Simple Question About Dash 8 / Turboprop Sounds???
wowie_kazowie
Post by wowie_kazowie »
Hey Everyone!
I just had a simple question about a common sound you hear around the airport coming from the turboprops and especially the Dash 8. The engine sound drops to a lower sound for a few seconds...You can here it in these two Vids:
At 24 Seconds in this one
at 5:08 in this vid
I asked around and the best answer I got was its the pilots adjusting the prop/feather but he was not sure... Is this true?? if not what is it? Just curious as it is one of the best sounds ever (one of my simple pleasures)!
Thanks Gents
No Conflict
Re: Simple Question About Dash 8 / Turboprop Sounds???
Post by No Conflict »
At 24 seconds, that is us putting the one engine into start feather and using the other to taxi. This has to do with the cooling down period required for each engine before shutdown (after stopping at the gate, we normally wait 30 sec or so before shutting down number 2 at the same time waiting for ground power to come up). It also sounds like the capt putting one into disc to slow the plane down without using brakes.
HTH
mattedfred
Post by mattedfred »
I think the sound the original poster is referring to is discing. The Captain selected discing while he was clearing the active in the first video and the Captain selected discing as he commenced his taxi.
No Conflict
mattedfred wrote:I think the sound the original poster is referring to is discing. The Captain selected discing while he was clearing the active in the first video and the Captain selected discing as he commenced his taxi.
Lol, didn't watch the second vid till now... yup, sounds like discing.
Looking forward to flying with ya back in YYZ Mattedfred!
mattedfred
I would reciprocate but I don't know the user behind the username. PM me if you like.
Chaxterium
Post by Chaxterium »
Yep, that's discing. My favourite sound. You should hear it with 4 props! ;)
wowie_kazowie
Thanks for the answers guys, appreciate it! and if you care to answer one more, do you just use discing to for added braking on the ground or always during taxi?
flying4dollars
Post by flying4dollars »
You'll hear this sound with all PT6 turboprops. When taxiing, rather than using toe brakes, selecting the power levers into ground fine (or coaxing it into the reverse gate if you're in a B100) aids in braking and causes the props to make this sound as the propeller pitch changes. I think garrets are somewhat the same but I'm not sure since I've never operated one.
Definitely discing in each of those vids.
Discing is sort of an eeeeeEEEEEooWWWoooEEEEeeeeeoOOWWWoooeee sound, where feathering is sort of a whhhooooommpp sound.
You can sort of hear the feather sound here...
http://www.youtube.com/watch?v=vD5IVoe9Les#t=0m45s
You can hear the discing and the feathering of a B350 here (feather at about 38s).
http://www.youtube.com/watch?v=5pVXEQQIfi8
KISS_MY_TCAS
Post by KISS_MY_TCAS »
flying4dollars wrote:coaxing it into the reverse gate if you're in a B100. I think garrets are somewhat the same but I'm not sure since I've never operated one.
Uhhh....B100s have Garretts on the wing. :smt017
KK7
Post by KK7 »
Chaxterium wrote:Yep, that's discing. My favourite sound. You should hear it with 4 props! ;)
+1 AGREED!!!
In some cases discing is used, in addition to saving the use of excessive brakes, to keep the prop RPM in an acceptable range. In the DASH-7 there is a range of prop RPM that is not recommended, and simply keeping the power levers at flight idle causes the RPM to be in this bad range when on the ground. Discing the props keeps the RPMs above this range.
Chaxterium
I also love the sound a PT6 makes as it goes into feather.
Nothing like the sound of discing though.
BingBong
Post by BingBong »
Another awesome sound on the dash....start the right engine....bring it out of feather....power leaver that sucker into quiet taxi mode...LOVE IT!
flying4dollars
B100 = Beech 100 or King Air 100. Just like B1900 = Beech 1900 :mrgreen:
BTD
Post by BTD »
flying4dollars wrote: B100 = Beech 100 or King Air 100. Just like B1900 = Beech 1900 :mrgreen:
I think everyone new what you meant, but I guess technically.
http://webcache.googleusercontent.com/s ... clnk&gl=ca
The next in the series was the B100, which featured 715 shp (533 kW) Garrett AiResearch TPE-331 engines as an alternative to the Pratt & Whitneys offered on other King Airs, and another increase in MTOW to 11,800 lb (5,350 kg). The B100 was introduced in 1976 and was produced concurrently with the A100 for several years; manufacture ceased in 1983 after 137 were built.
BingBong
Post by BingBong »
edited...due stupidity....
D5GRVTY
Post by D5GRVTY »
If we're all being scientifically correct...a Beech 1900 is B190 according to transport....if were all gonna play this game we better play by the rules :wink:
Huh, all those years of beech 1900 time go down the drain because my company apparently did a type rating on a BE02?? :roll:
Sorry couldn't resist correcting someone's correction ;)
Legacy
Post by Legacy »
Actually none of the Beeches are B. thats designation is Boeing's obviously. Beech is Be. Like GRVTY sais, a 1900 is Be-02, King air 100 is Be-10, 200 is Be-20.
Yeah, but Beech was retarded and put their successive model letters in front of the numerical designation (90, A90, B90, C90 etc) and then they decided to put even more letters behind the numbers for successive models of models (C90A, C90B, etc).
B200 will universally be accepted as a Beech 200 because just about all the variants are the B200 and B is also conveniently what Beech starts with. But only about a third of the 100s were the noisy 'B's from when P&WC went on strike during the 70s till the 100 finished production.
I don't have too much experience with Garretts, but I believe you have to reverse them slightly to get them off the pitch locks which makes an interesting sound before taxi...
5400AirportRdSouth
Post by 5400AirportRdSouth »
Yup, first time I stood in front of one at startup I thought the pilots were taking the piss by blasting me. By the third or fourth time I clued in....
Remember, only YOU can stop Narcissism
