15
altdenalt = pressalt + (ts / 0.0019812) * (1 - (ts / (tempC + 273.15)) ^ 0.234969)
End Function
Function alttrue(ca, fe, isadev, oat)
'return the true altitude (feet) given
'ca : altitude indicated by a calibrated altimeter setting set to the local altimeter setting
'fe : field elevation of the altimeter setting station (feet)
'isadev : altitude-averaged deviation of the air column temperature from ISA (C)
'oat : temperature (C) at altitude
alttrue = ca + (ca - fe) * isadev / (273.15 + oat)
End Function
Function sun(dateinput As Date, lat, lon, zenith, rise As Boolean)
'return the UTC of sunrise or sunset in hours
'return -1 if sun never rises, -2 if it never sets
'lat and lon are the lat/lon of the location in degrees
'zenith is the zenith in degrees
'=90.8333333 for official sunset
'=96 for civil twilight
'=102 for nautical twilight
'=108 for astronomical twilight
'rise =True for sunrise, False for sunset
n1 = Int(275 * Month(dateinput) / 9)
n2 = Int((Month(dateinput) + 9) / 12)
n3 = (1 + Int((Year(dateinput) - 4 * Int(Year(dateinput) / 4) + 2) / 3))
nd = n1 - (n2 * n3) + Day(dateinput) - 30
lnghour = lon / 15#
If (rise) Then
t = nd + ((6 - lnghour) / 24)
Else
t = nd + ((18 - lnghour) / 24)
End If
m = (0.9856 * t) - 3.289
L = Md(m + 1.916 * Sin(degtorad(m)) + 0.02 * Sin(degtorad(2 * m)) + 282.634, 360)
ra = radtodeg(Md(Atn(0.91764 * Tan(degtorad(L))), 2 * PI))
lquad = Int(L / 90) * 90
raquad = Int(ra / 90) * 90
ra = ra + lquad - raquad
ra = ra / 15
sindec = 0.39782 * Sin(degtorad(L))
cosdec = Cos(Asn(sindec))
coshr = (Cos(degtorad(zenith)) - sindec * Sin(degtorad(lat))) / (cosdec * (Cos(degtorad(lat)) + 1E-20))
If (coshr > 1) Then
sun = -1
ElseIf (coshr < -1) Then
sun = -2
Else
If (rise) Then
h = 360 - radtodeg(Acs(coshr))
Else
h = radtodeg(Acs(coshr))
End If
h = h / 15
t = h + ra - 0.06571 * t - 6.622
sun = Md(t - lnghour, 24)
End If
End Function
Function rhumbdirectlat(lat1, tc, d)
rhumbdirectlat = lat1 + d * Cos(tc)
End Function
Function rhumbdirectlon(lat1, lon1, tc, d)
lat = rhumbdirectlat(lat1, tc, d)
dphi = Log(Tan(lat / 2 + PI / 4) / Tan(lat1 / 2 + PI / 4))
If (Abs(lat - lat1) < 0.00000001) Then
q = Cos(lat1)
Else
q = (lat - lat1) / dphi
End If
dlon = -d * Sin(tc) / q
rhumbdirectlon = Modlon(lon1 + dlon)
End Function
Function rhumbdistance(lat1, lon1, lat2, lon2)
dlon_W = Md(lon2 - lon1, 2 * PI)
dlon_E = Md(lon1 - lon2, 2 * PI)
dphi = Log(Tan(lat2 / 2 + PI / 4) / Tan(lat1 / 2 + PI / 4))
If (Abs(lat2 - lat1) < 0.00000001) Then
q = Cos(lat1)
Else
q = (lat2 - lat1) / dphi
End If
If (dlon_W < dlon_E) Then
tc = Md(Atn2(-dlon_W, dphi), 2 * PI)
d = Sqr(q * q * dlon_W * dlon_W + (lat2 - lat1) * (lat2 - lat1))
Else
tc = Md(Atn2(dlon_E, dphi), 2 * PI)
d = Sqr(q * q * dlon_E * dlon_E + (lat2 - lat1) * (lat2 - lat1))
End If
rhumbdistance = d
End Function
Function rhumbbearing(lat1, lon1, lat2, lon2)
q = Cos(lat1)
Else
End If
Else
End If
rhumbbearing = tc
End Function
'direct and inverse functions on the ellipsoid
Function direct_ell(glat1, glon1, a, f, faz, s)
'Solves the geodetic "direct" problem by Vicenty's method.
