Winter & Piston Engines
Colonel Sanders
Post by Colonel Sanders »
It's getting cold again, and time to review some fundamentals
about operating piston aircraft engines in the cold weather.
The four-stroke, air-cooled internal combustion engine in your
aircraft has what is called a "crankcase breather vent tube"
which exits the engine, almost always down low on the belly
where you probably can't see it very easily.
Because the piston rings don't seal perfectly, the crankcase
is pressurized, and that air needs to escape. Hence the
breather tube. But not just air escapes - you've got an
emulsification of oil and water going out the breather tube,
too - which is how the belly of the aircraft gets greasy.
During the summer, the water in that greasy mixture is
harmless - it evaporates. However, during the winter,
the water in the greasy mixture can freeze and plug
the breather tube.
When the crankcase breather tube gets plugged like
this, the pressure increases inside the crankcase and
the next weakest link is the front seal around the
crankshaft, behind the prop. When that seal lets go,
the engine oil is pump out of the engine onto your
windshield (in a single) or over the nacelle of a twin,
like these guys who were flying across the North
Atlantic and made an unplanned stop at Greenland:
To avoid this, you need to drill a small hole or two
in the crankcase breather tube a few inches above
the end of the tube, to act as a pressure relief in
case water plugs the end of the tube up. Some
people like to put one wrap of electrical tape
around the holes, but I have mixed feelings about
that.
Next subject: oil
I personally like to run straight-grade oil (such as
Aeroshell 100Wplus) in the summer in private
aircraft. The reason why is that it is cheaper than
multigrade, and if you don't fly it every day, the
oil doesn't run off the internal engine bits as fast
as multi-viscosity oil does, in the warm weather.
You can run multi-grade oil in the summer if you
have some extra cash that you don't need, and
you fly it every day (eg FTU aircraft).
Decades ago, we only had straight-grade oils
for aircraft, so in the winter, people just went
for a thinner oil, which was better for the start,
but not the best when the engine got hot.
However, these days we have approved multi-viscosity
oil for aircraft engines, and I strongly recommend
their use for the winter. They will really reduce the
metal-on-metal wear at startup because they flow
so much better at cold temps. And, you don't need
to wait for the engine oil temp to get up before you
take off - again, because it flows better at cold temps.
So, in the summer I like to run Aeroshell 100Wplus
and in the winter, Aeroshell 15w50. Good stuff (tm).
There is something called "pour point" of oil, which
you need to know about. The pour point of W100
(sae 50W) straight-grade is only -20C. This can
cause oil to congeal in your cooler and cause your
oil pressure to skyrocket. This happened on an
episode of Ice Pilots and they thought it was something
magical. Uh huh.
However, the pour point of 15w50 is -42C. This
means that the oil is far less likely to congeal in your
prop hub or cooler. Much safer for winter ops!
Next subject: Preheat
Most people think you preheat an engine in the winter
to make it start. That's actually not true. A side effect
of heating the engine is that you make the fuel evaporate
better, which makes it easier to start.
However the reason you pre-heat an engine is to reduce
the internal damage caused by a cold start. You've got
metal-on-metal wear occurring, and you've got differential
expansion and contraction rates of dissimilar metals which
can reduce internal clearances. Neither of these are good
for making TBO.
To make the point, you could probably start a Lycoming
at -20C by spraying highly volatile ether into the intake.
It would probably burn and the engine would run. But
you could expect to see a lot of metal in the oil.
It is worth mentioning that mogas evaporates a lot
faster than 100LL in cold temps, and as a result, it's
a lot easier to start a cold aircraft engine with mogas
in the tank. Mogas has it's own problems, though.
How to preheat? Well, you can buy all sorts of
expensive (and not so expensive) aircraft engine
heater systems which have pads which glue to the
crankcase, bands you strap around the cylinder,
heating elements you plug into the CHT holes.
They're slick - just run an extension cord out to
the engine and plug it in. If you're doing a lot of
winter flying, they're a good idea.
However, you can also buy 1000W 120VAC
little heaters from Canadian Tire that you can
put in your engine cowling. Depending on the
temps, after an hour they get the engine to a
good temperature.
You can buy expensive engine tents/covers from
places like Kennon (very nice) or if you're a cheap
bastard, cut the zipper off an old sleeping blanket
and drape it over the nose. Doesn't work very
well outside in the wind, though. Works ok in a
cold hangar.
When to preheat? As always, what the engine
manufacturer says is golden. It has been my
experience that TCM engines frost the plugs if
you try to start them below 0C. You can start
a Lyc colder than that, but it might not always
be a good idea (see above).
Call me a candy-@ss, but if it's below 0C, I
preheat. Cold starts can do a lot of damage
to your engine, and if you take care of your
engine, it will take care of you.
