Tumbler Ridge IFR Approach?
randallg
Post by randallg »
Enroute chart LO1 shows Tumbler Ridge CBX7 as having an instrument approach available yet there are none in the CAP. Anybody know why? I'm interested because I have relatives there.
randall g =%^)> C-GTUM - 1974 Cardinal RG - CZBB
BC Flying Photos
oldncold
Re: Tumbler Ridge IFR Approach?
Post by oldncold »
1)It could be a restricted cap approach (r.ca.p.) and that is only avialble to commercial operators that have an ops spec #99 on their operating certificate.
2) the approach could have been cancelled and the enroute still show the route. what is your date on the enroute chart ? the changes are usually listed on the chart. opr on nav canada's web site under the changes to service
Other than that ? fly safe
8)
desertduster
Post by desertduster »
I was going to say it must be an RCAP, but I just looked and there is no RCAP. If there is no cap then you are out of luck.
Perhaps the approach has been decommissioned quite recently; or perhaps it's in the RCAP.
200hr Wonder
Post by 200hr Wonder »
If you check in your CFS they very top section will tell you what publications an airport can be found in so typically LO1, HI1, CAP2 would be an entry fro an IFR airport so if you are wondering about where to find an approach if any for an airport check there.
As for Tumbler ridge it is in the RCAP. The following applies
A minimum climb gradient of 280 ft/NM to 6900' must be maintained during the missed approach procedure.
The following conditions apply to this procedure:
  • The aircraft weight shall not be greater than that necessary to meet published climb gradient on the missed approach
    When computing aircraft weight, corrections shall be made for the pressure altitude, ambient temperature, wind components and any gradient loss associated with a turn planned at the missed approach.
    Crew members must be familiar with the runway environment.
Which if you look at the approach makes sense as there is considerable rising terrain in the the direction of the missed.
200hr Wonder
randallg
Post by randallg »
Thanks all, found it in the RCAP. Too bad I'll not be able to fly it.
BC Flying Photos
Flybabe
Post by Flybabe »
That's not necessarily a bad thing, IMO.
- Amelia Earhart
