nbinont wrote:I've flown it - Just file your flight plan and be sure to get a transponder code before crossing the border. You'll get switched to Boston Centre. I was VFR and the clouds kept me lower than I wanted. Lost communication with all ATC, out of range of all VOR/DME for about half an hour. Not as fun as I'd imagined! Don't worry - you'll be fine!
As NB says above and don't trust that the frequency you're handed over to at the border will give you good comm to a station. We (6500 ft) were helped out by higher traffic (9500) who relayed a station we could talk to. Rather lonely all by yourself in the middle of nowhere...
If I had it to do again I'd scope out where all the ground stations were and their frequencies and go down the list until I could raise someone. FWIW, we didn't get any calls from flight following the whole leg, don't know if it was no traffic or no comm/thin coverage.
D
