Every time I do a flight instructor renewal, the Inspector
shows up with a printout with the average flight test
marks of my recommends.
Guess what you're going to do? The exercises that
your students score lowest on.
Now, you're a special case - kind of an initial. You
have no recent flight test recommends. That shoots
that all to hell.
Sometimes in this situation, the PE is developmental
as hell and asks you to pick an exercise. If that's the
case, pick the simplest exercise there is.
This might be obvious, but by the time you're a class
2, you've recommended at least 10 flight tests, and
given at least 500 hrs dual. I know class 2 instructors
that have given 5000+ hrs dual. Hopefully by that point,
none of the PPL exercises should pose any particular
challenge for you to perform, or demonstrate
What the examiner wants to see is good PGI, taught
the TC way. It really doesn't matter what exercise you
are teaching. Like many flight instructors, you are
erroneously focusing too much on the technical side
of aviation, and not enough on instructional techniques.
If you apply all the learning factors, and deliver good
PGI at the whiteboard, you will pass the flight test. At
least, that's the case for everyone else I've ever met -
if you can get to the airplane, you've passed the test.
I mean, what the hell is the PE going to ask you to do
in a 172, that you haven't already done a thousand
times before? Hell, if the PE will push the paper, I am
happy to have him ride along and watch while I do a
surface level aerobatic routine in a 172, complete with
rolls, loops, 1/2 cuban 8's and hammerheads.
Remember, an instructor flight test is passed at the
whiteboard, with good PGI. If you don't know what
good PGI is - in excruciating detail - well, go back to
your recommending class 1 and review it. There are
an awful lot of pretty marginal class 1's out there, and
I hope yours isn't one of them.
