Buy a plane or instruct to build experience?
airspeed250
If you were to hire someone for an entry level job, say 500 to 1000 total time, would it matter much if their experience came from instructing versus owning and actively flying their own plane?
checkremarks
Re: Buy a plane or instruct to build experience?
If it was multi pic time then he'll no becuase multi pic time is king. Get a few hundred hours of multi pic and you'll be surprised how quickly you will get called.
I suppose that owning, maintaining, and flying your own plane might be seen as having a quality of responsibility and might give you more varied experience provided you don't just go between the same airports over and over...
However.....
Using your own plane solely to build time seems like a 'buy-a-job' venture and it doesn't come with the training or operational demands that you see in a typical commercial flying operation. A pilot with that experience should be able to fill out an operational flight plan; do quick and complete passenger briefing; properly weigh, distribute, and secure just about any kind of cargo; fly to safe weather limits; deal with less than ideal clients; say no to pushy clients; and do things in a timely and orderly fashion.
Somebody bombing around in their own aircraft is going to be at square one in those regards... or they may not, who knows? But a guy with 500-1000 hours flying commercially would certainly have at least some of those experiences.
However.....
- Colonel Sanders
Doesn't matter. Some might prefer one to the other,
perhaps even strongly. But it still doesn't matter. It's
all SEL PIC.
As someone mentioned above, people get all horny
for multi time. Never figured out why. I have to laugh
when I see a requirement for "1000 multi pic". Hell,
if you haven't taught yourself how to fly a multi after
100 hours, there's no hope for you. 100 hours is a
really long time.
I check people out in the C421, which has a fearsome
reputation to never, ever make TBO, unless you're some
kind of legendary Engine Whisperer (tm).
What bullsh1t. I check people out in a 421 in ONE DAY.
If you're not bright enough to listen to me and learn to
fly a 421 in one day, it's time to change jobs.
1000 hours multi time, my @ss.
all SEL PIC.
really long time.
Things you might want to consider; when you are an instructor your working with other's in a professional relationship; if you teach to a high standard you get a good "rep" more students more flying. You are also working in the "flying industry" and learning how that industry thinks.
The colonel is right you can learn to fly a twin in a day but you aren't going to be the Capt on it (unless you own it and pay the insurance bill) and for the first so many hours your going to continue learning how that plane works/ flies.
My first aviation job was as flight attendant for an arctic operator, I loaded the luggage etc and wobbled fuel at 40 below. That turned into dispatcher (I had pilot license) that included polishing planes during slow times.
Why because back then if you where good the company would get your multi training paid for ( gov't program) and you ended up in the right seat of some multi. One of the guys I polished planes with ended up as that companies chief pilot.
Final thought; I know lots of pilots that did not start out as instructors or built/ bought time flying. What they all did was get involved in the "flying industry" and found thier way into the cockpit. Good Luck whatever way you decide to go; its what you make of it!
Well, in my option, flying experience, is measured in hours, and the example, being
debated here is, 1000 hours multi pic.
If you have 1000 multi PIC, what does that show ?
It shows you probably worked as a SIC for some one successfully , and were upgraded,....
Because of your flying abilities, ( hopefully not because, you went out and bought a PPC or type rating)
Or that you were the next warm body in line, and or had been there the longest ( survivor)
With 1000 multi pic, you have likely operated a multi for a year and a half to 2 years, and experienced
The operational challenges which one faces as a PIC in a commercial IFR operation, for two seasons in Canada.( summer, winter, IFR, maintenance, loads, night, and icing/ deciding situations.)
So what is that worth ?
To me , If I was hiring an individual, I would still check the candidate's references ,
But the candidate's experience is worth a lot.
Getting back to the original question.
If you have a reasonable well paying job, and you can keep the job, then buy a single engine,
and time build with it. Go on longer trips that way you will learn, and experience
more.
If you are not in a position to buy an AC, then instructing
for not more than two years.( you must be at a relatively busy school, with some
Multi , and IFR training.
Either way good luck, and fly safe.
more.
TheRealOtter
You really have absolutely no idea of what you speak. I'd like an example of what you call "500 hours of REAL experience....." I've had very good luck hiring instructors.TheRealOtter wrote:While private time does not count for much in my books, instructing probably counts for less. When I see an application that has instruction time on it, I take that time and divide by half, and subtract that from the total. Like the ATPLs, except opposite, I would far rather have a co-pilot with 500 hours REAL experience, then 1000 hours of circuits or 750 hours of joy rides on your own machine.
A guy who's owned and flown his own airplane has made all his/her go/no go decisions on their own, has had to "mind the shop" simply because they've been responsible for paying the bills.....all very good experience.
Who cares if its not "REAL" in your books? I don't.
500 hours of talking on the radio, moving the gear handle, and staring at the magenta line while watching the miles count down on autopilot..... vs 1000 hours in busy terminal airspace watching someone without a license who you barely know do ten landings an hour while you try and decide where the line is between learning and crashing?TheRealOtter wrote:I would far rather have a co-pilot with 500 hours REAL experience, then 1000 hours of circuits or 750 hours of joy rides on your own machine.
I've been listening to this 'real' flying BS for far too long....
Totally agree with the pie man on this. Can you say "Lemon Meringue" knew ya could.iflyforpie wrote:500 hours of talking on the radio, moving the gear handle, and staring at the magenta line while watching the miles count down on autopilot..... vs 1000 hours in busy terminal airspace watching someone without a license who you barely know do ten landings an hour while you try and decide where the line is between learning and crashing?TheRealOtter wrote:I would far rather have a co-pilot with 500 hours REAL experience, then 1000 hours of circuits or 750 hours of joy rides on your own machine.
Chuck Ellsworth
Remember this is the internet and TheRealOtter may not have a clue about how to determine a pilots worth.....I've been listening to this 'real' flying BS for far too long....![]()
I would love to do a check ride on some of these people to see just what level of expertise they have.
- Beefitarian
airspeed250
Re:
Hi Beef. I've had a good paying career until this point but I've always wanted to be a pilot. I climbed the corporate ladder and I'm now in my thirties. It's time for a change and the desire to fly is still there. I don't want to stick it out in my current gig just for money and wonder "what if" when I'm 50. I'm fortunate I've saved a large portion of my income so it's possible to buy a plane to build some experience but not sure if that time is respected versus instructing.Beefitarian wrote:I have a question. Why would anyone that could afford to buy an airplane and fly it 500 hours, care about getting a job as an entry level pilot?
I keep reading stories here about pilots who can't afford groceries.
I appreciate everyone's feedback so far.
- Beefitarian
- Colonel Sanders
Despite what everyone tells you ...
It doesn't matter where you get your licences & ratings.
It doesn't matter how you get your first 1000 hours.
What matters is who you know, and can you fly the sim
and answer the IFR questions during the interview.
All else is bullsh1t. If your uncle is Chief Pilot, you're in.
My advice is to get qualified without accumulating debt.
would value that experience much more than instructing.
A lot of people have a hate on for instructors.
Me too, ..I would love to do a check ride on some of these people
Of course it is. Fly all over North America. A lot of peoplenot sure if that time is respected versus instructing
Spot on.Colonel Sanders wrote:Despite what everyone tells you ...
My first 432 hours was mostly in my own single engine airplane...which I continued to fly for a few years even after my first flying job. It was a great experience and education in itself as a guy in his young 20s. A lot of fun too...
