Orca 208s?
V1 Rotate
Orca 208s?
Post by V1 Rotate »
Do they regularly run Caravans over the mountains now?
Hmm...
Re: Orca 208s?
I didnt know they had 'vans !
Was that them I saw in YYF then? or was it morningstar?
Re: Orca 208s?
How is a Van any worse than all of the Navajos that have been lost doing bag runs in the mountains?
200hr Wonder
Re: Orca 208s?
Post by 200hr Wonder »
They are sub chartered from Alkan
Re: Orca 208s?
Were the losses in the mountains due to the Navajos or the crews?
Re: Orca 208s?
That's what I'm saying... it doesn't matter what you fly if you make a mistake. But I also don't think either aircraft is appropriate for going over the coastal ranges year round.
boeingboy
Re: Orca 208s?
Post by boeingboy »
They don't have vans. They can barely keep the hoes and metros in the air.
boeingboy
Re: Orca 208s?
Post by boeingboy »
V1 - you gone east yet?
Re: Orca 208s?
Nor do I.
Re: Orca 208s?
Post by 2550 »
Twin turbines only then? There is no plane in the world that will make an inexperienced crew safer.
lilflyboy262
Re: Orca 208s?
Post by lilflyboy262 »
A caravan can comfortably climb to 16,000 with a decent load. So whats the issue? Even a few twin turbines with an engine out and a full load will find themselves in trouble over those ranges.
Re: Orca 208s?
Which will fly further with an engine failure a single engine airplane or a twin engine airplane?
1 -1.....0
2-1......1
Roar
Re: Orca 208s?
Post by Roar »
Maybe a current C208 pilot could correct me, its been years since i've flown the Van but I seem to remember a chart in the AFM that prohibited flight in any icing conditions above the mid teens.
J31
Re: Orca 208s?
Post by J31 »
Roar wrote:Maybe a current C208 pilot could correct me, its been years since i've flown the Van but I seem to remember a chart in the AFM that prohibited flight in any icing conditions above the mid teens.
Above 20,000 feet
Redneck_pilot86
Re: Orca 208s?
Post by Redneck_pilot86 »
You know guys, just because a Caravan can go IFR, doesn't mean it has to. I know the guys flying here, and they are pretty used to getting challenging jobs done safely. These guys have operated in mountains without incident for years, and I would say the Whitehorse area is more challenging then the Vancouver area. Sure, the mountains aren't quite as big, but the weather forecasting is crap and there is very little support once you are en route.
Last edited by Redneck_pilot86 on Sun Jan 06, 2013 12:20 pm, edited 1 time in total.
Redneck_pilot86
Re: Orca 208s?
lilflyboy262 wrote:A caravan can comfortably climb to 16,000 with a decent load. So whats the issue? Even a few twin turbines with an engine out and a full load will find themselves in trouble over those ranges.
What is your definition of comfortably? Even through about 10000' in a gross weight caravan, you are down to around 600 fpm...and that falls back even more as you climb higher. Also, this caravan has no O2, so unless they are carrying portable oxygen they are limited.
Re: Orca 208s?
Any chance you might pick up wing ice at 16000 feet during most of the year??
Redneck_pilot86
Re: Orca 208s?
Cat Driver wrote:Any chance you might pick up wing ice at 16000 feet during most of the year??
Sure, so don't go if there is icing forecast. Pretty simple choice in a caravan.
Re: Orca 208s?
If there are clouds forecast at that altitude there would be icing in cloud..correct?
So there will be a lot of times you would be best advised to not fly a 208 there..correct?
PT6-114A
Re: Orca 208s?
Post by PT6-114A »
02 is an option in some of the caravans out there. I know a few flying around that have it.
Re: Orca 208s?
Remember what happened with the last YVR operator that was regularly running the 'Van over the rocks?
Re: Orca 208s?
Yes they defied all the beliefs so preventable among a lot of pilots that single engine turbines don't quit and even if they do you can find a safe landing spot.
Redneck_pilot86
Re: Orca 208s?
Is every cloud full of ice? Do we have to sit at 16000, or could we try 14000? Do we even have to go IFR, or can we get around VFR?
I will agree to your "best advised to not fly a 208 there" statement as far as you are best advised not to fly a 208 at 16000 in icing...but I see no problem flying the airplane within its capabilities in mountainous terrain.
PT6-114A wrote:02 is an option in some of the caravans out there. I know a few flying around that have it.
They don't have O2 in this particular caravan, although I have seen it as well.
esp803
Re: Orca 208s?
Post by esp803 »
I'll also vouch for the crews flying that Caravan, they know the limits. I had no problem operating the Caravan IFR up in the Yukon, I certainly would have preferred to be down south for it, where this is more then two ILS's in a thousand miles (not counting Alaska). I suppose there is probably more ice down in the lowermainland area then up in the Yukon.
As stated before, the crews on that aircraft know their stuff and know when to say no.
E
lilflyboy262
Re: Orca 208s?
Cat Driver, thanks for point out that when a single quits, we have no engine.
But what is the TRUE single engine service ceiling on a light turboprop when it is MAUW on a hot summers day? I bet it is below the mountain tops in a lot of those areas. You are just as likely to get into trouble with that too.
Icing at 16000? Depends on the day. Once it gets below around -15 to -20 generally it is only light icing. The van can handle light icing with no issues.
Just keep a very close eye on it. Once the airspeed begins to reduce, get out of it. Either turn around or descend. Pre-flight planning is a must and keeping an eye on escape routes.
O2 is an option in a lot of vans. I've seen it on about 50% of the ones that I have flown.
You just have to know what you are doing with the plane, and be very careful about the situations that you get yourself into. No different to any other aircraft you fly. Know its limitations.
