Min Crew Chart
ywgflyboy
Min Crew Chart
Post by ywgflyboy »
Does anyone have the minimum crew chart page (Transport Canada) bookmarked? I have tried searching 100 times over with out success.
comanchepilot
Re: Min Crew Chart
Post by comanchepilot »
Retractable pilots do it with their gear up!
ywgflyboy
Re: Min Crew Chart
Post by ywgflyboy »
Yes. Much thanks!
ScudRunner
Re: Min Crew Chart
Post by ScudRunner »
Don't tell CargoJet but you can operate the 727 with only 2 crew. shhhhhhh :mrgreen:
or does that mean the oiler doesn't count? ouch :goodman:
Panama Jack
Re: Min Crew Chart
Post by Panama Jack »
MINIMUM EQUIPMENT LIST
1) ITEM:
Flight Engineer or Second Officer
2) Number Installed:
1
3) Number required for dispatch:
0
4) Remarks and/or exceptions:
(M)(O) May be inoperative provided:
a) A broom stick, cane, or other similar item of sufficient length and rigidity is carried and readily available at all times to the LSP
b) Chewing gum or another similarly sticky matter is installed at the end of the broom stick, cane, or other similar item of sufficient length and rigidity.
-President Ronald Reagan