Note that a heater in the cockpit is a really
good idea, too. I destroyed a really nice
attitude indicator on a crisp February morning,
learning that gyros don't like extreme cold.
Note that with multiple heaters, you may trip
a circuit breaker (or blow a fuse). Two 1000W
heaters is really straining a single 15A 120VAC
circuit. I like to wire hangars with "split receptacles"
like a kitchen or bathroom, for this reason.
BTW, if you're going someplace in the winter,
toss a engine blanket or blanket in the back of
the aircraft, and as soon as you park someplace
(if you intend to fly again that day) immediately
get the engine covered up to retain the heat for
the next start. You wouldn't believe how fast
an engine, pointed into a cold wind, can cool down.
Do it before you pee, or buy gas or food.
Hopefully there are some useful hints and tips
for people here. If I can stop one engine from
being destroyed this winter, that will make it
worthwhile! If you feel the need to personally
attack me (as usual), go right on ahead as well,
because I honestly don't care what a wanker
like you thinks.
JayVee
Re: Winter & Piston Engines
Post by JayVee »
Great advice.
No need for an attack.
Dh8Classic
Post by Dh8Classic »
All you have to do is get rid of the last paragraph and you will rapidly become the best poster on the forum. Just like on the spin advice you gave without the last paragraph.
vrrotate
Post by vrrotate »
Great advice as usual colonel. Maybe a re-post of this in the flight training forum could help out some less experienced instructors/students this winter.
Colonel Sanders
Why on earth would I want to be that?
What I so is save airframes and engines from being destroyed
by educating pilots about how to operate them. I suspect this
can be achieved without continually re-inflating their egos.
Colonel Sanders
I thought about that, but there might be people that don't
read the flight training forum (eg private aircraft owners, etc).
Everyone that reads the flight training forum probably reads
this forum.
I feel a Venn diagram coming on ...
edit --- Dh8Classic - have you read the P&W Radial Engine
manual yet?
For the people that are confused by the above sentence:
https://dl.dropbox.com/u/16541550/PWRadial.pdf
I remember a C337 several years ago on its way from YVP to YFB in extremely cold weather that had a double engine failure. They were lucky as they landed on fairly thin ocean ice and were rescued quite quickly. It was suspected that they had lost their oil.
http://aviation-safety.net/wikibase/wiki.php?id=48619
Several years back a group of us were going to ferry band new Cirrus SR-20's across the Atlantic in the dead of winter. Due to complications, I only got from Minnesota to New York state. But one of the big worries was the breather tube which at the time(but possibly no more) was located along the front of the engine. A slot was cut in the breather hose because factory new aircraft did not have them.
A couple of years later, one of the guys I was flying with was ferrying a Cirrus across the Atlantic with another Cirrus tagging along in the dead of winter. The pilot of the other aircraft apparently refused to do this cutting of the breather and lost oil pressure, crashed and died just off the coast of Greenland.
http://www.hclj.dk/da/havarirapporter/~ ... eport.ashx
I have seen on occasion quite a large amount of ice on an IO-360 engine breather which always made me feel that the second hole should be quite far from the end of the breather tube and not fairly close as you sometimes see as I wonder sometimes if a large amount of ice could block both holes if water/oil is continuously accumulating in the blocked tube.
I always hangared as well below 0 degrees. Not only was it better for the engine, you don't have to scrape off frost. Even once I got Tannis heaters which heat the oil pan and cylinder, scraping frost is still a real pain on some aircraft.
Oil seems to be one of those subjects with people having very strong and differing opinions. I like the logic of the explanation. As for coring or blocking up of the oil cooler, it can be a turbine problem as well and I have seen it on an Allison engine where the procedure was to manually close the oil cooler flaps. Why....with oil bypassing the congealed cooler, the oil temperature is rising quickly on a -40 day. So the automatic oil cooler flaps open making things worse. Close them and wait for engine heat to warm up the cooler and see the oil temperature drop(kind of backwards).
Colonel Sanders
Great! A slot is far better than nothing, but I might
mention that a couple of small holes, spaced apart
will also do the same job, and will not weaken a
solid metal breather tube, the same way that cutting
a slot with a hacksaw will.
That's probably good advice. Even here in the balmy
south of eastern ontario, I have seen four inches of
frozen snot solidly plugging up the end of a breather
tube on an O-320. Fortunately it had two small holes
drilled, farther up.
Remember what the objective is:
to save airframes and engines from being destroyed by educating pilots
Last edited by Colonel Sanders on Thu Nov 08, 2012 7:43 am, edited 1 time in total.
[quote="Colonel Sanders"][quote]A slot was cut in the breather hose because factory new aircraft did not have them[/quote]
[/quote]
Good point about weakening a tube. In this case it was a rubber-type black hose.
dirtdr
Post by dirtdr »
Thanks Colonel!
