Why CYYZ uses east-west runways until extreme winds?
CYYZ will use their east-west (05-23 , 06-24) runways up until the crosswinds hit 30-40 knots.
In crappy weather they might switch to 15-33 a bit earlier (20 kt xwind).
The downwind / base / finals all cover the entire city / GTA anwyay, so I wonder what policy is involved here?
Anyoone here know why ?
Mike
Mike
33/15 L and R are too close together to do simultaneous landing operations. Their centerlines are only ~4000 feet apart. Normally when ATC is using these runways they land 33L (or 15R) and depart 33R (or 15L).
The 23 and 24R centerlines are over 10,000 feet apart which allows ATC to operate completely seperate and simultaneous take-off and landing operations. On top of this, there is now a 3rd parallel runway (24L) which allows even more aircraft to land and depart off the south part of the field.
A 33/15 operation can slow things down a lot and cause a lot of delays for the airlines. This is why most airlines will accept quite a crosswind for the east-west operation. However, you'll find that once one aircraft refuses landing due to the crosswind ATC will usually change the runways.
HavaJava,
How far apart do rwy's need to be for simul ops ?
Are you either in ATC or a pilot ?
Mike
Aha ! Thank you ! Now I can sleep at nightHavaJava wrote:33/15 L and R are too close together to do simultaneous landing operations. Their centerlines are only ~4000 feet apart).
Mike
just a pilot...but had a brief interest in ATC for a while.
I'm not sure what the minimum distance between centerlines is. I have a feeling it's further here in Canada than in the States. I've seen some crazy approaches down there (LAX, SFO) where aircraft are almost in formation with each other. I'm sure they're not allowed to run simultaneous operations like that in IFR though.
Maybe an ATCer can shed more light on this
Lol, I guess it depends on your perspective, another person might have answered *just* ATC ... but had a brief interest in being a pilot for a whilejust a pilot...but had a brief interest in ATC for a while.
Well it's always IFR, I'm sure you meant IMCI've seen some crazy approaches down there (LAX, SFO) where aircraft are almost in formation with each other. I'm sure they're not allowed to run simultaneous operations like that in IFR though.
I think I read somewhere that SFO can't do simul ops in IMC.
Mike
Captain Crunch
Toronto has a history of being stupid like that, I've been waiting to go there while an RJ's on final at 500' reporting 10kts on the tail, while surface conditions are 30kts at 90 degrees, no need for that at all, the only explination i have for that is that they must be leafs fans, by that reason, not as smart as some others...
- Jaques Strappe
Well CYYZ is a "special place" indeed. I have seen them use the east west runways when the wind is out of the north at 25 kts and then use the 33's when the wind is less than 5. Go figure.
As far as runways being too close together, they should spend a day in Boston, or Frisco. So why would they build another east west immediately south of 24l?
Why is the north runway now 23/05? Did the variation only change in the north end?
Why do you have more frequency changes on the ground in CYYZ than it takes to cross the Atlantic?
Why are ALL the green taxi center line lights always on?
Why is it that when a snowflake appears in any quadrant that the whole operation comes to a halt?
Why do you have to taxi a mile past your enty point only to double back when there is no traffic?
It is Toronto thats why. The center of the universe where no-one looks beyond their backyard to see how the rest of the world operates.
Well said Jaques. You pretty well summed up YYZ, it's a gong show. The Yanks must laugh at it everytime they come in here. It's the model of inefficiency.
BTW, certain airports in the US do PRM approaches (parallel runway monitiored), it's used on runways that are less than 3000ft apart.
Someone should tell the GTAA that parallel runways are only good if you can use them.
They changed the north runway to avoid confusion with the new "middle' runway when they are running simultanious ops on all three runways.
Another reason they favour the east west runways is noise abatement, a lot of the whiney ass'd complainers live to the south and north of the airport but east and west are more industrial/commercial properties.
- Jaques Strappe
1. Airlines (AC mainly) would rather try and keep their schedules rather than operate into wind with the delays that brings.
2. The ATC Shift Manager (in the ACC NOT the tower) is responsible for determining the operation.
3. Noise.
To address other points:
Because the GTAA planned to build another runway south of 05/23 which will be 05R/23L. Ever been to LAX?
