Extreme STOL question
jetsam
Post by jetsam »
Just for curious: is any GA aircraft (non helicopter) able to take off at SPRF elev. 14423 ft and land at Sea Level at 100 ft runway?
cdnpilot77
Re: Extreme STOL question
Post by cdnpilot77 »
never flown it but the info on Wikipedia suggests that the Pilatus PC6 Turbo Porter can land in 164ft at sea level also make a successful landing at over 18,000ft, by factory test pilots of course.
http://en.wikipedia.org/wiki/Pilatus_PC-6
Post by niss »
jetsam wrote:Just for curious: is any GA aircraft (non helicopter) able to take off at SPRF elev. 14423 ft and land at Sea Level at 100 ft runway?
Anything with me at the helm baby....
1000 HP
Post by 1000 HP »
Yeah baby yeah! :wink: ( I thought I would mention that if you don't need to take off again I will land anything in 100 feet or less for the right price)
looproll
Post by looproll »
:prayer: PC-6
sprayrail
Post by sprayrail »
While the porter is a great aircraft it does have an equal out there with a larger payload, the Helio Stallion for one and although the specs say takeoff and land in 350 ft., with the PT6 and half a load a 100 ft is do-able.
Regards
MUSICMAAN
Post by MUSICMAAN »
Garrett powered Otter would do it better than the Porter or the Stallion....... (in my opinion)
jetsam
Post by jetsam »
Porter...such a good STOL capabilities and only few in Canada, strange :shock:
MUSKEG
Post by MUSKEG »
Pc-6 is probably the ultimate bush airplane but the range is far to short to be of much use in Canada.
Just another canuck
Post by Just another canuck »
I've flown in the Porter a few times... amazing aircraft. It's definitely not as rugged as our Beavers and Otters, but the STOL capabilities are incredible.
Search Papua, Indonesia and Porter on youtube and you'll find videos from a guy named Sven (possible youtube name porterstans... not sure)... can't remember the last name but I worked with him in Papua. He flew the Otter mostly and DC-3 in Canada for years before getting time in the Porter and according to him, nothing compares. Although, yes, he is Swiss... LOL... and he hasn't flown the Helio, but some of the places the Porter went in and out of in Papua with full pay loads was just unreal. Just like Mel in Air America... :mrgreen:
So throw off the bowlines.
Explore. Dream. Discover.
rigpiggy
Post by rigpiggy »
My understanding was the Helio stallion was a better STOL machine, however the CIA bought 24 of them, and then set up there own production line, to avoid the optics of congress etc.... maytag used to fly one out of YVR and he would be at 5000 by the end of the runway
mag check
Post by mag check »
I would think that the stallion and pc6 would be pretty close on t/o, probably come down to piloting, but the stallion is much faster in cruise.
The guy that owns Oakley sunglasses has one.
Just another canuck
Personally, I have no idea which is the better STOL machine, but would someone care to speculate why Papua and PNG are full of Porters and 0 Stallions (none that I saw anyway). Price? Availability?
mag check
Post by mag check »
Availability. I think there are only 2 on the registery.
StudentPilot
Post by StudentPilot »
Just another canuck wrote:Personally, I have no idea which is the better STOL machine, but would someone care to speculate why Papua and PNG are full of Porters and 0 Stallions (none that I saw anyway). Price? Availability?
I was under the impression there were only ever a few Porters operated in PNG, and they haven't been flown there for quite some time. I've heard there are only a pair of Stallions flying as well...kind of hard to be a common type with so few!
polar one
Post by polar one »
JAC
You said you were in PNG and you have to ask why they use porters there? Susi Air in Indonesia uses them too. I think they have 4 or 6 now. and again, if you have seen what they fly into on a regular and routine basis you wouldnt ask the question.
PNG uses the twin otters a great deal with PNG airlines out of Australia in PNG and the strips they use are a little sketchy..particularily with a plane full of explosives. In both places the porter pilots are all experienced. Enough of a learning curve without trying to learn the basics of the area or STOL flying. Not sure a turbine otter would do what they do as it is more prone to crosswind issues and does not seem so good for flying the wild profiles and back of the curve that extreme STOL in these areas dictate.
