Ever heard wingtip vortices?
Hedley
Post by Hedley »
A new one for me on the weekend. Sometimes you can see wingtip vortices - eg in snow, or cloud - but twice I heard them, descending. First time I thought I was going nuts, but the second time confirmed it.
Sounded like a snake hissing.
Anyone else ever heard wingtip vortices?
KAG
Re: Ever heard wingtip vortices?
Post by KAG »
yes, it hisses and crackles. Your not nuts.
Chase lifestyle not metal.
CD
Post by CD »
Quite often, actually. It's a cool effect, especially on a perfectly calm day...
turbo-prop
Post by turbo-prop »
You should go play golf at theMcCall golf course in Calgary. When there landing 34 you'll here it coming then the pine trees lean over and almost touch the ground.
Props
Post by Props »
Good place is on the jetty in YVR when they're landing 08L. Kicks up a pretty good water spout too.
Tim
Post by Tim »
cool! anyone know what causes it??
Used to hear them all the time when plane spotting at YVR on 26 (before it was 26L). You'd hear them overhead about the time the aircraft had finished with reverse and was pulling off the runway. Sounds like somebody waving tin foil above your head. 727s seemed to do it more often than other aircraft...
linecrew
Post by linecrew »
CRJ 100/200s seem to have a very distinct sound to their vortices when they pass over you on short final.
Topspin
Post by Topspin »
iflyforpie wrote:Used to hear them all the time when plane spotting at YVR on 26 (before it was 26L). You'd hear them overhead about the time the aircraft had finished with reverse and was pulling off the runway. Sounds like somebody waving tin foil above your head. 727s seemed to do it more often than other aircraft...
Staff lot at YVR under 26R. All the aluminum signs bolted 40 feet up in the air start to vibrate and rattle, really cool.
Max Torque
Post by Max Torque »
I have heard them also. Also, on final one clear day, I was landing behind a 727 in a Beech 99. I had noticed a blurred area in front of us, somewhat like a distortion off our left side, almost like on a hot day. Then we got rocked by the other one. We weren't that close, but just one of those days in calm winds and it must have hung around longer.
Edo
Post by Edo »
Off the end of the runway in Prince Albert. The trackers were landing passing overhead at about 50 feet. It was pretty impressive just hearing the engine noise. Just as the engine noise faded, the hissing and crackling started. Very cool it repeated for every plane in the group as they landed one after the other!
jericho flight
Post by jericho flight »
Hear them all the time where I live. JR 705 (jazz), sound the best.
fanspeed
Post by fanspeed »
Definately heard them-anyone else see the shock on your wing?
Hedley
Post by Hedley »
The weird thing is that these were from a little 2000 lb (one ton) airplane. I guess the wing must have been really working.
cyxe
Post by cyxe »
Yes heard 'em, while spotting under the approach to 26R at Vancouver International.
Why do something now when you can do it later??
Team Firecracker
Post by Team Firecracker »
my wife thinks they sound like plastic bags..... :)
Lost Lake
Post by Lost Lake »
The sound is induced by the wing vortices nearly achieving the sound barrier. It causes the ear wax to vibrate at the right frequency. it usually occurs in western canadians, especially in Vancouver and Calgary.
Simple solution is just to clean your ears out.
Skydrvr7
Post by Skydrvr7 »
We used to listen to the Jetstream 31's with Air BC when they would land in Lethbridge. If you went at night and it was calm (not too common in Lethbridge but every once in a while!) you would hear the sssssssssssSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS for about 30-45 seconds after the aircraft passed over...it did sound like someone shaking long strands of tin foil...amazing to hear on a dark and quiet night.
ScudRunner
Post by ScudRunner »
Max Torque wrote:I have heard them also. Also, on final one clear day, I was landing behind a 727 in a Beech 99. I had noticed a blurred area in front of us, somewhat like a distortion off our left side, almost like on a hot day. Then we got rocked by the other one. We weren't that close, but just one of those days in calm winds and it must have hung around longer.
Your just seeing my Carbon Boot print, if your following a 27 you don't even need to dial up the ILS or any Nav just follow the trail of David Suzuki tears it leaves behind.
Post by North Shore »
Who says you can't teach an old dog new tricks!
Happiness is V1 at Thompson!
Lowjack
Post by Lowjack »
I've also heard them all the time at McCall lake golf course just in front of 34 at YYC. AA MD-80's have been the most consistent for you hearing them as they pass over.
all_ramped_up
Post by all_ramped_up »
Yup! Heard them from a Canadian North 737 when I was out for a walk on Frobisher Bay.
Was really loud since it was about -37C out and calm.
Joe Blow Schmo
Post by Joe Blow Schmo »
KAG wrote:yes, it hisses and crackles. Your not nuts.
Let's not jump to conclusions!
GARRETT
Post by GARRETT »
Watch this video and you'll hear the vortices a few seconds after the RJ passes.(I think it's a RJ, didn't look too closely.)
http://www.youtube.com/watch?v=cmdz6_7f ... re=related
Stan Darsh
Post by Stan Darsh »
Stand in the Landing Strip/Aviation World parking lot when they're coming in on 24R at YYZ. You can really hear it whip through the power lines.