We operate 2 grounds for most of the time. 3 grounds are required when all 3 E-W runways are being used and during de-icing and/or snow events. Because of all the taxying around (T2 for 05, T3 to 06L etc) Ground is a mess and can become overloaded quickly. To reduce trhe chances of this ground is split into more manageable pieces. The exact shape and size of these pieces changes from operation to operation. 119.1 is used to protect the other two grounds, not just to piss you off. The airport layout is not user friendly, too many runway crossings.
Only at night unless the electricians are working on them. Ever been to LHR? On all day every day. What is it to you anyway?
You're talking crap now. GTAA are responsible for snow clearing and in coordination with the ATC Shift Manager (not the tower) they decide when to plow and what operation to run. We're just left to pick up the pieces and hang on.
Inbound and outbound points are standardised for various operations to reduce coordination between Apron and Ground. AK is outbound for 99% of the time. How many aircraft have you seen go in AK? Lots I'm sure.
Some I've been asked...
Why don't you use 06R/24L more?
We'd love to but we don't have enough staff to run it for extended periods. There isn't always the demand either.
What gets up a controller's nose?
Crews that don't listen. Crews that assume. Crews that remind you they're holding short. Crews that change frequency without being instructed to. Crews that dawdle into position. Crews that go to position and take up residency.
If you're interested in learning more, phone us, ask for a visit, bring donuts, you'll be made welcome!
YYZ Tower
3. Noise.
YYZ Tower
- Jaques Strappe
YYZTower
You had me very interested in your post right up to the point where you mention green taxi lights in LHR. I fly to LHR several times a month. They are not always on, as you say and for an airport which handles alot more traffic than YYZ, it is a treat to operate there.
You simply follow the greens to the active, or to the gate, eliminating the need for moving 100 ft and then getting another frequency change. You cannot compare LHR to YYZ. The greens in YYZ are an absolute mess and quite frankly are a hinderance. It is literally a sea of lights. Unlike LHR where only a specific route is illuminated. I once asked the ground controller why they were always on ( meaning in cavok as well as low vis ops ) His response was that they didn't know how to turn them off. "What is it to me anyway?" ( typical Toronto attitude ) I can hardly see where the hell I am supposed to go! The rest of the world only uses them for low vis and even then, they only use what is needed.
I am full of crap now when it comes to YYZ coming off the rails in the slightest weather? Lets take a poll on that one shall we????
Inbound and outbound taxi points, great. So why is it that when the apron and taxiways are a ghost town between hub times, no one has the common sense to just say " Taxi to your gate" Hey that would be novel!
While I do understand your complaints about crew and I appreciate the invite, I too would like to have you in the jumpseat to see that YYZ is quite unique from the rest of the world.
Why is it that I can be in Tokyo talking to a Luftansa crew and when I mention that I am based in YYZ the jokes start flying! YYZ has a reputation and it isn't very good I'm afraid.
One question though. If you switch to the north parallels, why does everything slow down to the point where you get AC calling trying to maintain a sked operation? I would assume that it is mainly AC calling as they are YYZ's largest customer. Something the GTAA seems to forget often enough.
Jacques Strappe
They have Lighting Panel Operators at LHR and LGW whose job it is to guide aircraft following Ground's instructions. How they would do this without the lights on would be interesting!
The taxiway lights here are a mess. We have no control over them other than the brightness and on/off. If they're too bright, tell us and we'll turn them down.
I worked several snow events this winter and for the most part they went well, even when we had to use the 15s. That isn't a pretty operation due to the location of the terminals, CDF and the runways, but we work with what we're dealt. Sometimes its crap and we'd like to fold but we have to play the bad hand.
I apologise if it seemed I had and attitude. It wasn't meant to come across as it did.
33s. Arrival rate on 33L is about 36/hour even with 2.5 mile spacing because of the headwind. We offload 6/hour on 33R but that's still way below 55/hour when dualling. For every offload we lose at least 2 departures. Then there's the ground operation - a lot of runway crossings for T3 or a long way around for T1 and 2.
I have been on many jumpseats, but not for a while. Perhaps an exchange visit would be worthwhile?
Not true. Here there is not a stop bar at the runway at night, only in Low Vis. In the UK and Europe you'll find a stop bar at the runway entry at night too.The rest of the world only uses them for low vis and even then, they only use what is needed.