'Given the location of point 1, and radial and distance from that point,
'finds the location of point 2
'Output is Array(lat,lon) in radians
'glat1 and glon1 are the geodetic lat/lon of the starting pt in radians
'a is the major radius of the spheroid
'f is the flattening of the ellipsoid
'faz is the initial bearing (forward azimuth) in radians
's is the distance (same units as a)
'EAST is positive!!! (unlike the spherical formulae)
r = 1 - f
tu = r * Tan(glat1)
sf = Sin(faz)
cf = Cos(faz)
If (cf = 0#) Then
b = 0#
Else
b = 2# * Atn2(tu, cf)
End If
cu = 1# / Sqr(1 + tu * tu)
su = tu * cu
sa = cu * sf
c2a = 1 - sa * sa
x = 1# + Sqr(1# + c2a * (1# / (r * r) - 1#))
x = (x - 2#) / x
c = 1# - x
c = (x * x / 4# + 1#) / c
d = (0.375 * x * x - 1#) * x
tu = s / (r * a * c)
y = tu
Do
sy = Sin(y)
cy = Cos(y)
cz = Cos(b + y)
e = 2# * cz * cz - 1#
c = y
x = e * cy
y = e + e - 1#
y = (((sy * sy * 4# - 3#) * y * cz * d / 6# + x) * d / 4# - cz) * sy * d + tu
Loop While (Abs(y - c) > 0.00000000000005)
b = cu * cy * cf - su * sy
c = r * Sqr(sa * sa + b * b)
d = su * cy + cu * sy * cf
glat2 = Atn2(d, c)
c = cu * cy - su * sy * cf
x = Atn2(sy * sf, c)
c = ((-3# * c2a + 4#) * f + 4#) * c2a * f / 16#
d = ((e * cy * c + cz) * sy * c + y) * sa
glon2 = Modlon(glon1 + x - (1# - c) * d * f)
direct_ell = Array(glat2, glon2)
End Function
Function inverse_ell(glat1, glon1, glat2, glon2, a, f)
'Solves the geodetic "inverse" problem by Vicenty's method.
'Given the location of points 1 and 2,
'finds the distance between them, s, the azimuth of 2 from 1, faz
'and the azimuth of 1 from 2, baz
'Output is Array(s,faz,baz,flag)
's has the units of a, faz and baz are radians
'glat2 and glon2 are the geodetic lat/lon of the ending pt in radians
'flag=0 if algorithm converges, 1 if not
'algorithm fails to converge if pts 1 and 2 are close to antipodal
iter = 0
itermax = 20
r = 1 - f
tu1 = r * Tan(glat1)
tu2 = r * Tan(glat2)
cu1 = 1# / Sqr(1# + tu1 * tu1)
su1 = cu1 * tu1
cu2 = 1# / Sqr(1# + tu2 * tu2)
s1 = cu1 * cu2
b1 = s1 * tu2
f1 = b1 * tu1
x = glon2 - glon1
Do
sx = Sin(x)
cx = Cos(x)
tu1 = cu2 * sx
tu2 = b1 - su1 * cu2 * cx
sy = Sqr(tu1 * tu1 + tu2 * tu2)
cy = s1 * cx + f1
y = Atn2(sy, cy)
sa = s1 * sx / sy
iter = iter + 1
c2a = 1 - sa * sa
cz = f1 + f1
If (c2a > 0#) Then cz = cy - cz / c2a
e = cz * cz * 2# - 1#
d = x
x = ((e * cy * c + cz) * sy * c + y) * sa
x = (1# - c) * x * f + glon2 - glon1
Loop While ((Abs(d - x) > EPS) And (iter < itermax))
faz = Modcrs(Atn2(tu1, tu2))
baz = Modcrs(Atn2(cu1 * sx, b1 * cx - su1 * cu2) + PI)
x = Sqr((1# / (r * r) - 1#) * c2a + 1#) + 1#
x = (x - 2#) / x
c = 1# - x
x = e * cy
s = ((((sy * sy * 4# - 3#) * (1# - e - e) * cz * d / 6# - x) * d / 4# + cz) * sy * d + y) * c * a * r
If (iter = itermax) Then
flag = 1
Else
flag = 0
End If
inverse_ell = Array(s, faz, baz, flag)
End Function
