Navajo Chieftain Hydraulic System Check
floatplanepilot
Post by floatplanepilot »
Can someone tell me the limits on the hydraulic pump check? As a pilot we are to check the pump by running one engine and placing the gear handle to the fully down position and wait for it to snap back into place. We check one when we start up, and the other on shutdown. Any time limits on this during an inspection? What if it doesn't snap in place, what would be some suspected problems?
Ballsssssss
Re: Navajo Chieftain Hydraulic System Check
Post by Ballsssssss »
You mean "time limits" in regards to how long it takes for it to pop back up after pressing it down? If it doesn't pop back up you likely have a worn out pump on whatever engine you are testing at the time....it's not building enough pressure.
TT: don't care PIC: still don't care MPIC: really really don't care TURBINE: get a life.
Life's never fair, get a helmet.
black hole
Post by black hole »
I Think the time is 10 seconds. Its been a while
BH
floatplanepilot
Ballsssssss wrote:You mean "time limits" in regards to how long it takes for it to pop back up after pressing it down?
Yes. Is it also possible that there was air in the line and and pumping the emergency/gear handle would remove it?
Return to “Maintenance”