- Jaques Strappe
Hi Tower
Yes they have a lighting operator in LHR so yes the lights must be on. They are not all on at the same time is what I meant. It is not the YYZ controllers fault but with all the green center line lights on at the same time, it really does make for a sea of lights with no real definition as to where the taxi way is, especially when you exit 24L at C1.
So with the 33 operations, if I understand correctly, it is the runway crossings required, that slow down the operations and not that the runways are too close together? ( seperation )
Can an aircraft taxi along Charlie if the 33's are being used?
Do you find, as a controller that the addition of 24R/06L has really increased traffic flow? or does it present the same challenge with runway crossings?
Might help me understand a bit better.
Thanks.
Thanks.
Good morning Jaques
The bottom end of A and B at C, C1 and D is a mess. There is no way for us to deselect individual routes as this is the way it was designed. I agree that exiting 06L at C1 can be interesting. Most tower controllers will try and give you a nudge toward A or C1. Traffic that has exited at C3 and is heading west on C has to be held short of C1 to protect the exit for the next arrival. It may seem inefficient at times but missed approaches can result as an aircraft cannot hold short of C and be clear of the runway.
On the 33s the runway crossings are not the brake on the operation. We try to cross 33R in a gap behind a heavy whenever possible. Sometimes this isn't possible and we lose a bit of time. We need to provide departure with 3 miles in trail and this takes longer to achieve on the 33s due to the strong headwind, so we might sqeeze a smaller aircraft across.
We can taxy along C but we cannot do it when an aircraft is departing due to jet blast considerations. The normal route will be E-C2-06L etc. If departures are light we may cross at T for T1, otherwise its the "end-around".
In the dual each runway can run at over 50/hour. When 06R/24L is being used in the "triple" operation the capacity of 24L+R alone is about 75-80/hour. So yes it does make a difference. Traffic peaks at the moment are maybe 90-95/hour maximum so it may seem under-utilised when we're using it as the demand isn't there. It does make the whole operation a lot easier for us, crossing the departure runway is done in "heavy" holes or in batches to keep delays to the minimum. It is labour intensive though. A third ground is mandatory as is a "monitor" controller for South Tower. Landing and departing the same runway all day does give you grey hair!
Hope this helps.
Hope this helps.
- Jaques Strappe
YYZ Tower, when the wigwag lights are on at the runway intersections of J and 15 L&R (as they always are), it is my understanding that you would be required to stop and get further permission to cross regardless, however most taxi instructions seem to include this crossing clearance in the original. Are aircraft still required to stop and get further clearance, or is the original clearance enough for the crossing?
If you've been given a crossing clearance there is no need to stop at the runway and get further permission. Wig-wags are there to let you know its a runway ahead, and should be on 24/7.
If you've been given a "hold short" then you must read this back and wait for specific crossing instructions. Don't hassle the guy if he's busy though, he knows you're there! If its quiet, a gentle reminder is OK. If you're given a clearance to taxi without a specified crossing clearance (very rare) eg taxy E-G-H, you must not cross any runways without further clearance.
There is no requirement to readback a taxy instruction, but you must read back runway entry or crossing clearances and all hold shorts. If you read it back and get it wrong, then we have to correct it.
Hope this helps.
Hope this helps.
It annoys me that some people have nothing better to do but shoot their mouth off about how bad YYZ is. It is no where near a “gong show” that some uninformed, misguided individuals would lead others to believe. Yes busy and when the snow and ice starts to fly things slow down the same as any other airport. Try to get out on schedule during a snow shower in Boston or New York and YYZ will look like a cake walk. Don’t compare apples to oranges. When was the last time LAX got snow, or freezing rain?
Having flown all over the world YYZ is one of the better high density airports to operate out of.
Lastly I have never seen anyone required to land in a 40 kt crosswind on the east-west parallels. That is a load of SH#T!
And no I am not a YYZ ATC just a regular pilot who makes a living at it.
talkinghead
I'm thinking that with all the new-hires at places like AC and Jazz you are going to see a little bit more of this then normal, remember that when on the grnd most if not all the radio work is done by the F/Os. So maybe give the new guys a brake.YYZ Tower wrote:
YYZ Tower
