I taxiied the plane for fuel, with about 3/8 fuel quantity indicating in each tank, which seemed about right for the flying I had previously done. No one else flies or runs the plane. I planned three hours of flying, so I specified 170 liters total between the two tanks, which was fuelled. The fuel as found was to be my reserve. (the nature of the flying did not permit a "fill r up"). After this fuelling, the qty indicated full on both tanks, and I thought to myself, I had goofed, and ordered too much fuel.
And no, before you correctly and wisely ask, I did not dip the tanks. It's a brand new fuel quantity indicating system, STC installed into that plane 33 flying hours ago, which had been checked, and appeared to be operating properly.
I did my three hours of flight testing, and landed "safely" - I found out the next day, I had landed on fumes. It was independently confirmed that I had 3/8 tanks indicating before I fuelled, and again as I landed following the three hours of flying. So how could I have been on fumes?
The plane was then fuelled with 293 liters, with a uselable quantity of 284, and a total capacity of 302. That pucker factor went waaaay up! What had happened?
So, with confirmed full fuel, I flew again. I watched the EDM930 very carefully. I saw wandering fuel quantity information during the flight, but nothing wildly out of what should be normal for the first hour. But as the flight went along, I saw this:
So the useable that instrument should indicate would total to 284L. According to the certification rules, the unuseable fuel should not indicate in level flight. (When the useable fuel is exhausted, the quantity should read zero).
In the photo, it can be seen that the quantity indicators think the plane is carrying (142+135) = 277 liters - but I am 1.7 hours into my flight, and the totalizer is saying that I have burned 101 Liters so far. That totals to 378 liters, or 94 liters more than the useable amount, or 75 liters more than the absolute capacity of the tanks. The EDM930 is way out.
So I'm getting a dipstick. I'm also drafting a report to support a complaint to JPI, and I'll be filing an SDR. I'm thinking that a $6000 engine instrument, newly STC installed should be more accurate than this, or else come with a huge disclaimer. It is a certainty that accuracy like this does not meet the requirements for certification - which it has.
But, at the very least, one would think that this wizard instrument, which is factory programmed for this aircraft, would sum the fuel it reports is aboard, and the fuel it reports as burned, at pop up a red flag if it thinks the sum of those exceeds the total capacity of the aircraft (or, more properly, the total useable fuel).
The client now wants the original Cessna fuel indicators reinstalled. I can't blame him!
So, I am again a little wiser, and feeling rather stupid, which is not the first time. I have flown with suspect fuel quantity indication in other aircraft, but at least the indication led you to be suspect, and then I did check and dip. I guess we don't even trust the most expensive fuel indicators available for this plane! I got it wrong, and nearly very wrong - learn here from my mistake...
