Age discrimination OK if it's against young people
Dockjock
Post by Dockjock »
This topic was challenged as "off topic" when I posted it under another age-related thread in the Air Canada forum. I present it here as it is most certainly germane to the age related discussion going on. For what it's worth, legal experts think this challenge stands little chance of succeeding.
Court challenge lodged against Ontario's stiff under-21 driving law
http://www.theglobeandmail.com/news/nat ... le1661968/
Shall we propose an alcohol ban against drivers over age 60? Clearly, rules that are applied to people differently on the basis of age are contentious.
What about though, if there were a labour group that, as a condition of employment, was bound by a policy that had an alcohol related restriction that was more restrictive than what the law required? Would it be possible to challenge that as a charter right; the 'right' to drink up to 8 hrs prior to operating a flight instead of the 12 hrs that is Air Canada policy? Complying with this condition is mandatory, and yet it is 50% more restrictive than the law. Are my rights being infringed upon?! Or is this just something that I accept as part-and-parcel of being an employee of Air Canada and a member of ACPA?
Just asking...
TyrellCorp
Re: Age discrimination OK if it's against young people
Post by TyrellCorp »
If you were to stomp your feet, get angry and whine loudly enough, I'm sure there might be a body out there that will grant you your wishes at someone else's expense.
"Nothing is worse than having an itch you can never scratch"
the original tony
Post by the original tony »
I'm sure as Tyrell said, someone will help you.
The problem is there is no real money behind it! Human rights as airline pilots go, only count when money is involved. The seniority system, wearing a uniform, even telling us what plane we are going to fly is SOME sort of discrimination. Then again, we accept it when we sign up. My freedom of expression is being hindered making me wear a uniform. Why am I forced to follow a seniority system? I have flown a big jet before, I want to fly the same one now, isn't that discrimination on some level?
But any lawyer worth his salt with a money bag tied around his neck, or jowls as it were, will only fight the discrimination faced by certain groups. Regardless of the cost to others.
A noble fight indeed. Help the senior who gets 4x the pay of a "junior" to do 1/4 the work.
I could only wish more people in the world saw it this way. To compare our retirees to workers making minimum wage, having to work more years to be comfortable. I'll make sure to pass the msg along to the next 65yr old walmart greeter that AC seniors are right there with you. I'll just leave out the part where they will make in a month what you make in a year, that may just annoy him. Go figure.
Now i'll go vomit to cleanse myself of the shit that is this tribunal, farce, charade. Whatever.
Call it what you like, but greedy people like this will always get theirs.
I just won"t feel so bad when i point and laugh.
Tony
accumulous
Post by accumulous »
Not correct. It counts when pilots are prevented from working on any of the prohibited grounds of discrimination as outlined in the legal system of Canada.
Wear shorts. As long as it's the same material and color, why would it be a problem. There are long and short sleeve shirts. You should apply to the Human Rights Commission to make the forced wearing of long pants one of the prohibited grounds of discrimination in Canada. As long as you're not wearing hot pants there should be absolutely no reason why anyone at all would be offended.
Because somebody else is already leading the seniority system.
Because you knew that's the way it was when you signed on.
Which is different than the way it was when the guys before that signed on.
Only if you want to fly the big jet but you're not allowed to because you're wearing shorts. If you were flying the big jet in long pants you may have to put the long pants back on to fly it again because those are the pants you were wearing when you signed on.
Welcome to Air Canada.
Another reason to wear short pants.
Return to “Air Canada”
