NTD specialist?
Gyroscopic
NTD specialist?
Hey guys,
A friend of mine has all her weld inspection tickets and certification for most of the different types of NDT testing..
Was wondering if any of you know any companies who do NDT on aircraft and what requirements might be needed to be considered for hire??
thanks alot!
Gyro
thanks alot!
Gyro
bombardierfixer
Re: NTD specialist?
rdt, viscan. Maybe apply directly to a airline (WJA may need one soon, purely speculation on my part though)
Re: NTD specialist?
I got certified through Cougar NDT in Calgary, they do all kinds of a/c work. Good guys.
helicopterray
Re: NTD specialist?
Not too sure where you're located, but in the Lower Mainland, there's a number of repair shops that use NDT specialists.
Heli-One
Vector Aerospace
HS Tools
Accuren
Heli-One
Vector Aerospace
HS Tools
Accuren
Gyroscopic
Re: NTD specialist?
thanks alot guys!
currently in ontario but willing to relocate so anything will do!
electraguy
Re: NTD specialist?
A couple of things, coming from an aircraft NDT Tech. First of all, what "weld inspection" tickets do you have? Are they CGSB or ASTM? Maigasi, I used to work for Cougar, they are not in YYC and you certified through them? Appendix K trained? The problem with alot of industrial NDT people trying to make the switch to aviation is that they generally don't speak airplane, or the transport lingo. Pipeline weld inspecting and aviation NDT do not have alot in common. Your friend might be best off to apply to a company that does industrial and aircraft, that way she could be taught while still being able to use her current skills to make a living. A quick note, if her certs are ASTM they are of no use in Canadian aviation. Most require CGSB licenses or at least NAS 410. If you have questions PM me.
Son, Your gonna have to make your mind up about growing up and becoming a pilot.. You can't do both!!
Re: NTD specialist?
If your still looking, Perimeter Aviation in Winnipeg has its own NDT shop. Not sure if there hiring or not. give them a call
