Aircraft down in CZFG Pukatawagan-July 2011 + TSB Report
avfun
Post by avfun »
BuckNiner
Re: Aircraft down in CYPM
Post by BuckNiner »
The accident occured at CZFG = Pukatawagan, MB not CYPM = Pikangikum, ON.
BEFAN5
Re: Aircraft down in CZFG Pukatawagan
Post by BEFAN5 »
Everyone remember to check those density altitudes.
ameerdink
Post by ameerdink »
It's a C208, Beaver Air Services.
Awaiting more info.
YTH4Life
Post by YTH4Life »
do you know which airplane it was?
bigsky
Post by bigsky »
ameerdink wrote:It's a C208, Beaver Air Services.
Awaiting more info.
This article says it is a different company..
http://www.winnipegfreepress.com/breaki ... 89174.html
John Fondse, manager of Missinippi Airways, confirmed the aircraft belonged to the company.
"Missinippi Airways will co-operate fully with the Transportation Safety Board inspectors as they determine the cause of the accident," Fondse said in a prepared statement.
There is no substitute for BIG JUGS!!
HuD 91gt
Post by HuD 91gt »
Beaver Air Services is Missinippi Airways.
Safe-T
Post by Safe-T »
Beaver Air Serice does business as Missinippi Airways and according to a TSB spokesman on the radio, the airplane was a C208B manufactured in 2005.
According to T.C. register info this would be C-FMCB.
Also: http://aviation-safety.net/database/rec ... 20110704-0
Spinner
Post by Spinner »
Ridley, Rod
Date: 2011/07/05
Further Action Required: YES
O.P.I.: System Safety
Narrative: Winnipeg ACC reported that an ELT was reported by Winnipeg FIC to RCC at approximately 2115z. It was determined to be C-FMCB, a 208 Grand Caravan, operated by Beaver Air Services. The aircraft crashed on departure of runway 33 at Pukatawagan. ARFF responded.
User Name: Ridley, Rod
Date: 2011/07/05
Narrative: UPDATE
TSB reports that the Beaver Air Services Cessna 208 Caravan was departing Pukatawagan, MB for The Pas/ Grace Lake. During the takeoff from runway 33, the pilot rejected the takeoff, but the aircraft continued past the end of the runway and into a ravine. A post-crash fire ensued. One passenger was deceased; seven passengers and the pilot sustained minor injuries. The aircraft was destroyed.
"LIFE IS NOT A JOURNEY TO THE GRAVE WITH THE INTENTION OF ARRIVING
SAFELY IN A PRETTY AND WELL PRESERVED BODY, BUT RATHER TO SKID IN BROADSIDE, THOROUGHLY USED UP, TOTALLY WORN OUT, AND LOUDLY PROCLAIMING"
WOW... WHAT A RIDE
CGZMT
Post by CGZMT »
Does anyone know the pilot involved? If so can you send me a pm, sent a few emails out and nothing returned! Have a couple friends that work with said company. Thanks for the help!
The more you know the more trouble you can get in!
Doc
Post by Doc »
Heard a rumour today. Hope there is NO truth to it. It happened on the third takeoff attempt? Flaps? I'm not saying this was the case, but, if an airplane fails to take off, a reason MUST be found before another attempt is made. In the 'van, it's either the weight, or the flaps not being set for takeoff?
Redneck_pilot86
Post by Redneck_pilot86 »
In the picture, its hard to tell but it appears the flaps were down...
Doc
Post by Doc »
Redneck_pilot86 wrote:In the picture, its hard to tell but it appears the flaps were down...
Which picture? The one in this thread? I couldn't tell a thing from that? Certainly not flap position? Looks like a Barbecue.
Redneck_pilot86
All I am basing that on is the picture in this thread. It *appears* like there is a gap just forward of the trailing edge of what is left of the right wing, which would be consistent with the flaps being down.
BigQ
Post by BigQ »
Rumour's false. I heard it from 3 different sources, but it's false.
Whisperjet
Post by Whisperjet »
http://www.newswire.ca/en/releases/arch ... c5882.html
Transport Canada suspends Missinippi Airways' Air Operator Certificate
WINNIPEG, July 16, 2011 /CNW/ - Transport Canada has suspended Missinippi Airways' Air Operator Certificate, effective July 15, 2011 at 11:59 p.m. CDT. Without an Air Operator Certificate, a company cannot provide commercial air services in Canada.
This action is based on safety concerns identified during Transport Canada's inspection following the accident in Pukatawagan on July 4, 2011.
Transport Canada has taken this action in the interest of public safety. Transport Canada consulted with Missinippi Airways throughout the period leading up to the suspension. This suspension does not rule out further regulatory action.
Transport Canada will continue to work with Missinippi Airways. The company must demonstrate that it meets all applicable safety regulations before Transport Canada will reissue its Air Operator Certificate.
Midnight Sun Flyer
Post by Midnight Sun Flyer »
Awaiting more info.
Very sad indeed, there have been a lot of accidents with the Cessna 208 since they come on stream
If you want to grow old as a pilot, you've got to know when to push it, and when to back off.
. Yeager
http://www.youtube.com/watch?v=Qstkil0a ... re=related
Post by North Shore »
Whisperjet wrote:http://www.newswire.ca/en/releases/arch ... c5882.html
:shock: WOW! That's a harsh step to take. Something must really be 'up' there to get their OC pulled, when other Manitoba companies in pretty much the same boat did not, in the past, lose their OC's..
Happiness is V1 at Thompson!
floatplanepilot
Post by floatplanepilot »
Proactive Enforcement at its finest.
BEFAN5
Post by BEFAN5 »
Strobes
Post by Strobes »
great news!
cdnpilot77
Post by cdnpilot77 »
Are they flying again yet?
BigQ
Post by BigQ »