As a brand new Pilot with my own airplane, this is indeed very good information.
lownslow
Post by lownslow »
The slit in the rubber hose is a great idea. It stays closed (and clean) when the breather is operating normally but only takes one or two PSI when the regular breather freezes.
LnS.
Colonel Sanders
Another hangar pre-heat tip, this one for your hands:
Panama Jack
Post by Panama Jack »
Thanks Col. Sanders. Lets of good info I never knew.
cap41
Post by cap41 »
Can anyone suggest a good pre heater for a C150? Flying year round.
Canoehead
Post by Canoehead »
Colonel Sanders wrote:Another hangar pre-heat tip, this one for your hands:
And here I thought the only hangar use for that thing was keeping the gene pool in check :wink:
Great advice CS.
cgzro
Post by cgzro »
If you put an old sleeping bag around the engine / cowl and then take a 1500w electric heater you can put the heater under the plane, fashion a tube out of aluminum flexible ducting and direct the air up to the bottom of the engine through the bottom of the cowl. This will warm up the engine bottom to top in a few hours and does not modify anything.
If you have access to 220v you can get a 3500w heater which will heat things up very quickly but you'd have to be careful not to overhead things.
If you don't have electricity you need a propane heater and ducting. Some people duct to blow into the front of the engine but it seems better to me to blow it up from the bottom.
Nice thing about the air is it heats everything, hoses etc. as opposed to the glue on things which heat the oil and cylinder bases only.
cgzro wrote: Nice thing about the air is it heats everything, hoses etc. as opposed to the glue on things which heat the oil and cylinder bases only.
Couldnt agree more! Its so much better to have everything at a nice reasonable operating temp.. because as we all know.. not all of that oil ends up back in the pan!
cap41
Post by cap41 »
Thanks for the reply. I have regular 110V power available. It seems the the tanis system is a good option. The plane is on the ramp at the school i am at. Not sure if that sleeping option will work. I am hoping to fly the airplane 3-4 times a week. I like the tanis or EZ heat option as I can plug it in and leave it. Than the plane is ready togo when I arrive.
Anyone have any experience with the EZ heat system, It seems to be very economical compared to Tanis.
Post by ahramin »
A note on the sleeping bag trick. Take an old sleeping bag, cut the zipper off, then take it to your upholsterer and have them cut it to the shape of your cowl, then sew a zipper into it. Cheap form fitting engine blanket.
pez
Post by pez »
Interesting hand warmer... Took me a second there....
rigpiggy
Post by rigpiggy »
Imageeasy to carry preheater, 10# propane bottle, adapter to standard propane soldering torch, 4" of 3" stovepipe/ w a 90 elbow, and another 4' of flexible tubing ie: dryer duct, tuck it into your cooling outlet. Use with caution open 3" flame. Also works on your truck aim at the oil pan
habs.fan
Post by habs.fan »
Thanks for the good post, CS. I'll be checking for the little holes in the oil breathers of the school planes here next time I fly.
GyvAir
Post by GyvAir »
Colonel Sanders wrote: To avoid this, you need to drill a small hole or two
that.
The holes or slots need to be in a part of the cowl area that will be kept warm with engine heat. I usually see them within a few inches of the engine or at least well within the cowl.
There are SBs and ADs to cover this issue on a number of models, if you want to try to play within the rules. A sampling from google:
http://comanchegear.com/SERVICE%20LETTE ... %20370.pdf
http://www.commander.org/bergcom/tech/D ... 2%20SB.pdf This is a big file. Scroll down to SB-112-50.
http://www.aviataircraft.com/pix/pbulletins/sb19.pdf
http://rgl.faa.gov/Regulatory_and_Guida ... enDocument
http://www.casa.gov.au/ADFiles/under/ce ... 70-047.pdf (apparently it gets cold down there too)
As the Piper SB indicates, the less tube hanging out in the wind, the less likely it is to freeze.
I think the idea of the slot and the forming of the tube is to create a little venturi to suck air in through the slot during normal non-freezing ops, in an attempt to prevent oil from spewing into the cowl. It doesn't work that well, hence the tape trick. A nice neat square of not the stickiest tape in the world (so it will come off with a tiny amount of pressure build up) works nicely. Don't wrap the tape around the tube; it won't let go before you've made a mess. Trust me. In the winter season, just take the tape right off and put a new piece on in the spring.
Mooney has an interesting approach to preventing their breather lines freezing:
http://www.mooney.com/images/pdfs/sb-pdf/m20_312.pdf
What about baffling to block and lower the amount of cold air flowing into the oil cooler. Have flown aircraft with home made modification. Oops...is that legal.
cgzro
Post by cgzro »
There is already a thermal bypasss of the oil cooler that prevents cold oil from going through it.