Exteme STOL requires you to fly the last phase of the approach (or maybe more) well behind the curve. Porters respond well to this, and I have been told the stallions and the helios in general with their wingie fallout thingies do to. The DHC products (twin otter and turbo beaver) when you get them behind the curve dont give you as much, or any wiggle room
A twin otter is a great plane but the technique is a bit different for getting them in really short and they just land that much faster than the porter.
Extreme STOL is dangerous. It leaves virtually zero tolerance for error, and only takes a bit of an unexpected downdraft or wind gust to make things get really interesting..Lots of wrecks to prove even the pros rely on a bit of luck...not a great thing to do every day.
99% of pilots give the rest a bad name
What we learn from history is that we fail to learn from history
Just another canuck
polar one wrote:You said you were in PNG and you have to ask why they use porters there? Susi Air in Indonesia uses them too. I think they have 4 or 6 now. and again, if you have seen what they fly into on a regular and routine basis you wouldnt ask the question.
I never once said I was in PNG... I have, in the past, said that I was in Papua (Irian Jaya if you prefer). There is a difference. :wink: Actually, Papua is less developed than PNG, according to my sources.
And the only question I asked was "Why do the operators there use the Porter and not the Stallion?" Try re-reading my post. I know what the Porter can do. Like I said, I've seen it and been in the plane when it has been done.
polar one wrote:Extreme STOL is dangerous. It leaves virtually zero tolerance for error, and only takes a bit of an unexpected downdraft or wind gust to make things get really interesting..Lots of wrecks to prove even the pros rely on a bit of luck...not a great thing to do every day.
You're right, it's dangerous, but you know how that old and bold saying goes... and like anything worth doing, it should be done right. I know quite a few of the Porter pilots personally in Papua... all good guys. Some are older folks who've proved that flying around these parts for many years, decades in some cases, can be done. And not just the Porters... the Vans go into some pretty hectic spots as well. And you're right, they (the Porter crew) are very experienced individuals. Mostly ex-ag guys and all "extreme STOL" drivers way before they got to Papua. But even the most experienced can get bitten there... as has been proven many times in the past... just one of the reasons I left the place. :wink:
Just another canuck
Never been to PNG... I thought there were more.
Cheers.
Invertago
Post by Invertago »
http://www.youtube.com/watch?v=fBD1XOY5 ... re=related
Carbon cub would probably do it, but it won't carry much.
StudentPilot
Invertago wrote:Carbon cub would probably do it, but it won't carry much.
After a quick Google search I came up with the 2010 Experimental Bush class STOL results and the 2007 (I think) results from the Valdez fly-in. In 2007, the second place Bush class (ie mostly Super Cubs) pilot landed 66' & 101', and there was only one other landing shorter than 100'. In the experimental bush class there was a Carbon Cub that landed 73' & 53', but the other three Carbon Cubs had one landing under 100' and one landing longer than 100'. There was a Gyro (presumably homebuilt?) with two even shorter landings, but take offs around 140'. In the 2010 Experimental Bush class, there was no plane with two landings under 100'. Judging by the difference in take off rolls (ie Paul Claus taking off in 30' & 19' in a CC in 2007, and 64' & 79' in 2010) I'm guessing the competition in 2007 had a decent wind blowing. From what I've heard, the Valdez competition pretty much results in everyone stripping absolutely everything they can out of their planes and absolute minimum fuel. And I'd assume these are probably some of the best Super Cub pilots out there. I have a feeling landing a conventional plane on 100' consistently will only last so long before you go off the end or land short.
If you don't have far to go, I think I'd recommend a hang glider or paraglider (if either works at 14,000') and a couple of those nifty rockets/jets the birdman uses to get airborne...unless you can just jump of a cliff for "take off."
c185
Post by c185 »
I found the right plane for you :D
http://www.generalaviationnews.com/?p=5681
Do you fly BN? - "WHAT???"
Just another canuck
c185 wrote:I found the right plane for you :D
Very cool!!! :prayer:
cdnpilot77
Holy Crap JAC, we agree on something...common ground, its a beautiful thing!! :goodman:
c185
Post by c185 »
They also offer a 1000hp version :shock:
http://www.sherpaaircraft.com/video.html
Super cool!
But thirsty! :shock: (get the numbers at about 0:45)
http://www.youtube.com/watch?v=OwkUKjR6 ... re=related
